Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 01-29-2012, 02:49 PM   #61 (permalink)
Originally Posted by sescot View Post
Hello at all, sorry for my english. I'm from Italy. I have a 6hv and I'm thinking for a 7HV.
My first (economic) configuration will be:
Scorpion 4035-560
Esc HW 100A HV
Bec CC Pro 6V
3 x DS610
1 x DS650
Microbeast
Turnigy 4000 6s x 2 (from my X5)
What do you think?
I love painting canopy, and I buy unpainted canopy from Fusuno, but I can't find unpainted canopy for 7hv. Someone has checked other canopy as t rex 700 on this model?
I know my crash, and I prefer an economic canopy...
Thank you!
ESC 120amp HV for this with that motor
Unpainted canopies, email sales@fusuno.com and ask for it to be left blank.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 01-29-2012, 02:57 PM   #62 (permalink)
Looks good.
I think I'll be running 4000 packs as well, trying a lighter setup.
Fusuno doesn't yet list it but surely you can get one.
Another option is from Compass, they are lighter as well.
http://www.nankinhobby.com/Compass-P...prod_6681.html
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 01-29-2012, 03:01 PM   #63 (permalink)
Can I wait for a cut off with 100A esc? Also for first flights?
Originally Posted by GimpyGolden View Post
Looks good.
I asked to fusuno but no answer, I look for nankin and shipping cost, thank you!
sescot is offline        Reply With Quote Quick reply to this message
Old 01-30-2012, 06:49 AM   #64 (permalink)
Default My 7HV setup
Compass 7HV
rewound 4035-500 HKIII
JR8717 cyclics
JR8900 rudder
Beast X FBL
Helijive 120HV
WR Super BEC
693 SAB FBL blades
KBDD 105 tail blades
Team Rotorquest/ SAB Heli Canada
mtymyk is offline        Reply With Quote Quick reply to this message
Old 01-30-2012, 07:28 AM   #65 (permalink)
Why the WR Mike?
The HJ BEC with a slave lead is as good and less clutter.
Old 01-30-2012, 08:26 PM   #66 (permalink)
You know I figured I'd use it anyhow, maybe even if it relieves the duty off the jive just a little, I do have 2 left over from previous builds... Not 100% yet, I might just sell the wr bec's instead lol...
Old 01-30-2012, 08:37 PM   #67 (permalink)
If you wanna take a load off Jive and increase safety margin run a buffer pack.
800mah AAA Eneloops seem to be most popular.
I will be running a small buffer in my 600 scale build(J80Hv) I am wrapping up(finally) and may run one in the 7Hv(HJ120Hv) as well for peace of mind.
Old 01-31-2012, 11:05 AM   #68 (permalink)
http://www.evorc.com/product.php/528...rushless-motor
http://www.evorc.com/product.php/588...hless-motor-v3
What motor for 7HV?
Thank you.
ps Kv are correct for stock pinion?
Old 01-31-2012, 01:33 PM   #69 (permalink)
Top 1 is MK2 and bottom MK3.
Be careful if you buy the top 1 [ mk2 ] the description says 8 poles when infact its 10.
I have the mk2 and entered the pole count as 8 as per the description into my gov calculations and didn't get very good results.
I've gone with a 12T for better results.
Old 02-01-2012, 07:57 AM   #70 (permalink)
Ok, never heard of this , I guess this plugs into your slave port or fbl/receiver? I normally heard of running 2s lipos for a buffer , same thing?
Old 02-01-2012, 08:03 AM   #71 (permalink)
Ya it's in the manual.
Better to use the slave port for a second lead to Rx/FBL unit to carry current.
Plug buffer into open Rx/FBL slot or a Y on any channel.
Has to be 4cell NiCd/Mh at stock BEC output. A 2S will fry your Jive.
If you want to run HV(no need) with a Jive you will have to disable the int BEC by pulling red wire on throttle lead.
Old 02-07-2012, 08:46 PM   #72 (permalink)
FBL System: Beastx
Motor: Align 700mx 530kv (until the new compass motor comes out)
Pinion: 13t
ESC: Hobbywing 120hv
RX Pack: 2500mah 2s lipo
Cyclic Servos: Align DS610...for now...
Tail Servo: Savox SB-2272SG high voltage
Main Blades: Rail 696mm
Tail Blades: Rail 106mm
Lipos: 6s 5000mah
ochants76 is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 02:31 AM   #73 (permalink)
My setup update:
Vbar 5.2 pro Mini with Skookum powerbus / 2 sat's
YGE 120HV (On Vbar Governor), idle 1 @ 1800, 2 @ 1970
Cyclics: MKS HBL 950 HV @ 2S lipo
Tail: MKS HBL 980 HV @ 2S lipo
Scorpion 4035 560kv HKIII
12t pinion
Edge 115 mm tailblades on Custom tail
Compass 700 mainblades
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRÔTOS
EricW is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 03:30 AM   #74 (permalink)
who know when?
Old 02-08-2012, 03:35 PM   #75 (permalink)
Soon...very soon,Luke said around 4-6 weeks.
rotorWIZZ is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 05:58 PM   #76 (permalink)
My revised setup
Skookum sk720 with powerbus
Futaba s-bus
YGE120hv - skookum gov
Western robotics hercules super bec @8.4v from 1 pack
Cyclics Torq BL 9180
Tail Torq BL 9188 Both @ 8.4v
Scorpion HK 4035 560kv with extended shaft
12t revco pinion
Rail 106mm tail blades
Spin 710mm main blades
Old 02-08-2012, 07:53 PM   #77 (permalink)
Fullsize Vbar w/DSMX sats
YGE 120hv - Vbar governor
X-era 4035 3y w/15t
CC Bec pro
s9451 cyclic
s9251 tail
Radix 690mm
KBDD 104mm
My first 700 size heli.....I now know why "Bigger is better" comes to mind. I love it.
tcfrum323 is offline        Reply With Quote Quick reply to this message
Old 02-10-2012, 12:47 PM   #78 (permalink)
- Compass 7HV
- 3x JR8717
- Align DS650 tail
- BeastX gyro
- Hobbywing 120HV regulator
- WR Subebec @ 6V
- Spin Blades 710mm
- Align 530KV motor @ 13T
Aint tested it yet!
Trulsen is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 03:16 PM   #79 (permalink)
Hello, I have 3 chance for my next 7HV Rudder:
Align DS620
Align DS650
JR 8455
What do you think?
Thank you!
Old 02-14-2012, 05:55 AM   #80 (permalink)
Align DS620
Align DS650
JR 8455
Thank you!
DS650.
- Futaba 14FG | TT Mini Titan V2 BeastX | Compass Warp 360BeastX | Logo 600 SX V-bar | Align Trex 700N DFC V-bar -
