Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Like Tree2Likes
Old 04-12-2013, 06:32 AM   #61 (permalink)
Flight Style: Smooth 3D
FBL System: Thunder Tiger GT 5.1
Motor: Scorpion 4020-1100KV
Pinion: 18
Target Headspeed(s): 2200-2600
ESC: Talon 90
Governor: Talon
BEC: is in the Talon
Cyclic Servos: Savöx 1250 MG
Tail Servo: Futaba BLS 251
Main Blades: Stock SAB 500mm
Tail Blades: Stock SAB 80mm
LiPos: 4200 Zippy 40c
Kastlunger is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 10:30 AM   #62 (permalink)
Nice to see a couple people using the GT5 on the G500. I have 2 & just finished setting up my 2nd MT325e with the GT 5.1, & I really like this unit. I prefer it to the AR7200BX from my experience. For this bird I decided to try the SK540.
Flying-Sport/big sky
FBL- SK540
Cyclic- MKS DS9660A+
Tail- MKS DS760
Motor- Quantum 4115-1200
ESC- YGE120
Backup- Scorpion Bug
Reciever- 2x DSMX sat.
Batteries- 2x Pulse 5000mA 45c
Total cost-$1942.CAN
This cost includes tax of $205. & $23. shipping insurance. Does not include batteries.
rcnorth is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 02:36 PM   #63 (permalink)
Here goes...
  • Flight Style: Sport / Smooth 3D / Some smack
  • FBL System: Mini Vbar, 5.3.4
  • Motor: Quantum 4120-1200
  • Pinion: 17t
  • Target Headspeed(s): ~2300-2800
  • ESC: YGE 90LV (incl signal boost cable) + Prog Card III
  • Governor: YGE Gov Store, maybe Vgov later
  • BEC: YGE integral 6 amp cont/12 amp peak
  • Cyclic Servos: Align DS515M
  • Tail Servo: Futaba BLS251 + Futaba metal servo arm
  • Main Blades: SAB 500mm
  • Tail Blades: KBDD Extreme Edition 84.5mm
  • LiPos: Thunder Power, G8 6S4400 70C
  • Anything Else: Fromeco DC-Up II + Y-harness to YGE Slave cable to RxC port on MiniVbar; YGE slave cable signal pin disconnected
Built, but NOT YET MAIDENED as of 4/13/13.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 04-14-2013, 10:00 AM   #64 (permalink)
Default Finally caved in!!
FBL System: Ikon
Motor: Quantum 4120 Goblin edition
Pinion: TBD
Target Headspeed(s): TBD
ESC: Kontronik Jive 100+ and heat sink
Governor: Kontronik
BEC: Jive 100+
Cyclic Servos: Futaba BLS153
Tail Servo: Outrage BL 9188
LiPos: PULSE LIPO 4500mAh 22.2V 45C
tontondavid is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 09:34 AM   #65 (permalink)
  • Flight Style: Smooth 3D
  • FBL System: MSH Brain
  • Motor: Quantum 4120 1200 (Goblin Edition)
  • Pinion: 18T
  • Target Headspeed(s): 2200 - 2400 - 2600
  • ESC: YGE 120 LV incl signal boost cable
  • Governor: MSH Brain
  • BEC: Built-in ESC
  • Cyclic Servos: MKS DS9660A+
  • Tail Servo: MKS DS760
  • LiPos: not yet...
  • Paint job: Red/white
On settings...
- Goblin 500, Brain, mks ds 9660A+, mks ds760, yge 120lv, Quantum 4120 1200
- NX4, Brain, mks ds 9660A+, mks ds 8910A+, Edge 423
- Goblin 380, Brain, Xnova Tareq, BK3001HV, BK5005HV, YGE 90 lv
- DX8
manux88 is offline        Reply With Quote Quick reply to this message
Old 04-22-2013, 06:08 PM   #66 (permalink)
Budget build just to try out the 500 Had to go with the sexy Red/white/black!
Flight Style: Sport & Smooth 3D
FBL System: Mini VBar
Motor: Quantum 4120- 1200 Goblin Edition
Pinion:18T Stock
ESC: Talon 90
Governor: In Talon
BEC: In Talon
RX Pack: N/A
Tail Servo: Align DS615
Main Blades: Stock
Tail Blades: Stock
LiPos: Pulse 5000mAh 65c (Can feed my 700 Goblin also)
Goblin 700 w/ full VBar | Goblin 500 w/ Full VBar | Blade 300x w/ AR7200BX | Blade (100x?) MCP X BL w/ Pushrods
Spektrum DX8 | Powerlab 6 | ProtekRC Pro 40
Doostur is offline        Reply With Quote Quick reply to this message
Old 04-22-2013, 10:01 PM   #67 (permalink)
Originally Posted by ShaneXman View Post
  • Flight Style: Smooth 3D / Smack 3D / Big Sky/ Speed
  • FBL System: Mini vbar
  • Motor: Scorpion 4020-1100
  • Pinion: 22T pulley
  • Target Headspeed(s): 2700 - 2750
  • ESC: YEP100
  • Governor: Mini vbar gov w/ hobbywing sensor
  • BEC: Built in with yep100
  • RX Pack: none
  • Main Blades: Stock SAB blades
  • Tail Blades: Stock SAB blades
  • LiPos: Pulse 4500 45c 6s
Heres mine
kumar2494 is offline        Reply With Quote Quick reply to this message
Old 04-26-2013, 10:53 AM   #68 (permalink)
Flight Style: Circuits, Loops, Rolls, Just learning some 3D
FBL System: Mini V-Bar
Motor: Quantum 4120-1200 Goblin edition
Pinion: 18T
ESC: YGE 120 LV
Governor: Mini V-Bar
BEC: YGE 120 LV
Cyclic Servos: JR 3717 HV
LiPos: Thor 4400mah 45C
Should have the build done today and hopefully the maiden flight too.
Spektrum DX8, Blade MCPx, Blade 130X, Goblin 630 V-Bar Silverline, T-Rex 450 Pro Mini V-Bar, T-Rex 550 DFC V-Bar Silverline, Goblin 500 Mini V-Bar, Gaui NX4 SK540.
Wolfman350z is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 12:01 PM   #69 (permalink)
Default My Favorite Helicopter!
Flight Style: Hard 3D, Smack 3D, Smooooooth 3D
FBL System: Spektrum AR7200Bx with Satelite
Motor: Quantum 4120-1200kv Goblin Edition
Pinion: 19 tooth
Target Headspeed(s): Bailout/2404/2807
ESC: Castle Creations Talon 90
Governor: Talon 90
BEC: Talon 90
RX Pack: NONE
Tail Servo: OutRage 9188
Main Blades: Stock SAB 500mm, Might Go To Revolution 520mm
LiPos: 3x THOR 4400mAh 6S 45C and 1x THOR 3300mAh 6S 45C
Anything Else: I'm 13 Years Old...
HorizonHobbyFreak is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 04:51 PM   #70 (permalink)
  • Flight Style: Novice
  • FBL System: HC3SX
  • Motor:Savox 4050-1200
  • Pinion: 17t, and 18T
  • Target Headspeed(s): ~2400-2800
  • ESC: YGE 90HV
  • BEC: N/A 2S Lipo RX pack 21000MAH Zippy
  • Cyclic Servos: KST DS515MG
  • Tail Servo: MKS BLS 980
  • LiPos: Zippy 6S 4500MAH 45C
  • Anything Else: Futaba R6203SB 14SG
  • Anything Else: Red
Kit, Cyclics, Lipos, motor ordered, 2 of 3 cyclics Backordered (anyone got some KST DS515MGS they want to loan until mine come in?
I'm moving 3rd week of May so I'm not sure when this will maiden
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 05-17-2013, 05:15 PM   #71 (permalink)
FBL- SK540
Tail- MKS DS760
ESC- YGE120
Changing to YGE90LV, because I'm going to use my YGE120 in my 550X
Old 05-17-2013, 06:25 PM   #72 (permalink)
Flight Style: Beginning Sport, Very Light 3D
FBL System: AR7200BX (Beastx)
Motor: QUANTUM 4120- 1200KV
Pinion: 18t
Target Headspeed(s): 2200 normal 2600 IU
Governor: Talon 90
BEC: Western Robotics Hercules Super Mini BEC G2
Cyclic Servos: Savox SH-1250MG
Tail Servo: Savox SH-1290MG
LiPos: 4 x Glacier 30C 4000mAh 6S 22.2V LiPo
Color: Yellow / Black
Goblin 380 / Spirit FBL
02DropTopM3 is offline        Reply With Quote Quick reply to this message
Old 05-21-2013, 08:47 AM   #73 (permalink)
  • Flight Style: Big Air / Light 3D
  • FBL System: Spektrum AR7200BX
  • Pinion: 18T
  • Target Headspeed(s): 2600
  • ESC: Castle Talon 90
  • Governor: Internal
  • BEC: Internal
  • RX Pack: n/a
  • Cyclic Servos: Savox 1250mg
  • Tail Servo: Savox 1290mg
  • Main Blades: SAB Stock main blade
  • Tail Blades: SAB Stock tail blade
  • LiPos: Align 3300 packs from my trex... (for now)
Tri$tate 3D | BK Servo | Switch Blades | HeliDirect | Canomod
cjpainten is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 12:11 AM   #74 (permalink)
Flight Style - Sport/Smooth 3D
FBL - Spartan Vortex
Motor - Qauntam 4120-1200
Pinion - 18 tooth
Target H.S. - 2400 - 2750
ESC - Kontronic 80HV
Gov - 80 HV
Bec - Internal Kontronic 80HV
Cyclic Servo - Futaba BLS153
Tail Servo - Torq 9188
Main Blades - Sab 500
Tail Blades - Sab 80
Lipos - Gens Ace 4000
TT E720, Logo 600SX, , Goblin 570
Proving the laws of gravity
bitsnpieces is offline        Reply With Quote Quick reply to this message
Old 05-25-2013, 02:43 PM   #75 (permalink)
FBL System: ICON Flybarless System
Motor: Scorpion 4020-910kv
Pinion: 23t
Target Headspeed(s): 2300 normal 2400 IU1 2500 IU2
ESC: Hobbywing 100A
Governor: ICON
BEC: CC Pro
Cyclic Servos: Hyperion DH16-FTD
Tail Servo: Hyperion DH20x-GCD (with Gaui metal tail servo gears)
Main Blades: Gaui 520mm
Tail Blades: KBDD EE 84.5
LiPos: GensAce 25C 4000mAh 6S 22.2V LiPo
Color: Red / White
R71d
Futaba T8FGS - Goblin 500, Gaui X2, Heli-Max Axe 100CP, and miscellaneous crashed heli parts...
Ranger71d is offline        Reply With Quote Quick reply to this message
Old 05-30-2013, 02:25 AM   #76 (permalink)
Motor: Savox BSM 3750 1300KV
Pinion:18T Stock
Target Headspeed(s): 2300 - 2500 - 2700
ESC: Hobbywing 100a
Governor: MSH Brain Gov
Cyclic Servos: Savox 1250MG
Tail Servo: Savox 1290MG
Main Blades: Edge 475MM
Tail Blades: KBDD 84.5 Yellow
LiPos: Turnigy 6S 4500 30C
hoggy is offline        Reply With Quote Quick reply to this message
Old 06-10-2013, 10:15 AM   #77 (permalink)
My set up
  • Flight Style: Sport / Smooth/ (3D newb) / Big Sky
  • FBL System: MSH-Brain
  • Pinion: Stock
  • Target Headspeed(s): 2600/2800
  • ESC: Yep 100a
  • Governor:
  • BEC: currently built in / waiting on wr
  • RX Pack:
  • Cyclic Servos: Savox SH-1250-mg
  • Tail Servo: MKS 760
  • Main Blades: Stock SAB 500mm
  • Tail Blades: Stock SAB 80mm
  • LiPos: Assorted at moment 6S 4000
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 06-13-2013, 06:56 AM   #78 (permalink)
Talking goblin 500 setups
Thank you All for posting your setups as it helped me decide on my electronics as i finally pulled the trigger buying my 500 , it was in my plan for months recently decided on a trex 500 and then my friend decided he was going to get a 700 Gobby and he was like get the 500 you only live once, true.. So heck I got the gobby 500 as i wanted my first goblin to be a 630 next year which i still plan on but now ill have two eventually ,im over Impressed, certainly.worth the significant price over align 500 and got it tuesday built 90% weds and just wow, what quality and instructions fool proof! More than i planned on budget for my 500 plans but its totally worth every nickel. I will post my setup very soon..side note they dont leave much extra room in that frame as i.chose cc 100 edge over the talon 90 literally had to build it into the frame..hope i have no need to take it out lol
Jbishop73 is offline        Reply With Quote Quick reply to this message
Old 06-13-2013, 08:20 AM   #79 (permalink)
  • FBL System: Mini Fu-Bar
  • Motor: HKIII 4020-1350
  • Pinion: 18T pulley
  • Target Headspeed(s): 2500-2600
  • ESC: YEP(YGE) 100A
  • Governor: yep gov
  • BEC: Grypone BEC
  • RX Pack: 3000mah 2S
  • Tail Servo: Futaba 9254
  • Main Blades: Maniac 500mm
  • Tail Blades: stock
  • LiPos: NanoTech 6S 4000mah 45-90c
- Velocity 50 n1 - (coming soon) / OS 55 / Align 50 Muffler / Align 3GX / Align 3G Blades / Futaba 7C
- HK 450Pro v2 FBL
Trex 500ESP - SOLD
Trex 600NSP - SOLD
raiden83 is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 08:55 PM   #80 (permalink)
Flight Style: Sport / Smooth 3D / a little smack
FBL System: mini Vbar
Pinion:18
ESC: YEP 150 amp
Governor: internal
BEC: 6 amp 12 max internal
Cyclic Servos: Align DS515's
Tail Servo: Align DS655
Main Blades: stock
Tail Blades: stock
LiPos: Beast DNA 4000 40c
Radio: Futaba 7c fasst
RX: FrSKY TFR4 s-bus
Micah
mhills51 is offline        Reply With Quote Quick reply to this message
