Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 02-22-2013, 01:08 PM   #21 (permalink)
Has any one run the Hatori yet? Curious to see how those orings hold up my nitro one always leaked and blew the silicone coupler to. I have the old one on my spectra g with the stailless adapter. If i ever crash my spectra on the exaust i will need a new one and hate to spend a lot of money on some thing that leaks
spacecowboyz is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 02:55 AM   #22 (permalink)
Default Introduction - Hatori SB-12R Muffler - Flex mount
I have had maybe 20 flights on it and its holding up well so far. No problems with leaks or bolts coming loose.
Bald-ie is offline        Reply With Quote Quick reply to this message
Old 02-24-2013, 09:21 PM   #23 (permalink)
Smile
Sweet that's what I like to here
Old 03-27-2013, 09:00 PM   #24 (permalink)
I can now confirm that this new Hatori weighs 8.8oz
from my original muffler comparison HERE thats within 1/2oz of the lightest exhaust system I've seen
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 04-03-2013, 07:35 AM   #25 (permalink)
Someone needs to make a performance comparison with the Quickdraw and Hatori. And maybe the new BH pipe.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 04-03-2013, 10:07 AM   #26 (permalink)
there will be significant differences between any muffler and the tuned pipes.
I had hoped to be able to do some relative comparisons via an engine dyno but its going to be a while before that can happen.
Carey Shurley
Old 04-15-2013, 01:09 AM   #27 (permalink)
Just wondering, have you any sort of sealer or gasket between the muffler and the crankcase?
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 ——
malc1 is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 06:06 AM   #28 (permalink)
I always use the stock Zenoah gasket, it has material on it that sticks when it gets hot..........and replace it if I remove the muffler
Carey Shurley
Old 04-15-2013, 06:09 AM   #29 (permalink)
Thanks Carey, Richard's going to sort one out for me BTW.
Old 04-15-2013, 07:16 AM   #30 (permalink)
Nope no sealer / gasket.
I polished both the exhaust flanges with fine wet/dry on a piece of flat steel (Small surface plate) until there were no high/ low spots and it is leak free.
The only thing that I have always done with any exhaust on a heli, Is to pre heat the bolts and fit them whilst hot, then dont over tighten them, just a firm nip up.
Never had an exhaust come loose /leak yet
Old 05-02-2013, 01:00 AM   #31 (permalink)
Had mine arrive from the US yesterday and have just installed it with a stock exhaust gasket.
Will hopefully try it out later on.
A much better system of mounting I think as long as the heat doesn't destroy the o rings and mounting grommets.
Old 05-11-2013, 07:32 PM   #32 (permalink)
I ran into someone flying one of these mufflers on a Trex 700 converted to gas with a VX270TT engine. I have to say it was a very quiet muffler. Much quieter then the Century V2 and the RJX that I has on my Whiplash gasser.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 08:27 PM   #33 (permalink)
the Hatori's are super quiet and at least on the dyno tests I've seen allow the motors to make the most power they can with a muffler system
Carey Shurley
Old 03-11-2014, 08:15 AM   #34 (permalink)
I see Hatori USA has the SB-12R for 225.00 and HeliProz is calling it the SB-12R-3. How's it holding up? Is the new mount doing better than the original 2 bolt type.
TREX 600 Gasser (690 Mains, 700TT boom) - T-Rex 450 SE V2 - OpenPilot Revo - CC3D - Atom - Blade CPP (06' model and still going!) - Blade mCP x (Wha hooo) - JR9503, SPEKTRUM DX8, Sullivan Dynatron/Finer Edge
AMA#621236 & IRCHA#4196
Rick~K is offline        Reply With Quote Quick reply to this message
Old 03-15-2014, 11:58 AM   #35 (permalink)
Default Hatori SB-12R
I've been using this pipe on my TRM G260PUH for the past 6months, started off reasonably quiet with a nice exhaust signature. Progressively, its gotten worse...its loud as heck now...I suspect the 2 high temp O rings are wearing out from the heat and need replacement between the header and the steel plate. Anybody know what part numbers I need and where to order from? Thanks
Empire Hobby - GAUI USA Field Rep
Team Pilot - HobbyWing Products
Experience RC - Halo Blades Field Rep
Team Pilot - PM HobbyCraft
Gauiguy88 is offline        Reply With Quote Quick reply to this message
Old 03-15-2014, 06:35 PM   #36 (permalink)
yes the part numbers are:
#153 Fluorine O-Rings
#185 Silicon grommets
you can get them from hatoriusa.com
Carey Shurley
Old 03-26-2014, 03:25 AM   #37 (permalink)
IMO is an absurd a muffler costs more than the engine itself. I would never pay it. Somethings people simply shouldn't support buying it.
Don't do like me. Do not live in a s*hole
Calil is offline        Reply With Quote Quick reply to this message
Old 05-20-2014, 08:55 AM   #38 (permalink)
Update on this product. I tried to order one direct from Hatori, and was told this product has been discontinued due to problems.
They now have a redesigned SB-12R been made stronger in the area where some had cracked in the past.
The SB-12R mounts like the RJX where you have a flange that bolts to the engine and the muffler bolts to that.
When bought direct from Hatori I paid about $235 shipped for the muffler.
