Old 04-22-2012, 05:03 PM   #1 (permalink)
Default Microheli or RKH Rotor Hub come with Feathering Spindle??
Does anyone know if the MH or RKH Rotor Hub comes with the Feathering Spindle, bearings and hardware??
mammothtarm is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 05:09 PM   #2 (permalink)
No, just the hub and Jesus screw. You'll need the OEM dampners, spindle shaft etc.
The blade grips do not come with a spindle shaft either (microheli, don't know about Rakon) but does come with the bearings pre installed.
Sent from my PG86100 using Tapatalk 2
Blade 130X - Stock
mCPx v1 Brushless Stretch (125mm) - WK10A - 11000kv Inrunner - 550 mah - Full CNC Upgrades
Retired Helis - Outrage 550, Trex 500, Logo 400, Others
poor_red_neck is offline        Reply With Quote Quick reply to this message
Old 04-23-2012, 12:42 AM   #3 (permalink)
Ok thanks. I couldn't get my stock spindle out and in trying to do so, I ended up stripping the Phillip screw. It's really dumb how blade made their spindle.
Old 04-23-2012, 12:45 AM   #4 (permalink)
Its a really small screw, don't over tighten it and make sure to use some blue loctite
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote Quick reply to this message
Old 04-30-2012, 02:34 PM   #5 (permalink)
I am putting together my Rakon rotor hub and blade grips, apparently the screw for the spindle is not magnetic, I even opened another new spindle to see if the srew was difff, my screwdriver can lift almost any screw, but wont touch this thing, making it extremely difficult to get the screw into the spindle shaft, dont know what im going to do, may give up.
penskyc is offline        Reply With Quote Quick reply to this message
Old 04-30-2012, 03:08 PM   #6 (permalink)
put the shaft in one blade grip and then put it through the rotor head and put on the spacer. Drop the Philips screw into the bearing of the remaining grip then hold the heli so that the shaft is pointing up and put the grip onto the shaft and tighten the screw.
Easy as pie!
tbullard is offline        Reply With Quote Quick reply to this message
Old 04-30-2012, 03:46 PM   #7 (permalink)
put a tiny drop of glue/ca/silicone/loctite/peanut butter (creamy) on the end of your screwdriver. Now the screw wont fall off your screw driver!
branmuffin is offline        Reply With Quote Quick reply to this message
Old 04-30-2012, 04:07 PM   #8 (permalink)
Rakon hubs don't even come with a screw. You have to use the stock screw and the machining of the hub leaves alot to be desired!
I'm sticking with MH! At least it comes with the proper screw to fit the hub.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 04-30-2012, 04:25 PM   #9 (permalink)
Easy as pie!
got it! thanks a bunch! I first put a diff screw in, spooled up, and the grip flew right off!
