SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support |
09-26-2011, 09:36 PM | #1 (permalink) |
Goblin Shopping List
I'm defiantly going to be pressing the buy now button on a Goblin 700 when they are released and have started shopping for electronics.
Here's what I have so far: Full size V-Bar 5 Pro & BeastX (will try V-Bar first) Scorpion 4525 with Hyperion phase sensor to plug into V-Bar Hawk 120 ESC Futaba HV S.Bus receiver Here's what I think I'll buy: Futaba BLS255HV for cyclic Futaba BLS256HV for tail 2S LiPo direct for receiver, gyro and servos Hyperion 12S 45C stick pack or TP 5000 65C 6S Anyone else have any times in mind or suggestions? I have ultra sticker shock on battery prices - very open to suggestion here. |
09-29-2011, 06:19 PM | #2 (permalink) |
Sounds like a killer setup!!!
09-30-2011, 11:58 PM | #3 (permalink) |
I think I have changed my mind on the hump pack. I'm going to run a separate BEC instead off the main packs, probably the new Gryphon Quasar or the CC BEC Pro.
10-01-2011, 12:59 AM | #4 (permalink) |
Either use the gryphom or the WR BEC, the CC BEC you will regret, as they fry all your electronics quite often
10-01-2011, 01:43 AM | #5 (permalink) |
Sounds familiar
I checked out the WR BEC - looks like a good unit. Might need to change the V-Bar to a mini one as I can't see any room to put the full size sensor. |
10-02-2011, 11:40 PM | #6 (permalink) |
For me I shale get the goblin 770 in march figured they will have all the 700 bugs worked out then
YGE hv 160 esc(14s)( phase sensor built in) Wr Bec (14s)(8.2v out) 7s 65c 4000mAh TP Packs Sk 720 + gov mode ( like the v bar but think I am going back sk) Hitec servos maybe their BLS ones or the current ones I have(Hitec 7940th). Custom wound 5035 for the kv needed for 14s Man I love SAB blades.
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c |
10-03-2011, 12:15 AM | #7 (permalink) |
Why u going back to sk? Is their elec gov support?
10-03-2011, 12:26 AM | #8 (permalink) |
their logging is better, the gove seems to be all right from reviews, flys just as good or it did with v2 when I had it..... little harder to tune tho to get just perfect.
idk tho but their new v3 FW really has my attention.
10-03-2011, 02:09 AM | #9 (permalink) | |
Sab for his models currently has these settings: Goblin 700 Blade 700[mm] HS 2100 rpm Motor Scorpion HK 4525-520 Ratio 10.7 Kontronik Jive 120HV, bec interno 6V 12S-5200 38C Giga power 3x JR8717 1x BLS251 Vstabi 5.1 Goblin 600 Blade 600[mm] HS 2120rpm Motor Scorpion HK 4025-630 Ratio 10.7 Kontronik Jive 80HV, bec interno 6V 10S-5200 38C Giga power 3x JR8717 1x BLS251 Vstabi 5.1 Greetings from Italy |
10-10-2011, 11:58 AM | #10 (permalink) |
My configuration...
Goblin 700 Kontronik HeliJive PowerCroco 4535 Mikado VBar Futaba BLS157 + BLS256 Western Robotics SuperBEC This configuration already reached 11,5KW peaks in the TDR I had, we'll see how the Goblin performs. Keep it coming SAB -Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE |
10-10-2011, 12:32 PM | #11 (permalink) |
Got this waiting!
Kontronik 120HV BLS451 and 251 tail 4525 LE Scorpy Mikado VBar Voltz 5100 65C
-Goblin 700: Crashed but re-building, still needing electronics -Goblin 630: CC Ice 120HV, vBar |
10-21-2011, 03:15 PM | #12 (permalink) |
As for myself it will (would) be
scorpion 4530LE Hitec/neu brushless servo spartan FBL kontronik kosmic or yge 160 tp 65C 12S |
10-22-2011, 04:42 AM | #13 (permalink) |
Using a separate battery for servos or straight off the flight pack?
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once. Sponsored by : KONTRONIK, OPTIPOWER, PRC, CANOMOD |
10-22-2011, 06:59 AM | #14 (permalink) |
I'm not really sure right now... basically as written I already have the WR SuperBEC for up to 14s and a custom BEC for up to 16s is coming until I get a goblin. Maybe with a buffer pack as backup. But it really depends on how much cells I'll use and weight... I'll try to stay as light as possible.
-Klaus
10-22-2011, 10:57 PM | #15 (permalink) |
Xera 4530 Ltd
BlS-256 on Tail VBar Full Size ESC - Jive 120V or YGE w VBar Gov - need to see size for electronics BEC - If not Vbar WR Super or will look at Gryphon, not impressed with WR Super Cyclic Servos- I have BLS-451 sitting here but I think on Direct to swash I need to look at HIGH Torque. Maybe 8917HV's they have tons of torque or even 8717's with Jive BEC. I have BLS-451 but do not think enough torque for this setup
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... Last edited by Mystic3D; 10-23-2011 at 09:04 AM.. |
10-24-2011, 09:14 AM | #16 (permalink) |
Order in but I still need to decide on most of my setup.
Vbar or Skookum (I have both in heli's now) Hawk 120A - ESC gov Outrage or MKS servos Motor ??? 12s BEC or LiFe direct or 2s LiPo regulated or HV At least I have some time to make up my mind on configuration before they ship. //Dennis
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades |
10-24-2011, 03:50 PM | #17 (permalink) |
Nice one Dennis, good to hear about another Goblin coming to Melbourne!
I'm planning on running the Hawk, and SAB have confirmed its large footprint will fit into the frame. I'm also undecided on how to power the electronics. I'll be running HV servos and I have a Gryphon HV regulator ready to go but I wonder if direct 2S LiPo would be a better option. I guess using a Kontronic ESC with a BEC would remove this question. Why don't other HV ESCs have a built in BEC? |
10-24-2011, 09:12 PM | #18 (permalink) |
Here's my set up :
kontronics black heli jive kontronics black 700/52 tp 65c 5000mah 12s sticks jr hv 8717's cyclic torx hv tail servo will more than likely run the entire set up on 6 volts. will also try a 2 cell lion pack if necessary. full size vbar All the above in stock. just waiting on release of the heli. d |
10-24-2011, 09:13 PM | #19 (permalink) |
Yep, good to see the Hawk will fit, I will put the CC120HV ICE2 back on the Logo and put the Hawk on the Goblin. I think for powering the avionics I need to make my decission on servos first and that will narrow down how to power them. The other question will be if there is a good spot to fit an extra RX pack in the heli compared to putting a 12S BEC somewhere.
On your earlier post, I guess you saw where to mount the full size Vbar sensor from the photos of Tareq's heli, looks like a good place to put it. //Dennis.
10-24-2011, 10:07 PM | #20 (permalink) |
Yeah, gyro sensor mount pad is cool. I will find a use for it even if I decide to use my spare BeastX.
I am going to use HV servos so I think the BEC will be the best option as a hump pack of a good size it quite large and I'm not sure there will be enough room. There are picks of what looks to be a hump pack taped to the top of the boom where it meets the frame...
SAB Goblin 500 SAB Goblin 700 Jeti DS-16 |
