Everything Else for Sale - Non Heli Related *No Commercial Ads* NO FIREARMS! |
09-25-2015, 01:55 PM | #1 (permalink) |
Honda Acura turbo kit brand new $699 or trade current model helis or vbar control
For sale $699 pick up or trade I have over $1400 into this quite possibly a bit more this is what I rember. So trades should consider that when you make an offer
B16 B18 DOHC VTEC MOTOR complete turbo kit This will fit the coupe, sedan, hatchback Honda Civic / CRX / Del Sol, Acura Integra ( must be a B series motor) This kit Includes: - T3/T4 Hybrid Turbocharger - Intercooler 27x6.5x3 (Direct Bolt-on) - 2.25" Aluminized Mandrel Bent Piping (Total of 4) - High Pressure Silicon Hose (Total of 6) - Clamps (Total of 21) - Cast Iron Turbo Manifold - 2.5" Stainless Steel Down pipe - Stainless Steel Connect Pipe - Stainless Steel Dump Pipe - Blow Off Valve - Waste gate 7 psi - Valve Set for Waste Gate - Gasket Kit for Waste Gate - Steel Braided Oil Feed Line - Oil Return Line - Oil Pan Fitting - Necessary Vacuum Tee's - Necessary Vacuum Lines - Necessary Gaskets and Bolts - Necessary Hardware TURBO SPEC: T3T4 turbo Intake: 3 inch Inlet: 2 inch Compressor trim: .50 Compressor Wheel diameter: 50.16 / 76.84 Turbine Wheel diameter: 54.06 / 65.20 Exhaust Trim: .57 Turbine flange type : T3 flange Down pipe flange type: 5 bolt standard Cooling type: oil cool only Horsepower rating: 350+ AUTOMETER Z-SERIES 20 PSI TURBO BOOST VACUUM GAUGE 2601 Auto Meter 2634 Z-Series Electric Oil Pressure Gauge 2 1/16 in. 0 - 100 psi Golden Eagle Oil Sandwich Plate With 1/4 Plug Adapter LSVTEC GVC100-14 VMS 6 VACUUM BLOCK OMNI POWER 2.5 BAR MAP SENSOR HONDA CIVIC ACURA INTEGRA Bosch saturated 440cc Honda Civic Integra Turbo D16 B16 B18 H22 Fuel Injectors OBD2 Plug & Play AEM FUEL PRESSURE REGULATOR FPR 25-300BK - Civic Integra Del Sol B16A B18C D16 Honda Prelude 1996 to 2001 OBD2A to OBD1 ECU Conversion Jumper Harness turboxs bc-sbc boost controller Walboro 255lph fuel pump All is new not all in original but new or like new conditioN |
09-25-2015, 02:00 PM | #3 (permalink) |
More pics of other items upon request
11-16-2015, 11:20 PM | #4 (permalink) |
Turbo kit ...
Would you take wheel trades plus an xbox one with ton of games I also have interior from a 96 gsr integra tan for what everreason you can't reach me here cjbailey123@gmail.com is my email
