4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support |
05-07-2012, 11:57 PM | #1 (permalink) |
SKYES metal gear for v120d02s
http://www.ebay.com/itm/SKYES-Walker...#ht_2983wt_932
metal gears for the v120d02s anyone tried these?? any comments? however the slipper clutch MOD would probably be better |
05-08-2012, 01:27 AM | #2 (permalink) |
I think the slipper clutch would complement this. Might still risk main gear damage. But I think it looks promising.
05-08-2012, 03:18 AM | #3 (permalink) |
That's hard to say. I love the slipper clutch from Bob Lavinia, or however his name is spelled, and haven't had a single tail failure of any kind since installing it, although I had to mod it a bit to get it to fit right and not bind on the 'B' gear.
But, if people still end up messing up gears even with the slipper clutch, most likely the 'A' gear which mates to the main gear, trying a metal replacement might work. But then again, one might just end up having to find a metal replacement for the main gear then. The slipper clutch should stop any damaging force from getting to the rest of the heli as sort of a 'release valve' but sometimes high pressure systems have relief valves and they still blow. |
05-08-2012, 08:14 AM | #4 (permalink) |
Just ordered it. Let's see if it is better than the Wolfgear for the 4G6. I will let you know.
KR, Henk Blade MCX, FBL 4G6V-2S Xtreme, FBL 4G6V-1S Xtreme rewind, FBL 4G6S-1S Bell 222 Darthdark, FBL V120D02S |
05-10-2012, 09:27 AM | #6 (permalink) | |
The the Wolfgear, damaged was usually limited to the main / external tail gears - elminating the need to tear your heli apart to replace the incredibly annoying to replace front tail gear. |
05-10-2012, 10:28 AM | #7 (permalink) |
the 120 and 120s share the same parts in the transsmision tail right????
05-10-2012, 03:24 PM | #8 (permalink) |
NO. They are way different.
The D02S has larger gears from front to back. Much larger. Larger everything in fact. Every piece on this bird is bigger and thicker, hence the durability claim from Walkera. |
05-10-2012, 11:29 PM | #9 (permalink) |
ok thanks i toughti read from someone trying to convert his 4g6s to 12s that the only thing compatible was the tail...
05-11-2012, 01:03 AM | #10 (permalink) |
ha yes that was probably a thread that I responded to and saved him a ton of money based on my own mistakes.
05-13-2012, 11:14 AM | #11 (permalink) |
Im new here.
And i got them, setup and did like 8 flights or so. Only thing to watch is the c? Gear. It's a bit worn out because of the contact with the metal gear. Anything else you want to know? Pics or so? |
05-13-2012, 09:41 PM | #12 (permalink) |
Welcome! and thanks for your feedback and opinion! i would definitely like to see some pics if you can
SPEkTRUM DX-8 Align TRex 450 Pro V2 (BeastX, DFC, Castle Ice Lite 50, Hitec HS-5065MG, MKS DS-95i) Align TRex 250 (Spektrum AR7200BX, Scorpion 2208-3600, Hitec HS-5065MG, MKS DS-95i) Walkera WK2801-Pro, Walkera V120D02S, Walkera C05 Genius CP |
05-15-2012, 04:38 AM | #13 (permalink) | |
But you probably meant the V120D02S....
05-15-2012, 08:52 AM | #14 (permalink) |
anybody have any pictures and/or further flight reviews of these gears?
05-16-2012, 05:26 PM | #15 (permalink) |
Some facts...no pics......sorry i hope i canl do some the next days.
It seems that the metal a gear is really a bit slippy and grinds the main gear till there is no grip left. Im nor sure if i installed it right. But maybe i remove the metal a gear and just leave the metal b gear on...it won't replace the slipper clutch wich i also ordered. I already had to replace 2 main gears in 1 week. Nearly after every crash. Maybe i have to fix the gears with some glue so that they don't have that much movement on the main gear. Hope you get me right..im not a native speaker |
05-18-2012, 03:33 AM | #16 (permalink) | |
The solution for me was to grind away the upper part of the main gear, where it rests against the lower bearing. This way, the main gear is positioned slightly higher, and fully meshes with the metal front tail gear.
05-18-2012, 04:08 PM | #17 (permalink) |
True ...it is bigger i have to cut the main gear. If not i have to change the main gear nearly after 4 flights. Maybe i just install the slipper clutch and leave the plastic gear. I don't see a real benefit in these new gears. They are much more durable yes but they grind out allthe other gears......
05-19-2012, 03:20 PM | #18 (permalink) | |
05-19-2012, 08:09 PM | #19 (permalink) |
A slipper clutch is a lot less bother. Once installed, you can forget about tail gear problems without also having to worry about main gear problems as well.
Metal gears only protect against damaging themselves while using a slipper clutch removes the potential for damage itself. |
05-20-2012, 12:46 AM | #20 (permalink) | |
I think that it does not hurt to make parts of the tail drive train stronger. If anything, metal has the tendency to deform less than these plastics under stress, and will therefore allow for a smoother drive train. These gears are NOT about crash protection in general. You replace some plastic with some metal, so other parts will break instead of these gears in a crash. Actually, following this logic it means that when you have the metal gears, you should ALSO run a slutch.
