Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > mQX
mQX Blade mQX Quad Helicopters Information and Help
Old 02-06-2012, 04:54 PM   #101 (permalink)
Originally Posted by Blue87 View Post
Now getting it to lift off.... A whole different story... LolAttachment 287094Attachment 287095
Anyone have any advice on how to get this board to properly spin up these sr tail motors?
I thought that Blade SR runs on 3s Lipo?
If power is the problem, i think that you could use NPN-transistor as a switch to power these SR-tail motors
sucmanhtritue is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 05:17 PM   #102 (permalink)
Originally Posted by tntburnett View Post
+1 sweet
Be blessed
Isaac
Sent from my DROIDX using Tapatalk
+2 looks great
Nytflyer is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 05:18 PM   #103 (permalink)
Are they spinning at all??? As said before maybe they require more voltage
Old 02-06-2012, 06:28 PM   #104 (permalink)
So in theory, I would connect ground as usual then put the positive motor lead from the board to the base leg of the transistor, then a 3s lipo to the collector leg, and the motor positive to the emitter leg? If I am way off please correct me lol
Blue87 is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 09:09 PM   #105 (permalink)
My memory is that this is a common collector (voltage follower) configuration for an NPN transister, in which case, the voltage across the motor will be slightly less than the voltage to the transister base (voltage from the board to the base). So not much voltage to the motor.
Which circuit will work is complicated:
It will depend on whether the board output to a motor is active low or active high. I do not have an mQX yet, so I do not know.
One way to test: There are 2 leads to connect a brushed motor to the mQx board.
One lead will be to some transister or MOSFET. The other will be to +V or -V.
Do you know if the +V/-V lead is at +V (when active, the other lead will connect to -V) or -V (when active, the other lead will connect to +V)?
This will determine whether you need an PNP transister or NPN transister, respectively. In either case, one would probably use a common emitter configuration: base to the motor lead of the board (only about 0.7V drop across the base circuit, so use a resister inbetween the base and board to limit the current running through the transister),
collector to the motor lead, and
emitter to the appropriate supply voltage.
Instead of a PNP or NPN transister, using a P-channel or N-channel MOSFET may be better: possibly less voltage drop across the device when on, and
will not use-up too much current from the board (but may need a pull-up or pull-down resister).
Later: I forgot: a common emitter (for MOSFET, common source) circuit inverts things, so you may need to switch which supply voltage a motor connects to and also switch leads on the motor to keep it spinning in the same direction. This will be messy.
Sorry for the mess, but I do not have a mQx yet, so cannot take the measurements to tell you which option will work.
flying-llama is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 09:23 PM   #106 (permalink)
Originally Posted by liftbag View Post
I will try this very soon, but I am convinced that the Walkera 4G3 tail esc with integrated converter works great.
Paolo
Thats all I am using is 4 of the 4g3 tail esc's with built in converters..
Yeah you're right paolo I waisted money on the fans they will never work oh well be great for a small jet lol
f.a.r.m.e.r is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 09:42 PM   #107 (permalink)
Originally Posted by Varc View Post
okay, now I want that shell!
Where can I order that canopy? I noticed that the ebay listing is in a different language and bids only.
FL offers tuning for the hood
MQX + + + + + In black Full
Carbon Optic + + + + + with
contrasting slices and Comets in
neon yellow. Much more visible
***** + + + + + You finally see
where the front and the back
is ... ... .. If only for X mode! Enjoy
there is no private sale Redemption
or warranty
Google translate
Well I guess saves me time dont have to make anymore canopies, these look much better then mine
I bet mario from MIA is sweatin bullets over these canopies and will follow up with some kind of lawsuit that dude stole his designs
Old 02-06-2012, 10:36 PM   #108 (permalink)
If designes were "stolen", at least they were improved upon! LOL!
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 10:43 PM   #109 (permalink)
What's the highest output bl motor able to be used on the 4g3 ?
Old 02-06-2012, 10:44 PM   #110 (permalink)
Lmao varc so true lol
Old 02-07-2012, 01:47 AM   #111 (permalink)
I did a re-do
steve28 is offline        Reply With Quote Quick reply to this message
Old 02-07-2012, 01:50 AM   #112 (permalink)
I didnt like the "struts" I had made so I fixed it with velcro and put it on an angle towards the front flying in 'X' mode
Old 02-07-2012, 04:16 PM   #113 (permalink)
Highest output I have used is the hp05 but im sure it can handle more.. Its the same as the helimax tail esc, but helimax has specs on their unit if you want to know its ratings check out their site...
Old 02-08-2012, 09:46 AM   #114 (permalink)
Blade Forum Support
Hey peeps I was messing around with my old mcpx paper canopy and look what I did from looking at the one the guy made on ebay.
Not has good but its a start.
Be blessed
Isaac
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 08:02 PM   #115 (permalink)
Here are a few pics of my Gaui skids mod.
I use a rubber band around the mounting pegs to secure the battery.
Here you can see how I have trimmed away the stock landing stands.
There is plenty of clearance beneath for cameras, or sidewinder missiles.
The gyro sponge has held well, and will serve to dampen vibration better. Also the wire upgrade to the motors should save my FETs.
There will be no mistaking which mQX is mine at the local fly-ins.
Heli-Yeah! is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 08:17 PM   #116 (permalink)
Attachment 287747
Attachment 287756
Attachment 287749
Attachment 287748
Attachment 287755
Attachment 287750
I want those props! Does it flip pretty well? I know you mentioned in the video thread that they were a bit heavier than stock. You think you lose a little bit of agilty?
If so that really isn't terrible anyway they look cool as hell and I would imagine would make it a bit more stable for those looking do do some key chain cam videos.
Old 02-09-2012, 12:45 PM   #117 (permalink)
Since as of now, hes the only one with optional canopies available, I went and purchased MIA Style C canopy for my MQX.
I will report back when I recieve it and post pics.
I wouldve purchased from somebody else, but I wanted something now.
Old 02-10-2012, 01:22 AM   #118 (permalink)
Please post detailed photos, in case anybody wants to make a copy for themselves
fac13 is offline        Reply With Quote Quick reply to this message
Old 02-10-2012, 01:48 AM   #119 (permalink)
liftbag is offline        Reply With Quote Quick reply to this message
Old 02-10-2012, 07:21 AM   #120 (permalink)
I just laughed coffee out of my nose!
