Old 05-17-2007, 04:26 AM   #1
Mercuriell
Default Build & repair videos 600 Nitro & E - by Mercuriell
TREX 600N Videos
http://www.helifreak.com/showthread.php?t=35686
Engine installation assembly - 34MB wmv
Clutch assembly - 35MB wmv
Clutch relining - 23MB
Clutch removal from the top - 16MB
Engine fan & ducting assembly - 40MB wmv
Engine starting - 23MB wmv
Metal blade grips & feathering sleeve - 30MB wmv
Throttle linkage and setup - 28MB wmv
Rotorworkx T600 Nitro frames overview - 12MB wmv
Rotorworkz T600 Nitro frames E -> N conversion notes - 38MB wmv
Damage control: Apply to E & N
Smackdown - what to do after you crash
Smackdown 1 - General overview - 33MB wmv
Smackdown 2 - Rotor assembly overhaul and metal grip install - 52MB wmv
Torque Tube front bevel gear replacement - 28MB wmv
Hitec 6975 servo gear change - 28MB wmv
Setup videos - applicable to 600E & 600N
Tail Setup Part 1 - Basics - 23MB wmv
Tail Setup Part 2 - Gyro setting - 32MB wmv
Engine & Motor - disassembly and repair
Bearing replacement on OS SX-50 Hyper v2 using bearing puller- 42MB wmv
Bearing replacement and overhaul OS SX-50 v3 using heat - 92MB wmv
Replacing piston ring - 9MB wmv
Articles on OS teardown from Audacity Models
John
Mercuriell is offline        Reply With Quote
Old 05-17-2007, 07:06 AM   #2
Eyefly
Yes please. For some of us who have never operated an IC engine, I would love videos of starting, tuneing, breaking in, maintaining, etc. Anything associated with running one of these. I am sure there are plenty of guys like me who only have electric experience. Thanks for the contribution.
Alex
Eyefly is offline        Reply With Quote
Old 05-17-2007, 07:54 AM   #3
Azlum
Any chance you could do a short vid showing how to properly set up your throttle linkage? This is one aspect that I am unsure of.
[ SAB Goblin ][ Trex 450 Pro ]
Azlum is offline        Reply With Quote
Old 05-17-2007, 09:58 AM   #4
tdsounds
I'm with Azlum and eyefly. I been flying nitros for almost 9 months now. I'm not even sure if my throttle linkage and engine tuning is right.
tdsounds is offline        Reply With Quote
Old 05-17-2007, 10:26 AM   #5
drummer5140
Wow very good video, will sure help me out when i get my new Trex next week, Thanks for the videos.........
drummer5140 is offline        Reply With Quote
Old 05-24-2007, 05:20 AM   #6
Mercuriell
Put up engine starting - no big deal for ex-Raptorites but glow virgins might find it of interest !
John
Old 05-24-2007, 08:23 AM   #7
DebianDog
Nitro virgins!
I never thought about it but you are right.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 05-24-2007, 09:46 AM   #8
benzmaster
Good job Mercuriell, i would recommand you this glow plug adapter :
http://www.readyheli.com/RVO1015_Rem..._p/rvo1015.htm
it's very cool because you don't have to remove the canopi to start.
i'll make a little picture of my 600N to show how I've installed it.
thx for all your vidz that helped me a lot !!
this item is also amasing :
http://www.readyheli.com/HE50H06_Ext..._p/he50h06.htm
i'll buy it as soon as it will be in stock
benzmaster is offline        Reply With Quote
Old 05-24-2007, 10:32 AM   #9
gbatch1
I just got hold of one, not many are floating around the uk atm. no one to help all on my own anyone got a set up of the boom and tube. chears guys x
gbatch1 is offline        Reply With Quote
Old 05-24-2007, 11:17 AM   #10
benzmaster
have a look at that : http://www.helifreak.com/viewtopic.php?t=38710
T-rex SE V2
Hacker A20-6XL motor - Hs65MG's - ESC 35X - GY401 - Gorrilla gear & tail paddles
T-rex 600N - OS 50hyper - GY401 and s9254
9451 on cyclic - Hatori muffler - 2 in 1 reg -Multigov
Old 05-24-2007, 04:25 PM   #11
benzmaster
here is the glow plug extension picture
Old 05-25-2007, 04:45 PM   #12
Mercuriell
That's very neat - I set up something similar with an RCA hifi plug but the ground connection wasn't working - maybe too much Loctite on the engine mount bolt so have to sort that out
John
Old 06-01-2007, 03:33 AM   #13
expertzx
Would love to see a video on how to install the torque tube but I guess it's too late since you've already built your chopper.
expertzx is offline        Reply With Quote
Old 06-01-2007, 03:38 AM   #14
benzmaster
it's easy to install.
first measure the middle, then put blue loctite 5 cm away from the middle and install the bearing. Once it's stuck, you can put washing up liquid on the plastic part that goes around the bearing. for introducing the TT, use the plastic protection tube to push... and you're done. Install the tail boom into the frame, install the tail case and screw it.
T-rex SE V2
Old 06-01-2007, 03:40 AM   #15
expertzx
Thanks for the advise, was sitting there wondering how I was going to install it but you explained it very well.
Old 06-01-2007, 03:42 AM   #16
benzmaster
:mrgreen:
T-rex SE V2
Old 06-11-2007, 08:59 AM   #17
Mercuriell
Thought I'd do a video of changing the front bevel gear and found a(nother) potential souce of binding which could cause tail issues - hope it's not too long-winded
Changing Torque Tube front bevel gear - 28MB wmv
John
Old 06-11-2007, 10:51 AM   #18
benzmaster
ouééé c'est le top, merci John
T-rex SE V2
Old 06-11-2007, 07:33 PM   #19
Finless
Team Taco VP
Mercuriell, WOW... I have not got a gear like that that was warped in that way. I have changed 4 myself. Yours looked warped possibly by heat or something?
Anyway nice idea for the fix BUT..... I would worry that the gear would float now and possibly move against the bevel drive gear thus leaving no backlash.
As a tip I would then use green locktite or thin CA to secure the inner race of the bearing to the plastic so the gear wont move forward. Just an idea to save premature wearing of the gears should the one gear move forward.
Bob
Old 06-12-2007, 09:15 AM   #20
benzmaster
have you seen that, you can now buy 3 front drive gear set for 25$
http://www.align.com.tw/shop/product...oducts_id=1785
T-rex SE V2
