Old 06-16-2014, 12:38 PM   #41 (permalink)
Originally Posted by kevinbj View Post
I'm not using Scg module.. I don't know what that is.. I jus take the card out the kosmik & insert to laptop but since update it takes forever to view log.. Please explain SCG module
Single Cell Govenor module. It basically gives the kosmik the ability to see every individual cell voltage and monitor them for any abnormalities in the battery.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 07:57 PM   #42 (permalink)
No not using that.. does it make a difference?
kevinbj is offline        Reply With Quote Quick reply to this message
Old 10-22-2014, 08:14 AM   #43 (permalink)
Anyone got this running on windows 8.1?
Been fighting this again for days... had it running on my old pc but had to get a new one.
I'm so tired of this just to get some data.. why does this has to be so difficult?
We pay big amounts on our esc so why not provide a simple and clean program..
What a frustration this is.
Minicopter Diabolo x2//Minicopter Diabolo Black Edition//Gaui X7F//Gaui X7.
www.rchelionline.com
bullet3030 is offline        Reply With Quote Quick reply to this message
Old 11-16-2014, 11:49 AM   #44 (permalink)
Is there an explanation of what each field in the log means?
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x.
jrwalte is offline        Reply With Quote Quick reply to this message
Old 01-12-2015, 08:13 PM   #45 (permalink)
So I finally loaded log view suite and was able to import files however something is wrong. My rpm's are up around 130, 000. Followed the vids but the new suite is different, more user friendly for us dummies. Is there somewhere to load motor gearing parameters?
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 01-12-2015, 08:39 PM   #46 (permalink)
I know there is a field in the kosmik where you set gear ratio and pole count so it records rpm.
Old 01-13-2015, 05:22 AM   #47 (permalink)
Ok so where is it
Diabolo S #6
Diabolo
TDR
N7
Old 01-13-2015, 05:49 AM   #48 (permalink)
With bluetooth it's 3rd and 4th option under motor tab
Old 01-13-2015, 06:07 AM   #49 (permalink)
I was referencing the log view, doesnt the kosmik work in sinc with pyro motors?
Diabolo S #6
Diabolo
TDR
N7
Old 01-13-2015, 06:25 AM   #50 (permalink)
Log view is probably expecting the rpm signal to be true and not motor rpm since you set it in kosmik. Log view is very versatile though. I'm sure you can create a new field to calculate from motor rpm. I don't know how.
Old 01-13-2015, 06:40 AM   #51 (permalink)
If you go into the .ini generator at Heliporn you can set the gear ratio and end up with motor and HS. Alternatively you can open the ini with Notepad or similar and edit the gear ratio in there.
http://www.heliporn.at/kosmik-ini-generator/
John
Old 01-13-2015, 11:51 AM   #52 (permalink)
Logview (v2) expects OpenFormat, 1..n channels (here one) and 1..n data fields per channel.
LV can process the data of each field individually.
It is required that a record contains exactly the number of fields which is defined to LV by the INI file (device description, record format).
It does not work to double a data field, one in, two out (view), the 2nd with a different data interpretation. That's why for example JLog with a Castle ESC sends temperatures twice to have the ability to interpret (process) a temperature as Celsius AND Fahrenheit without the need for a 2nd .ini (one for Celsius, another one for Fahrenheit).
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 01-13-2015, 03:56 PM   #53 (permalink)
Where in the notepad would I change gear ratio since I already have that but no ratio is visible, and I failed german
Diabolo S #6
Diabolo
TDR
N7
Old 01-13-2015, 03:58 PM   #54 (permalink)
http://j-log.eu/jlog2-en/faq/kosmik-and-logview
Tom (j-log.eu)
Old 01-13-2015, 04:14 PM   #55 (permalink)
Tom thanks I was looking for that.
Hopefully I can get it all to come together, technology not my forte
Also going to try johns previous link
Diabolo S #6
Diabolo
TDR
N7
Old 01-13-2015, 04:30 PM   #56 (permalink)
KOSMIK_master.ini
## <--- modify here individually (hier individuelle Änderungen)
## RPM
Messgröße1=RPM
Einheit1=RPM
Symbol1=RPM
Faktor1=1.0
## above (oben): motor rpm 2-pole normalized (2-Pole-normalisiert)
## alternatively (alternativ): rpm motor: 2/pole-number (2/Polanzahl)
## --- example (Beispiel): /5 for a 10-pole (/5 für einen 10-Poler)
## Faktor1=0.2
## alternatively (alternativ): headspeed (Rotordrehzahl): /pole-number*gear ratio
## --- example: /5 /9.7 for a 10-pole in a TDR 1:9.7
## Faktor1=0.0206185567010309
OffsetWert1=0.0
OffsetSumme1=0.0
KOSMIK records (default) 2-pole-normalized.
Divide by half the pole number. --> real motor speed
On top multiply by the ratio: example: pinion==17, main gear==218. reduction is 17/218=0.0779816513761468 --> rotor speed
--- in our example -------------------
KOSMIK (2-pole) to rotor: KOSMIKrpm * 0.0779816513761468 / 5 = KOSMIKrpm * 0.0155963302752294 = rotor speed
But it is much easier to use Stephan's INI generator.
Just fill out the form, download your ini file and copy em to %appdata%\logview\geraete\openformat.
Now select your device in LogView.
Tom (j-log.eu)
Old 01-13-2015, 04:53 PM   #57 (permalink)
Tom thanks agian you show your extreme knowledge and willing to help in this area but WAY beyond my expertise, are you planning a holiday to NYC in the coming weeks? You can stay at my house and I will let you drive my german car whilst here loading the data. Lol
Lets talk about building a high rise in NYC
Rich
Diabolo S #6
Diabolo
TDR
N7
Old 01-13-2015, 04:58 PM   #58 (permalink)
crash, regarding your question:
I just filled the form according to my example, 10-pole, pinion=17T, gear=218T. The generator always assumes a 1-stage-gear, so pinion/maingear.
Tom (j-log.eu)
Old 01-13-2015, 05:03 PM   #59 (permalink)
(If you visit me you can drive my American car, still have the Corvette C5 (since '99)).
Look if my last "less-scientific" reply fits your need.
Tom (j-log.eu)
Old 01-13-2015, 05:13 PM   #60 (permalink)
Perfect and I'm on my way; in need of a holiday. You picking me up or sending a car
On another note flying multiple kosmiks how do I seperate kosmiks in LV
Diabolo S #6
Diabolo
TDR
N7
