Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 10-09-2016, 06:39 PM   #1 (permalink)
Default torq bl 9088 [ wag]
anyone using this tail servo on 6hvult ? i have a small tail wag at hover, tried moving all gains / rates [skookum] not much diff . tail gain @ 25 , 10 points higher or lower makes it a bit worse. Any ideas , diff servo maybe /
thanks ,
mrultralite is offline        Reply With Quote Quick reply to this message
Old 10-11-2016, 01:33 PM   #2 (permalink)
I am using the JR 8900G on my 6HV-U.
No issues, no wag.
How long is the output arm on your tail servo?
How does the present arm length line up with the FBL unit programming?
Does the tail pitch change assembly work perfectly smoothly on the bench, with the pushrod disconnected at the servo and while pulling outward on the tail blade grips (away from the hub) and twisting/feathering them?
Have you checked to see if the thrust bearings are lubricated and oriented correctly in the tail blade grips?
Which tail blades are you using?
Sorry for all of the questions, sir.
Old 10-11-2016, 01:48 PM   #3 (permalink)
thanks Ah C ,,trusting thats the same servo , mech is fine i re-did the tail set up , that may fix [ set @ 85 L,R ] , [ using a goblin tail and kbdd blades by the way]
Its just i was reading on the skookum wiki that persistant tail wag might be an inadequate servo
Old 10-11-2016, 02:01 PM   #4 (permalink)
That particular servo isn't inadequate unless it's going bad. Which could be the case since it has been out of production for a few years now. Only way to really tell would be to swap out servos if you are sure it's not mechanical.
I have one of those Torq 9088's and have used it on a few different helis, never had an issue with it.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 10-11-2016, 03:19 PM   #5 (permalink)
Thanks flint,
Old 10-12-2016, 01:03 AM   #6 (permalink)
Wasn't the setup , so back to gains start stop are @ 30/35 +\- 5 collective mix 25 control rate 480 ,
Any extremes I could try ?
But I won't bug you guys more about another crazy tail wag. Problly get it sorted.
Old 10-12-2016, 10:38 AM   #7 (permalink)
You are not bothering us at all, sir.
Tail Wag appears to be the number one problem, across all brands and models of helicopters, for years.
We want to help, if at all possible!
Old 10-12-2016, 03:30 PM   #8 (permalink)
start stop up to 50's , teeny tiny bit of stiffness in grip ball link , anyway seems fixed
Old 10-12-2016, 04:07 PM   #9 (permalink)
I have had to ream the tail spider ball links on everything I own. Even a little drag can cause issues.
