Old 05-17-2010, 03:19 PM   #61
6600RPM
OnTheSnap,
Thanks for posting photos of your SK 720. I just installed SK 720's on my Trex 450 Pro and Trex 500 using Align 450 Pro and Align 500 FBL heads as you did with your 450 Pro. I initially tried mounting the SK 720 on the 450 Pro's stock antirotation bracket but then discovered the KDEDirect extended antirotation bracket for FBL units. It enabled me to install the SK 720 facing forward (servo ports forward) solidly on a longer bracket. I recommend the longer FBL bracket for anyone mounting a FBL device on the 450 Pro.
I initially installed Align 3G units on my Trex 450 Pro and Trex 500 and then ordered Skookum SK 720's when I began to hear good comments about them. I am really happy with the way they perform. They let me adjust the level of control I want from the unit directly in the unit. I currently have both units set between the Scale and Default levels (elevator and aileron control rates set at 140 and 150, respectively) while I get accustomed to them. So far, I am very happy. I have a lot more control of my helis, and I am enjoying flying them much more as a result.
T-Rex 600 Nitro Pro
T-Rex 500
T-Rex 450 Pro
6600RPM is offline        Reply With Quote
Old 05-18-2010, 02:56 PM   #62
n808
Originally Posted by OICU812 View Post
Unit is on AR arm plate
Who makes and where did you get the "AR arm plate" the Mini-V is mounted on?
EDIT: never mind, found it, but out of stock. It's available here, though.
n808 is offline        Reply With Quote
Old 06-11-2010, 10:09 AM   #63
londonrommel
I bought the Aligh 3G flybar unit from ebay without the flybarless head and converted the trex 450Se2 into flybarless using all stock parts.
i used the following as a reference, see:
http://docs.google.com/viewer?a=v&q=...Qq0UVR4kCc_lmg
It works very well even on the first flight. Need to do more testing and adjusting to get it perfect.
let me know if you have any questions
Rom
londonrommel is offline        Reply With Quote
Old 06-11-2010, 04:10 PM   #64
Mathias
How's the Mikado 450 FBL Head working out for you guys? My 6S Pro will be converted to FBL shortly, and would really like some inputs on what head conversion to order.
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote
Old 06-13-2010, 05:55 PM   #65
southside81
450Pro Super Combo with BEASTX
southside81 is offline        Reply With Quote
Old 06-15-2010, 01:32 PM   #66
theflyingeagle
My Mini-V Pro.. need some more tweaking but it's already nice to fly!
Did my best te get it nice and clean..
Align 3G head...
theflyingeagle is offline        Reply With Quote
Old 06-27-2010, 06:49 AM   #67
zosek
Hey,
I'm about to build FBL pro. I just want some opinion on what to buy. I dont know which one. Mini v-bar or 3g. 3g is nice due to the package that includes everything, but i'm a little confuse because of it's more negative feedback than v-bar has. On the other hand, v-bar+head would cost me 100€ more.
What do you guys think?
Tnx,
SAB Goblin 630
JR Vibe 50
Protos 500
Align T-Rex 250
zosek is offline        Reply With Quote
Old 06-27-2010, 09:16 AM   #68
jetblue2135
Originally Posted by zosek View Post
Hey,
Tnx,
I am using the 3G on my Pro and it has been awesome. I also have 3G's on my 700N and 700E's, never had a problem or issue and the heads for all are really nice.
Smiling 's my favorite
jetblue2135 is offline        Reply With Quote
Old 07-06-2010, 01:56 PM   #69
DenDog220
removed
DenDog220 is offline        Reply With Quote
Old 07-13-2010, 11:37 PM   #70
flixdachef
If you guys don't mind me asking, what will a Mikado Mini-V stabi system cost me in U.S. dollars? I wouldn't mind getting my X-mas list put together early so my wife has a chance to save up
flixdachef is offline        Reply With Quote
Old 07-14-2010, 08:23 AM   #71
jetblue2135
About $475 for the current mini V and $299 for the new mini V coming out.
Old 07-19-2010, 11:54 PM   #72
OICU812
Im sure we'll be seeing a price revision as well on the new FS Vbar units to.
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
OICU812 is offline        Reply With Quote
Old 07-20-2010, 08:09 AM   #73
jetblue2135
...yes indeed.
Old 07-31-2010, 01:05 AM   #74
daschkiller
Default Using mine as a trainer
SK 720 mounted in the gyro position using JR DS285MG swash servos and 3500MG Tail. I'm supplying mine, with a warning: I am by no means an expert. Oh and another warning, if you're tweaking stuff in between flights be sure you upload the right file, reversed ailerons are not fun. Oh and one more, always disconnect the battery from your SK720 before plugging or unplugging the USB cable from the computer. I'm not sure if that's what did it or if the servo was gonna fail anyway but something toasted it.
File Type: zip training.zip (320 Bytes, 122 views)
daschkiller is offline        Reply With Quote
Old 08-01-2010, 04:50 PM   #75
KidHeli
well i am going to do it... i am going to get the mini v this week and then purchase the head week after next... gotta wait to get paid you know the deal.
while im waiting to purchase the head what are you guys thoughts
1. Align FBL head
2. Mikado FBL head
3. RJX FBL head... i think i have read about quality control issues with them, can you guys comment
let me know what you guys think.
KidHeli is offline        Reply With Quote
Old 08-03-2010, 10:57 PM   #76
AusAnt
Default Is my setup and file OK?
I am getting close to completing my Pro with MiniV, and was hoping somebody could look over my file and setup.
I posted a thread in the VBar section on HF - but if anyone here can help here's a link.
http://www.helifreak.com/showthread.php?t=233152
Thanks,
Ant
Logo Xxtreme
Mini Protos stretch - Mini VBar
AusAnt is offline        Reply With Quote
Old 08-04-2010, 06:57 AM   #77
mickeyjohnston
Default 450 pro FBL - Align 3G
Here is the video of me flying and the file here http://www.helifreak.com/showthread.php?t=229854&page=3
Mickey
mickeyjohnston is offline        Reply With Quote
Old 08-07-2010, 07:46 AM   #78
Kraanwater
Nice Flying Mickey, i had the same problem with stripping the main gear but i crashed Wasn't that bad tho, Main Blades and main shaft. What setup your are using and what is your Throttle cruve?
Kraanwater is offline        Reply With Quote
Old 08-12-2010, 04:08 AM   #79
mickeyjohnston
Thanks,
I'm running a -8 13t pinion, 2200mah 3S Zippy batterys. 3G FBL, Align blades. I'm running a flat 100% throttle curve. KBDD tail blades, CC 10 amp BEC. Everything else is stock.
Old 08-16-2010, 11:03 PM   #80
Don McCullough
Here is my 3G installation. Using the AR6255 receiver, all fits neatly inside the frame. I just drilled two small holes to access the pots on the bottom plate. The LEDs and the button are visable through the two bottom slits.
ID:	174529   Click image for larger version
T-500 V-Bar, T-450 Pro Skookum, T-250 V-Bar, Blade 130x, Blade 300x
Don McCullough is offline        Reply With Quote
