Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 06-01-2014, 01:22 PM   #1 (permalink)
Default Msr wobble and vibrates crashing before take off
Hello, I am having trouble with my Msr it wobbles and vibrates really bad crashing before it can take off.
I have replaced almost every part expect the 5-1, and motors. Also looked around the fourm with no luck.
The wobble can be felt at low power and translates at high power to complete instability. please any suggestions?
Bladenote is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 04:19 PM   #2 (permalink)
Abble could be a cracked shaft or a bent feathering shaft. bent blades. bad blade grips. Aksi, use the red tool as the swash plate may have separated.
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 06:30 PM   #3 (permalink)
Checked all mentioned above and replaced the parts. Nothing has changed
Old 06-01-2014, 08:57 PM   #4 (permalink)
Both brash washers on the feathering pin?
Old 06-02-2014, 03:14 AM   #5 (permalink)
Not the washers. Hard 2 find. Anyway 2 tell if they are gone
Old 06-02-2014, 08:02 AM   #6 (permalink)
I bought a used MSR and had nothing but problems. I found a new "air frame" on ebay that included everything but the blades,motors, and control board. Now it fly's good.
They are a little tricky in that even if everything is trimmed correct they are hard to get off the ground.
I try to get the blades just below take off speed and them give a lot more power so it jumps off the ground. I think these are also very subject to prop wash so putting it on a table or "launching pad" helps minimize the prop wash. Don
dontrinko is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 12:38 PM   #7 (permalink)
Hey~
So i checked the brass washers are they were missing completely from the pin. Replaced the pin and added washers... the blade grips are now really tight and still pivot with a fingers touch.
Test flight was much better.. I could take off without it wobbling into the ground; however the trim is really off it flys left hard into the ground crashing. My flybar is a little tight after the repairs - i am going to losen it
I also noticed if the servo is set to max in any direction the flybar touches the blades... Im guessing this is a problem?
Cheers 4 the help
Old 06-07-2014, 07:41 AM   #8 (permalink)
Flybar can't be "tight" unless the guides are squeezing the links or the links are snapped on backwards.
Blade 200QX, Align T-Rex 450 Pro 3GX,
P-51, SU-26XP, Carbon Cub, Cessna 182,
F/A-18, Blackjack 29, Slash 4x4
hydro_pyro is offline        Reply With Quote Quick reply to this message
