Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 11-13-2013, 03:14 AM   #61 (permalink)
Default Re: Castle Creations Quick Tip videos
Failsafe is the position of your transmitter sticks at time of binding, typically throttle all the way closed and cyclic neutral....
Sent from my DROID3 using Tapatalk 2
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 05:44 PM   #62 (permalink)
I am probably in over my head with this TREX 600 build, but I have somehow figured out every single piece of this heli except for this HV80. I having been trying to get the endpoints recognized for two days with no luck. I got the HV80 set up for Heli mode in the PC. Set radio to linear throttle/pitch with no trims, Dissabled thr cut. I then set the throttle endpoints to 30/30 and leave throttle stick at max. I turn on the receiver and see all servos responding correctly. Then I plug in the HV80 and get the 12 beeps as I expect. Then I start raising the endpoints in my radio and it goes to 140 without being recognized.
nSidio is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 05:55 PM   #63 (permalink)
Try reversing channel sound like u have a futaba radio ch needs to be reversed ... isnt working because when you plug it in at max it thinks its min ...
When you re do it with ch 3 reverse . After u set max then min you will get the chime that it armed ... hope that helps
Sent from my SCH-I535 using Tapatalk
kayakboy69 is offline        Reply With Quote Quick reply to this message
Old 03-09-2014, 10:19 AM   #64 (permalink)
Thanks for the response. I was sure hoping that would be the fix, but it still does not work.
Old 03-09-2014, 10:44 AM   #65 (permalink)
The pamphlet that came with the HV80 says the red wire does NOT have to be removed for the Ice2 HV. Almost every vid I have seen says to disconnect the red wire if using an separate BEC. Go figure.
After reconnecting the red wire, When I did the end point adjustment the HV80 finally collected a high endpoint of 119. I added 2, then started to lower the throttle stick. At this point the motor spun up??? Do I need to clear the initialization somehow and redo this step. It would appear I need to put the throttle servo back to not-reversed?
Old 03-09-2014, 10:48 AM   #66 (permalink)
One other question while I am thinking of it. I am assuming I should be doing this initialization in DIR setup for the 3GX? Once the throttle is finally set with its endpoints for the HV80 I would then go into the 3GX to set the throttle calibration?
Old 02-10-2015, 05:10 PM   #67 (permalink)
[QUOTE=nSidio;5701741]The pamphlet that came with the HV80 says the red wire does NOT have to be removed for the Ice2 HV. Almost every vid I have seen says to disconnect the red wire if using an separate BEC. Go figure.
/QUOTE]
that's for speed controls that have a built in bec ...
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 08:57 PM   #68 (permalink)
Ice2 does not have a bec .. only cut IF your hooking up esc with internal bec ..
Did you get your end points figured out ?
When you configure you end point . You take pinion off motor for safety
End points low and linear as you describe
Full throttle and plug battery in this put it in programing mode ..
Set hi end point till bleep ..
Lower and repeat bleep ..
After that when u lift the stick it will begin to spool up ..
Old 04-30-2016, 04:46 PM   #69 (permalink)
Default cc edge 50, need help
I cant get the esc to go into program mode, rx is a gpro
Wind Spirit is offline        Reply With Quote Quick reply to this message
Old 06-12-2017, 10:32 PM   #70 (permalink)
ok, where is the video?
3drcbuilder is offline        Reply With Quote Quick reply to this message
Old 06-19-2017, 03:40 PM   #71 (permalink)
Weird. I can only view the videos on phone/tablet but not from a physical computer and I've tried 3 different ones.
Logo 550se || MSH Mini Protos Stretch || Oxy 4 325 || NCPS || DX8 G2
howaboutme is offline        Reply With Quote Quick reply to this message
Old 08-12-2017, 05:15 AM   #72 (permalink)
CHC Benefactor
I think it's a problem with the youtube encoding. I had problems on both mobile and pc browsers. Here they are again:
Castle Quick Tip- Throttle Calibration.wmv (3 min 23 sec)
Castle Quick Tip Auto-Rotation Throttle Calibration.wmv (8 min 0 sec)
Old 09-27-2019, 01:32 AM   #73 (permalink)
reposted in correct place
