Old 07-20-2012, 11:46 AM   #1
tnitzani
Default What RPM set for my Trex500 CF
Hi all,
I finaly got back my new ESC from CC, I have the ICE80 HV wich got back from its upgrading at CC, after using the stock Align ESC for 3 years.
What is the recommended RPM setup when using the stock Align motor 1600kv 6pole with a 12T pinion & 162T main gear, for:
Normal Mode:
Idle1:
Idle2:
Thank you in advance and a happy weekend to you all
tnitzani is offline        Reply With Quote
Old 07-20-2012, 01:52 PM   #2
DKS_ONE
If you were gonna run governor, the 12t pinion won't likely be enough. You could run a flat 100% throttle curve on your I/U modes and that should get you just over 2600 rpm which would be good. Say Normal 0,40,80,80,80 Idle1 85,85,85,85,85 and Idle2 100,100,100,100,100? That would work
Danno
Fusion 50, 600 conversion, 600mx motor, CC 80HV ESC with cap pack, Jolly Bee canopy
UMX Carbon Cub SS
DX8
DKS_ONE is offline        Reply With Quote
