NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001 |
05-25-2015, 05:18 PM | #1 (permalink) |
aftermarket skid question
does any othe skids fiton the env?
SRW, EFC,RCRCC AMA 930196 IRCHA 3540 Skookum support pilot |
05-25-2015, 08:08 PM | #2 (permalink) |
I have always used the stock skids. You may be able to take some from another 700 and drill holes to fit.
soXos Strike 7.1 L, Diabolo 600, Logo 600, Kraken 580, Protos 380 Evo |
05-29-2015, 07:18 AM | #3 (permalink) |
I have the same question on skids. I had been told last week by CY Hobbies that the skids would come in this week. They have been out for what seems like months. That is all I need. However, I noted that other hobby stores are out of other items for the ENV 700. I wonder if there are problems as A Main and others are discontinuing the Rave and have very little CY inventory.
Any info on CY or the Rave situation would be appreciated.
Trex 600N/550/450, Whiplash 90e/Rave ENV Nitro. Better Careful and Measured than Cut and Mangled... |
05-29-2015, 11:55 AM | #4 (permalink) |
the guys at Curtis Youngblood said they we're restocking soon. I found that the skids for the tsa 700 should work it's 79mm and the rave env is 76mm
05-29-2015, 04:57 PM | #5 (permalink) |
I sent pictures and the dimensions to Dennis at The Heli Farm. He is going to phone me tonight with what will work the best. He stocks Synergy, Align, Alees, Thunder Tiger etc.
05-29-2015, 06:02 PM | #6 (permalink) |
I just talked to Dennis at The Heli Farm, 1 780-864-8291, info@thehelifarm.com .
He has landing gear that will bolt right on the Rave Ballistic and ENV. You will still use the stock lower frame brace that bolts to the frame. http://curtisyoungbloodhobbies.curti...S1023-5174.htm They have a 3" hole bolt pattern already. They have a 10mm skid pipe and are built tough. They were for a Century gasser. Call Dennis.
