Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 10-18-2011, 10:42 PM   #1 (permalink)
Default Goblin helicopters technical support thread
We will answer technical support questions in this thread.
Please post technical questions only.
Goblin Helicopter
www.goblin-helicopter.com
goblinhelicopter is offline        Reply With Quote Quick reply to this message
Old 10-18-2011, 11:16 PM   #2 (permalink)
Hello, i have preordered your lovely helicopter.
Myself and others are concerned about the stiff linkage you use from main grip to swash, is there any wear issues on this? Can you explain please?
Also we hope to have online manual to read, when will it be online?
How many KW is the drive system for? Can it cope with 4535LE scorpion motor and vbar gov or jive gov being so aggressive in the long term?
A lot of other helis cannot handle power, bearings get rough, gears wear or strip, frames flex.
Lastly not really techincal but what style/color is the heli we will receive from helidirect?
helicraze is offline        Reply With Quote Quick reply to this message
Old 10-18-2011, 11:45 PM   #3 (permalink)
Welcome Goblin Helicopter!
I too have pre-ordered and would like to know about when a manual will be available.
Also wondering about where a full size VBar sensor would be installed.
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 01:08 AM   #4 (permalink)
Great questions both of you! The manual they have stated will be about a month out. Parts list and prices will be about 2 weeks.
Nikon D4/Sony Fs700/Cinestar 8/8FG super/Dx8
Twister773 is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 01:10 PM   #5 (permalink)
Hello SAB when you say high torque servos what spec are you talking about a minimum of perhaps10kg and up? Please advise
Magneto is online now        Reply With Quote Quick reply to this message
Old 10-19-2011, 01:26 PM   #6 (permalink)
Wanted to know the RTF weight and weight without batteries?
Sorry if this question has already been posted I haven't seen it yet....
Thanks in advance
Mikado - TP - Egodrift - TORQ - RotorTech
haq0901 is online now        Reply With Quote Quick reply to this message
Old 10-19-2011, 02:15 PM   #7 (permalink)
Hi,
The system of damping of the Goblin is designed for 3D flight high headspeed and simultaneously to be effective at low headspeed.
This system is characterized by a content movement bound by HUB.
This movement is controlled through hard damber with low initial preload.
The linkage system, theoretically rigid in reality, for the elasticity of the uniball and linkage, is not opposed significantly to the movement.
As for the motor we currently have hundreds of flight with Scorpion Hk4525. With this motor we never had any breaks and problems on the transmission.
We did tests with the motor POWERCROCO 4530 in speed tests.
Even in this case we had no problems.
We flew with many types of servos, JR, Futaba, Outrage, Align. The Goblin flies like all other helicopters.
The high performance servos need if you fly high performance.
The weight of the model with HK4525, Jive 120HV, 4 servos, canopy Fusuno and blades is 3290 grams.
SAB Heli Division.
Old 10-19-2011, 04:22 PM   #8 (permalink)
It is great to have someone from goblin on the forums
Old 10-19-2011, 09:43 PM   #9 (permalink)
Hi,
color and style of the production model will be very similar to the model of Tareq.
SAB Heli Division
Old 10-19-2011, 11:46 PM   #10 (permalink)
Excellent!!! I really like Tareqs colours...
Great work
Bring on Dec 19th!
Henseleit TDR Xera Vbar gov, MA whiplash YS120 VBar gov, Rex700N VBar gov, Stretch 450 Pro 6s Vbar , FPV Quad, Planks a plenty, Turbine Eurosport.
Nutbag is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 11:52 PM   #11 (permalink)
Will there be a nitro version of this heli in the future?
low.level.3d is offline        Reply With Quote Quick reply to this message
Old 10-20-2011, 12:00 AM   #12 (permalink)
for now this project is not expected.
Old 10-20-2011, 03:30 AM   #13 (permalink)
Mr Goblin, what is the maximum pitch the head can support without binding?
Do you have V-Bar profiles for Luca that you can share?
Old 10-20-2011, 03:48 AM   #14 (permalink)
Welcome Goblin Helicopters.
What is the lowest RPM you can run for smooth 3D. Is the heli stable at this headspeed ie. no wobble in hover?
Can you give us a rough estimate on what it would cost to replace the boom?
G
iPhone & Tapatalk
TDR3DRigid Mikado V-Bar 5.1
Futaba8FG S-Bus
g-bru is offline        Reply With Quote Quick reply to this message
Old 10-20-2011, 06:07 AM   #15 (permalink)
Another question
How wide is the area where the ESC is mounted? I would like to know if there's room for a Hawk 120 HV ESC - http://arkrc.com.au/products/SJ%252d...L-LIPO%29.html
This is quite a big ESC at 73.4 x 56.2 x 31
In comparison the Jive 120 is 62 x 32 x 21
Old 10-20-2011, 10:50 PM   #16 (permalink)
Hi guys,
The standard pitch without modification is + / - 16 °
The configuration file Vbar will be released in mid-November.
We have done tests at 1300 rpm and no oscillation.
The boom complete and painted will be around 70 USD
The area for ESC, is defined by an aluminum base that can act as a heat sink.
The size is about 58 x 100 x 35. Is not 100% rectangular. Attack pictures from the phone.
the ESC you have indicated is OK.
by the end of November will be released so many video assembly with lots of useful information.
Goblin Helicopters.
Name:	ESC Goblin.jpg
ID:	261613   Click image for larger version
Name:	ESC Gobli 01.jpg
Old 10-21-2011, 12:27 AM   #17 (permalink)
Many thanks, my shopping list is now complete.
Old 10-21-2011, 02:25 PM   #18 (permalink)
Care to share your shopping list? Xera or scorpion?
Old 10-21-2011, 04:11 PM   #19 (permalink)
Default Question for "goblinhelicopter"
Hello!
From the pictures and schematics posted so far, it appears as though there is no counter-bearing. Is that the case? If there really isn't any, how long are the motor bearings expected to last, like in the 4525LE? Thanks.
Cheers,
Rok
Impunitus is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 04:30 PM   #20 (permalink)
Hello,
what should be long the motor shaft?. Ex.: HK4525-520 the shaft il long 37,5 mm - HK5025-440 the shaft is long 32,8 mm. Pinion fix well for both motors?
Kind regards
Tb77
Tuonoblu77 is offline        Reply With Quote Quick reply to this message
