Old 09-26-2015, 06:21 AM   #1 (permalink)
Default T rex 250 servo's what is new ?
Hi guys , i have one servo on the swash that is failing and i am thinking to replace all three of them . What is a good swash servo and not too expensive or good combo deal ?
Blade 230s V2- Mini Titan 450- Logo 500 - Bell OH kiowa- Spektrum DX 18 and some gliders
guyken is offline        Reply With Quote Quick reply to this message
Old 09-26-2015, 06:46 AM   #2 (permalink)
Still using Align servos on mine, if I were to swap it would be for a DS76t set to save weight.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 09-26-2015, 12:48 PM   #3 (permalink)
And what about these ,
HK-933MG Digital MG Servo 12g/2.0kg/ 0.10sec
Old 09-26-2015, 02:23 PM   #4 (permalink)
Just replaced mine with these ones
http://www.align-trex.co.uk/electron...-hsd41601.html
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super
Toocool4 is offline        Reply With Quote Quick reply to this message
Old 09-26-2015, 03:11 PM   #5 (permalink)
Not bad, a little slower than the stock Align servos, but not bad for the price.
There's always a bit of a gamble buying cheap HK stuff, but sometimes it pays off.
Old 09-26-2015, 05:10 PM   #6 (permalink)
I'm also on the hunt for some fast servos, and light servos, that's pops right in, at a reasonable price.
There's a couple of BB servos, i think the 180 uses them, not sure if it will fit nicely in the 250.
Also Spektrum has some h3xxx??? a bit unsure about the quality though
Again still on the hunt
Just a guy, tryin to Fly
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 09-26-2015, 05:33 PM   #7 (permalink)
I use Turnigy 212dmh servos on the cyclic of my 250. With a speed of .07 sec at 4.8v, coreless motor, metal gears, dual bearings and metal case with a heat sink, and they only cost $19 at Hobby King. They work great for me. Also use a Turnigy 306g on the tail.
Trex 550e•Blade Fusion 480•Blade 330s•Blade 230s Smart•MSH Protos 380 Evo •OMP M2 Explore•OMP M2 V1•(2)OMP M1• Goblin Fireball•Blade Fusion 180• Spektrum NX8
Victory Motorcycles:2013 Victory Cross Country•2007 Victory Jackpot
kla912000 is offline        Reply With Quote Quick reply to this message
Old 09-27-2015, 12:55 AM   #8 (permalink)
They're a good spec, just heavy for me, I much prefer the way the 250 handles if you keep the weight down.
Old 09-27-2015, 06:50 PM   #9 (permalink)
The weight doesn't bother me. I don't do any hardcore 3d so it isn't a problem. They are only a little heavier than the stock 415's but are much faster. The biggest thing for me is the metal gears. The ds76t is more of a tail servo. They are definitely light and fast but on cyclic the plastic gears strip too easy. The Trex 250 has plenty of power to handle the Turnigy 212's. My 250 performs great with them.
I guess it all comes down to personal preference. Everybody is different. I just have always had a good experience with Turnigy servos.
Old 10-10-2015, 12:39 PM   #10 (permalink)
Have you tried these? How do you like them? If not, what did you go with?
Murph_d is offline        Reply With Quote Quick reply to this message
Old 10-10-2015, 04:25 PM   #11 (permalink)
I tried them once on a Blade SR. They worked pretty good as cyclic servos. They are a clone of the Corona 933mg's. They center good and are pretty fast and are great for the price. The only major downfall that I found with them is the mounting tabs are a bit fragile. You have to be very careful when mounting them to not break the tabs. What I did was cut a small piece of 2 sided tape put it on the inside of the tabs, against the frame, and stuck the servos on first then put the screws in. The 2 sided tape gives the mounting tabs a bit of a cushion and prevents the tabs from breaking, as long as you don't over tighten them.
Overall, a good servo for the price.
Old 11-10-2015, 04:15 PM   #12 (permalink)
Anyone running the TGY-213C? They are around 16g, about the same as the 211/212 and only a couple of dollars more.
yakky is offline        Reply With Quote Quick reply to this message
Old 11-13-2015, 07:40 PM   #13 (permalink)
The 213C is a very good servo. I have the 212dmh's but my buddy has the 213C's on his 250. They are very similar servos but the 213C's have a bit more torque and are better for 3d flying. When it's time to replace my servos, that's exactly what I'm going to get, the TGY 213C's.
Old 12-16-2015, 08:21 AM   #14 (permalink)
I tried the hobbykings 933 on my 250 with mini vbar.they caused all kinds of cyclic wobble no matter the settings I used.servos would jump around in a hover.
xxxntwv is offline        Reply With Quote Quick reply to this message
Old 12-16-2015, 09:03 AM   #15 (permalink)
Thanks for the feedback, I'll probably end up with a set of them.
Old 12-17-2015, 01:21 AM   #16 (permalink)
For sure, we have been waiting for a fast, light weight(under 10 grams), coreless, full metal gear servos for the 250. You'd think they would of made one by now, but still.... they are just a tad too heavy.
Old 01-11-2016, 11:13 AM   #17 (permalink)
11g, more than 10 but not by much
https://alofthobbies.com/kst-ds245mg...in-08-sec.html
Number is online now        Reply With Quote Quick reply to this message
Old 01-11-2016, 12:49 PM   #18 (permalink)
yeah that's been out for almost 3 years now, some complain of slop
http://www.rcgroups.com/forums/showp...9&postcount=70
Old 01-11-2016, 01:03 PM   #19 (permalink)
My KST 215 were also sloppy after a few hundred flights. no effect on flying characteristics.
Old 01-11-2016, 01:05 PM   #20 (permalink)
The Spectrum 3050/3060H are also very good servos, and lighter than the big metal servos.
