MA Glow Miniature Aircraft Glow Helicopter Support Forum |
05-06-2013, 07:22 PM | #1 (permalink) |
Need Help Using Align Gov Sensor With Vbar
Hey Guys,
I have a fury 55 With fullsize Vbar When i bought the heli it had an align gov on it which i removed to use the vbar gov i still have the align sensor and was told the wiring is different is anyone running this setup if so can you please explain how i need to wire this. |
05-08-2013, 11:36 AM | #2 (permalink) |
Its been a while but I believe you have to swap the red and black wire at he servo plug. If youre real carful you can just lift the tabs , slide out the pins , swap and reuse the plug . No special tools needed. Any ways heres a link to some vbar gov info http://www.readyheli.com/assets/imag...patibility.pdf
Just realized that the align gov sensor comes with a JST connector so u cant reuse that with the vbar. You will have to replace with a standard female servo connector.
MSH mini-p VBar ,G380, Goblin 500, TREX 600N LE VBar, Trex 700N 91hz FB, Whiplash 105HZR VBAR, Nitro Citizen 414 Last edited by mr008; 05-22-2013 at 10:46 AM.. Reason: incorrect info |
