| Beam E4 Beam E4 Support Forum |
I had a blade strike which cracked on of the stock main rotor blades. Before I order another set of stock blades I am curious to know what blades you guys are using these days...
Mark Gaui 200 V2 FBL, Gaui X2 FBL BeastX (in process), Align Trex 450 Pro 3GX, MSH Mini Protos MSH Brain To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , MA Furion 450 w/Beam FBL Head Mini Vbar (in process), Beam E4 V2 FBL Mini Vbar, 130X, nano CP X, 300X |
Edge... Perfect fit... Flybar version on Flybarless Beam
I had Mavrik, but the root was thinner so needed shims (not supplied with the blades) Edge supplies the shims but you don't need them.
Dany Synergy E5 in the works Furion 6 Flybarless, Skookum 720 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Beam E4(v1) FBL, Skookum 540 |
#3 |
Thanks Dany, what size do you use?
#4 |
325mm.
I need to get a spare set so I might give these a try, I don't do hard 3D and they are a little less costly; Mavrikk 325mm ST Sport Flybarless
#5 |
Stock blades where 335mm and weren't that good, I replaced with some Hobbyking 335mm blades for awhile $4.I don't think the stock ones are actually fbl blades even though they come with the fbl kit.Id like to try some Maverick G5, anyone try those?
Steve Last edited by Stevemech; 07-15-2012 at 01:23 PM.. Reason: Typo |
#6 |
I had the G5s... they need shims, which I didn't have at the time, so I squeezed the grips and ended up with the tracking being a little wonky.
#7 |
How about the Align 325's? Does anyone use them? I use Align 205's on my Gaui 200 and they are great!
Mark Gaui 200 V2 FBL, Gaui X2 FBL BeastX (in process), Align Trex 450 Pro 3GX, MSH Mini Protos MSH Brain To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , MA Furion 450 w/Beam FBL Head Mini Vbar (in process), Beam E4 V2 FBL Mini Vbar, 130X, nano CP X, 300X Last edited by Carthagenj; 07-18-2012 at 09:33 PM.. Reason: typos |
#8 |
Aligns work, running with beastx, Neu motor 12 pinion 3s, it goes well but that is in the hands of a beginner, rolls & flips .
#9 |
I went with these @ only 7.99 shipped, well balanced out of the bag.
http://www.ebay.com/itm/2X-Real-Carb...ht_1771wt_1011
Beam e4 fbl v2 ar7200bx, mks ds92a+, ds520 tail, mini g2 bec, cc50 ice lite,DX7, icharger 206b, and phoenix v4. / Previous-Blade nano,450 3d, mcp x v1 and v2, msr and mcx. |
#10 |
I bought those ones in 335mm from Hobbyking for about the same price but the 335's needed tape to balance and I also noticed they don't feel the same when you give them a test bend( between pairs).Not my favorite but maybe the 325's are better!
Steve |
#11 |
I just got mine in yesterday. I went for the 335mm length. I hope they will work!
Mark
#12 |
They work good but there balance wasn't perfect. Sometimes they are sometime they aren't , but the price is right!!
Steve |
