Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 11-22-2011, 12:19 PM   #821 (permalink)
Looks good.
I would turn the tail servo around so it doesnt get swiped by the blades.
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 04:36 PM   #822 (permalink)
Thanks, first real heli so I'm learning as I go with a lot of helifreak help. I will mount the servo on the left with the horn facing right, correct?
TT e325, mcpx, 250 build in progress
scooterfuzz is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 11:20 PM   #823 (permalink)
Correct. Took me two smashed servos to learn this
Nick
Old 11-27-2011, 07:34 AM   #824 (permalink)
Originally Posted by nickyd View Post
Not really. Were at the bottom of lake Luzern. Pretty much central Switzerland.
I was in Luzern in June this year. Truly nice place where to be. Also Alps as photo background with MT in the front
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote Quick reply to this message
Old 12-03-2011, 06:53 AM   #825 (permalink)
Default Canomod blinker canopy
Got this canopy more for show than go, doubt It will see much airtime.
Trex 250se 3gx
Trex 500 Beastx, Ice 75 9650's & 9257 500mx, Edge main & Kbdd tail blades
Mini Titan e325 Beastx Airtronics 94809 cyclic, 9257 tail, Ice lite 50/scorp 2221-8 Edge mains, Kbdd tail blades
Jr Vibe 50, Beastx, all Futaba servos OS55hz, Hatori sab 50, Radix
Punkin71 is offline        Reply With Quote Quick reply to this message
Old 12-03-2011, 10:42 AM   #826 (permalink)
Nice looking canopy! May I ask where you got it?
Sweet looking 500 too ...
-John
FR4-Pilot is offline        Reply With Quote Quick reply to this message
Old 12-03-2011, 11:23 AM   #827 (permalink)
Canomod blinker from helidirect, it was the closest match I could find to the fusuno on the 500. It cost more than I wanted to pay for a 450 size canopy but I just had to have it!
Trex 250se 3gx
Old 12-11-2011, 07:00 AM   #828 (permalink)
Here`s my two new MT`s. Both are swinging 350 blades.
ID:	272719   Click image for larger version
ifheli is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 01:00 PM   #829 (permalink)
Tell us about your set up. What did you do to swing 350 blades and what battery set up?
helicopter1 is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 01:53 PM   #830 (permalink)
Size of your tail boom (or is it Protoses), belt you used, which blades...
clicky is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 02:07 PM   #831 (permalink)
Heli # 1.......CNC helicopter frames, HK2221-2010, CC esc, BeastX, Rave 450 FBL head, Rave boom sleeved w/ TT boom, and a 453 belt I bought along time ago. The weight is about 980 grams
Heli # 2.... Stock plastic frames, old Outrage 1700KV motor, CC esc, CX-3X1000, modified stock head for FBL, Rave boom also sleeved w/ TT boom, & 453 belt. The weight is about 948 grams.
The Thunder Tiger 448 belt used w/ the scale fuselages would work also for stretching helis. Both are running 5065`s on cyclics, 5084`s on tail, & 6S batteries. I decided to use the Rave booms but they are 13mm so I sleeved them w/ Thunder Tiger booms to fit tailcase & boom mounts.To do this I wrap one layer of tape on rave boom as needed and slit the cut down pieces of TT booms so they would clamp onto rave boom as you tighten the screws in tailcase and boom mounts. If and when I have to replace a boom, I will use a mini protos boom to sleeve the rave booms because they fit tighter on the rave booms. I know I could have used carbon booms here but most are pultruded w/ thick walls.
The tail ratio has been changed on both also. The blades for now are rotor techs
Old 12-22-2011, 12:57 PM   #832 (permalink)
Here's my MT v1.
Stock motor and ESC; Turnigy NanoTech 2200mAh Li-Po; JR DS285's on cyclic, DS3400 on the tail; Logictech 2100 gyro; KBDD paddles and TR blades, main blades are generic SAB look-a-likes from e-Bay; Pro Line "assault" canopy.
Upgraded to CNCheli.com upper and lower mixing arms on the stock plastic head.
Jon
Chaos 600E
Jonathan Ott is offline        Reply With Quote Quick reply to this message
Old 01-18-2012, 06:43 AM   #833 (permalink)
After office flights
ogosvil is offline        Reply With Quote Quick reply to this message
Old 03-03-2012, 10:25 PM   #834 (permalink)
Default FRP canopy Red
I really like this canopy. My mini titan looks very similiar to my Titan SE.
chadk is offline        Reply With Quote Quick reply to this message
Old 03-03-2012, 10:59 PM   #835 (permalink)
Default mini upgrades, lights, carbon fiber, canopy, and landing gear.
Im happy with all my upgrades or changers i have done to my mini titan this week. (thanks to uncle sam ). I put those Gaui landing gear on it. This was a huge improvment along with a new FRP canopy from TT. This canopy is awsome. It looks so much better then the stock canopy. I upgraded the tail to all allow. Again another huge improvement over the plastic tail. I installed Curtos Youngblood carbon fiber tail and main rotar blades. I also did some preventative maintenance on the heli such as new belt, some new bearings and lube throughtout. Oh, I forgot about the Flight System LED kit. The lights look cool! They actual blink (or are steady depending on which one/location). Here are some pictures. sorry some are a little blurry.
ID:	295679   Click image for larger version
ID:	295685   Click image for larger version
ID:	295686   Click image for larger version
Old 03-03-2012, 11:40 PM   #836 (permalink)
Nice canopy Fredrik.
I discovered that mounting your tail servo the other way around saves it from blade strike in a crash.
Happy flying
Nick
Nick
Old 04-04-2012, 01:10 PM   #837 (permalink)
Fresh after a rebuild. Going through some of the other pics I see my Canopy come up on a few others as well. They look great in the air, good visibility. I wouldn't normally splurge but it had a hairline scratch on the bottom and sold as 'cracked' for almost half price and the little thing has been good to me so a little TLC.
The knack of flying lies in learning to throw yourself at the ground, and miss. Clearly, it is this second part, the missing, that presents the difficulties.
Team Compass Pilot
Scott Bowersox is offline        Reply With Quote Quick reply to this message
Old 04-04-2012, 08:45 PM   #838 (permalink)
same remark as above concerning tail servo orientation/location: change it or you'll be sorry at some point
fakyrr is offline        Reply With Quote Quick reply to this message
Old 04-05-2012, 02:14 AM   #839 (permalink)
You mean gyro? And yes - gyro at the top + flybar = broken gyro case in crash. I was lucky as gyro pad gave up first and just cleanly peeled off. Since then my gyro was in the frame.
Now - it is again at the top: but I have removed flybar and gyro is in nice metal case with orange label
Old 04-05-2012, 03:59 AM   #840 (permalink)
No I really meant the tail servo, mounting it with the case protruding from the left of the tail instead of the right as in the picture.
Tags
mini titan 325
