Atom 500 Compass Atom 500 Model Helicopter Discussion |
09-23-2014, 02:09 PM | #1 (permalink) |
Pick up an atom, couple questions.
I'm still working on inverted orientation, backwards circles, hurricanes, etc so I like longer flight time and don't really need crazy head speed.
1) Best batteries? Looking at the glacier 3000mah - 30c, can you go 3300mah? 2) BD3sx fitment? I am looking to run the 3sx I was poking around to look for some pictures and it looks like it may not fit on the gyro tray? Anybody have any insight to this? 3) Where does the receiver go? Looking at an AR7000 or ar8000. I see some mount it on the opposite side of the ESC. I also see some mount it inside the frame. 4) ESC, it comes with the stock hobbywing ESC. Is the gov any good? How good is the BEC on this thing? 5) Manual, the one I DL from Compass still has a flybar? Is there a newer version for the FBL head? 6) Dampers, should I just go with the KBDD lime, like I said I am not going for crazy HS. I've read that the stock seem to wear out fast. thanks!
Mcpx Dbl Brushless | 1̶3̶0̶X̶ | 180CFX | Warp 360 | Atom 500 | BD-3SX | DX8 AMA 1040965 |
09-23-2014, 02:20 PM | #2 (permalink) |
I can answer a few of those.
The 3300's run great in this heli. I was getting 10 min flight times at low headspeeds (not sure what headspeed) but still had enough power for light 3D flight. Highly recommend them, the CG wasn't an issue in flight and if you stretch to 500mm blades the 3300's are better for that as well. For the FBL, I can highly recommend the spirit FBL if you want rescue. It is half the price of the demon, offers many more features, and has the same reliable rescue both upright and inverted. Not to mention it is much smaller and can be mounted easily on the Atom 500 (I am running it and there is tons of extra room on the tray). 243 bucks for the FBL with 7 dollar shipping to the US. More should be available later this week. www.spirit-system.com The manual has an insert for the new FBL version but the heli comes pre assembled. Are you buying a used one or new? I believe the new ones come with a YGE rebrand 60 amp instead of the HW 60 amp.
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500 |
09-23-2014, 02:22 PM | #3 (permalink) | ||||||
http://ffevj.gfdzo.servertrust.com/v...500FBLHead.pdf Quote:
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
09-23-2014, 03:01 PM | #4 (permalink) | ||||
09-23-2014, 03:18 PM | #5 (permalink) | |
That's the older Platinum.
http://www.prostarhobby.com/product-p/4114.htm Unfortunately, they're out of stock everywhere in the US, so you'll probably have to go stock, at least for a while, unless you want to do some surgery on T-Rex 500 dampers..
09-23-2014, 08:31 PM | #6 (permalink) |
Ah crap, hmm now my good deal is not as good...
09-23-2014, 09:46 PM | #7 (permalink) |
I don't think the BEC is that bad, especially since it'll only be driving mini servos with the possible exception of the tail servo. The governor is pretty much crap though.
09-23-2014, 10:21 PM | #8 (permalink) |
What radio do you have? Just use a throttle v curve and and cyclic to throttle mixing. Better than some govs out there. Also doesn't the demon have a gov? If it does you just need an rpm sensor for it.
09-23-2014, 10:26 PM | #9 (permalink) |
The hobbywing 100a V3 is around 80 bucks new and an excellent ESC for this heli. Powerful BEC and will have no problem handling anything you throw at it
09-23-2014, 10:39 PM | #10 (permalink) |
I have a DX8. Unfortunately the BD does not have a gov.
I'll get it in the air with the hobbywing that is on it for now, it will be a good experience to try a v-curve and some mixes thanks guys
09-24-2014, 12:58 AM | #11 (permalink) |
Personally I prefer mixing over less than perfect govs. It won't hold a perfectly consistent rpm the whole flight, but response is instant when you give hard collective or cyclic. With some governors the headspeed has to lag for a split second before the ESC senses it and adds power. It will do great with properly adjusted v curves and mixes. I also have a dx8. Let me know if you need help with it. Its really simple.
09-24-2014, 07:59 AM | #12 (permalink) |
I put a 3X on my Atom 500, actually fly's pretty good.
I did have to slightly notch the frames to get the fit I wanted. I'll get some pic's later today and post. His is using two Sat's so no Rx mounting but there is enough room on the side frames or even between the frames behind the motor.
09-24-2014, 08:52 AM | #13 (permalink) |
Thanks Gimpy. Good to know!
I guess I'll know more when I get to look at it more closely. I got to check an Atom out last weekend at a fun fly they had at my local field, but did not really note the layout. I guess it planted the seed, 2 days later I bought one I see that space behind the motor, just did not know how much space is there.
09-24-2014, 08:16 PM | #14 (permalink) |
Ok was going to order some batteries tonight.
The 3000mah glaciers are 500g, the 3300mah are 518g, 10% more power for 4% more weight? Is 18g going to make a difference?
09-25-2014, 01:36 PM | #15 (permalink) |
I have 4 pulse 3300mah 6s packs I'm selling from my 12s setup
2 are 35c 2 are 45c
~Synergy N7, YS91-3DS, IKONV2/BT XPERT SERVOS ~Synergy N5c TT, OS55-H, IKONV2 ~Blade 180cfx ~Futaba T14SG TeamXpertServos |
