Old 07-11-2012, 12:51 AM   #61
DanXbix
Wow great news! Awesome work looks like this may just turn into another mcpx
E-Flite Blade 450x
DanXbix is offline        Reply With Quote
Old 07-11-2012, 02:52 AM   #62
ChrisG23
@coredump: you sir are a genius!
ChrisG23 is offline        Reply With Quote
Old 07-11-2012, 06:49 AM   #63
new bee
Originally Posted by coredump View Post
Update:
I flash xp12a with BLHeli 5.0 then I use the BLHeliSetup tools to select
Input Polarity to "Negative".
I knew you would figure that out
I was secretly hoping it would work
new bee is offline        Reply With Quote
Old 07-11-2012, 01:02 PM   #64
itsmillertime0
Update:
Then using the signal spot I found. The XP12A can detect the ppm
signal. When I apply the throttle, the motor actually spins. It is a
walkera 4#3b BL 1S motor. I just give it a little throttle hoping it does
not burn out.
So BLHeli with negative input signal will work on the 130x board.
itsmillertime0 is offline        Reply With Quote
Old 07-13-2012, 04:57 PM   #65
ChrisG23
Just looked at the signal point on my board. Looks a bit tougher than on the mcpx thats for sure. lol gonna need a magnifying glass and a stable hand for sure
Old 07-30-2012, 06:38 PM   #66
sonyv1
Just saw someone flying the heli with spin 8800kv and with stock esc. Is he going to burn the board, or the motor can auto draw smaller amp?
YouTube
"> YouTube
" type="application/x-shockwave-flash" width="425" height="350">
sonyv1 is offline        Reply With Quote
Old 07-30-2012, 06:45 PM   #67
sonyv1
Old 10-19-2012, 08:54 PM   #68
Harmwalker
Marking thread...
Harm
Harm
120SR - 130X - nCPX
Lovin' this hobby!
Harmwalker is offline        Reply With Quote
