Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Like Tree1Likes
Old 02-08-2012, 11:08 AM   #21 (permalink)
Originally Posted by Slyster View Post
Did you watch the video in post #1?
i watched the first part of the video about the bevel gears, but it didnt answer the problem im having with mine. i downloaded the vid on my laptop, but havent had the chance to watch it. Which part are you reffering to?
https://www.youtube.com/channel/UCVA...MiyWkC_3r0vjMw - Me And MineTv Coming to Youtube Winter 2015
dantemcc is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 11:42 AM   #22 (permalink)
Watch the video.. the whole thing
Old 02-08-2012, 11:54 AM   #23 (permalink)
@dantemcc
Sure did.... Wilson suggests using CA to glue the inner race of the bearings to the bevel gears (the gears that mesh with the Torque Tube)... I suppose he didn’t mention the front bevel gears, but does it matter? Its literally the same thing.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 03:02 PM   #24 (permalink)
A prior poster asked about what type of grease and I could not find a reply within this thread.
Will liquid silicone grease (like Harvey's brand you find in the plumbing section as home improvement stores) work for gear lubrication?
zorax2 is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 03:50 PM   #25 (permalink)
Just don’t use anything petroleum based... silicon will work, some use that... others prefer lithium grease or some synthetic.
AMA# 977012
Old 05-03-2012, 01:23 AM   #26 (permalink)
Just discovered another tip although I don't suspect it has been the cause of many if any strips but worth mentioning none the less. The rearmost bearing that the rear gear slides into must be seated all and I mean ALL the way in so it is completely flush with the tail box.
I have just had a small crash and spent a bit of time trying to work out why the mesh seemed tighter than usual. I had to replace both the bearing and the gear and it turns out that my bearing this time was protruding by no more than a gnat's knacker. Using a chock of wood and a hammer, the bearing finally seated properly and the mesh is now spot on again.
Logo 700, Logo 600, Protos 380 Evo, Trex 470L, Jeti DS-16, TT Raptor 50 nitro, couple of planks and lots of laughs
Carapau is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 11:18 AM   #27 (permalink)
There is a tool made for pressing on and pulling off, torque tube gears-I think it was made for Align machines, but I did use it, successfully, on the Fusion.
It makes life a lot easier.
If I can find a link to it, I will post it.
Old 05-04-2012, 11:49 PM   #28 (permalink)
That tool would have saved me at least a few hours sitting in my garage floor with a hammer and random tools/blocks/etc. trying to get a perfect fit or get a bearing off a gear!
-Jay
Major Equipment Sponsor - AdventureRC
Discount_Bob is offline        Reply With Quote Quick reply to this message
Old 05-11-2012, 12:25 PM   #29 (permalink)
My front bevel gear moves in and out quite a bit. When it's out all the way the mesh is too tight. When this happens I think it's been contributing to a bad vibration. I'm going to be working on it this weekend, but I assume I'm going to end up gluing it.
David
HD Cell 500 w/ Ikon, Blade 130x, Citizen #258.
minnzoo is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 12:21 AM   #30 (permalink)
Hey guys - So I just received my Fusion 50 with the black gears. Has the stripping issue been solved or is there something I still need to do?
If so what's the simplest way to do it?
Thanks in advance
Just asking cuz it's kinda hard to determine if the problem has been addressed/solved by Outrage.
S
Trex 470LP / Beastx / Align BL50X / Align 470MX
Trex 500X / Beastx / Align RCE-BL80X / Align 520MX
smaze17 is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 01:23 AM   #31 (permalink)
Just work through the points in this sticky and you will be fine. What you may well find with your new kit is that the boom block now holds the gear solidly and so there should be no need for sanding.
Old 05-23-2012, 06:08 PM   #32 (permalink)
I just won a Fusion 50 from Helidirect and I am building it now. It has the black gears and it does have some play in the front TT gears. (Side issue, the main shaft will not go thru the swash, only goes half way in, argh). Nice build otherwise.
huckfin1 is offline        Reply With Quote Quick reply to this message
Old 07-06-2012, 12:03 PM   #33 (permalink)
I really dont understand how you guys can strip the main gear.
I'm using the old white main gear, not CNC, and after 30 or 40 flights the gear is pretty good.
My governor gain is set to Medium(25) in Castle Creations, so... I really dont understand this post ha.
Thanks.
nivaldin is offline        Reply With Quote Quick reply to this message
Old 07-06-2012, 01:24 PM   #34 (permalink)
I'm with you man... I retired my original gear after around 430 flights. Not because I stripped it, but because I had a motor/ESC fire that really charred it and I was afraid it may have been compromised. I still have it.
Depends on how hard you fly though... some guys fly really hard, with a lot of pitch and 700 sized motors.
AMA# 977012
Old 07-06-2012, 01:44 PM   #35 (permalink)
Yeah, I agree with you about the flight style.
My flight is not like Tareq ofcourse, but I do some harde maneuvers like Tic-Tocs, Funnels, Rainbows... so...
Old 07-06-2012, 04:24 PM   #36 (permalink)
Gov gain wasn't stripping main gears oddly enough, it was stripping tail gears. The main gear strips under 3 conditions normally:
1/ Bad mesh
2/ Using a 700 class motor
3/ In cold weather when the plastic gets more brittle.
Old 07-06-2012, 04:58 PM   #37 (permalink)
1/ Bad mesh
Make sense!
Old 08-04-2012, 05:00 AM   #38 (permalink)
Smile What happens when you want to change your gears?
Alright guys!
I've digested this thread as I'm building my Fusion.
Something has struck me about the gear gluing thing, if you glue both bearings on the tail end of the TT gear, how do you get it apart to change the gear if/when it does eventually strip?
Cheers all.
maddog7 is offline        Reply With Quote Quick reply to this message
Old 08-04-2012, 11:43 AM   #39 (permalink)
With a pliers and of some effort it comes off fine.
Old 08-09-2012, 02:07 PM   #40 (permalink)
What rpm do you use usually to avoid tail gears get stripped?
Soxos Strike 7.1
Minicopter Diabolo 700 UL and 550
Mikado Logo 600SX
Gaui X3
Arag_ is offline        Reply With Quote Quick reply to this message
