Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 500X
500X Discussion and support of the Gaui Hurricane 500X QuadCopter
Old 04-02-2012, 02:50 PM   #1
Lubebosch
Default Motor losing power in Gaui 500X
I built a stock Gaui 500X with a FY-91Q GPS Controller on 2S Lipo
It flew great until I decided to assemble a dedicated camera gimbal and move to 3S Lipo.
The unit now lifts off and, after a few seconds. the rear left motor loses power and the ship falls reversing on that side. If I start again, same story.
I also put a BEC to avoid overload of the ESC, but nothing changed. The FY-91Q seems to work well (no malfunction LED on).
Any suggestion?
Luigi
Lubebosch is offline        Reply With Quote
Old 04-05-2012, 03:55 AM   #2
Lubebosch
Anyone?
Old 04-05-2012, 09:02 AM   #3
ppridday
Is there any chance that one of your ESC's or one of the motors is failing? You should be able to swap motors and controllers around and check that through process of elimination.
Paul
I love the smell of kero in the morning....
ppridday is online now        Reply With Quote
Old 04-11-2012, 09:17 PM   #4
briangp
I'm still new to this bird, but first thing I'd check is for bad bearings on that motor. Swap the motor position and see if it follows, that would be a good troubleshooting technique.
AMA# 655558
Trex 600E, Compass 6HV FBL Head, Microbeast, Inolab DS760MG cyclic, Logictech 6100G tail, CC HV85 ESC, Scorpion 4025-630
briangp is offline        Reply With Quote
Old 05-05-2012, 02:55 PM   #5
maxtrin
Hello i have the exact same with my Gaui 330X any ides??
maxtrin is offline        Reply With Quote
