Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-19-2013, 11:36 AM   #1
AnthonyV
Default Align 600 DFC Pro - Pinion for 2300-2400 RPM's?
I had a few issues on my 600 DFC (stock 510kv motor, ICE2 HV80 ESC) and decided to go through my ESC settings. Originally, I was running governor high and realized the 2200rpm's that I had wanted for IU2 was in fact much higher (around 2400-2500). I changed to SET RPM and now my headspeed is down to 2200 rpm which is too slow for me now. This is currently running 12s.
What pinions are you guys running for 2300-2400rpms's? Are you experiencing any problems with these head speeds? The problem with the current 13T (stock gearing, 8.615 gear ratio) that I am running is that it limits me to 2230 for a motor efficiency of 95% and Castle has advised me against going with anything higher with the current gearing with SET RPM.
Goblin 770 Competition - Goblin Black Thunder 700 Stretch - Goblin 570 - Vortex 250 PRO
AnthonyV is offline        Reply With Quote
Old 09-19-2013, 09:20 PM   #2
wifeorheli?
You can get the newly released upgrade allowing you to run the 700mx motor or run it ungoverned 95 flat or even 100 flat I HATE GOVERNOR run it wide open! You should hit around 2500 beginning of pack if jot more
Team RcHeliWorkz.com / Team ElyQ USA
TeamRcHeliWorks.com / Team Novarossi / Pulse Lipos
wifeorheli? is offline        Reply With Quote
Old 09-20-2013, 11:42 AM   #3
Mike A.
I ran mine at 2350 for quite a while using the setrpm mode and stock pinion. It gives you a warning but it works perfectly fine. You actually end up with quite a bit of overhead because the castle program is only using 3.7v for it's calculations.
Mike A. is offline        Reply With Quote
Old 09-23-2013, 02:12 PM   #4
AnthonyV
Mike A - You are correct.
I met with Clint from Castle Creations over the weekend and he explained everything in great detail to me. Basically, you could technically set the headspeed as high as you want but the motor power will never exceed 100%. So if you set it at 3000rpm head speed, the highest you'll get is 100% of the motor which would probably be around 2450-2550 depending on the KV of your motor, torque values, etc. Also, the deal about having it at or below 95% does not matter because again the motor will not exceed 100%. As you said, they calculate this at 3.7v and always allow a decent amount of headroom (5-10%) for their calculations.
I'm back at 2400 rpm at set RPM and it's running great
Old 10-02-2013, 10:29 PM   #5
satgod
I have mine gov'ed to 2350 using stock gears and pinion
I do have a KDE xf-530 motor in it and my gov is setup at 94.5% at 2350 I believe
it worked out very well
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 08-30-2016, 07:18 AM   #6
nabl74
For those of you running 2300 to 2400 can you let me know what blades you are using? Been running align 600 blades that came with 600l dominator at 2450. Just noti ed after about 200 flights or so that my blade holes are starting to elongate
Trex 500l Dominator-HW100A Pro / i2rc tail blade holders / Gpro
Trex 600l dominator- BRAIN / edge 80 / 750MX
E7se 700 - BRAIN / edge 120 / gryphon bec/ 800MX / 815 &855 cyclics and tail/ halo 700s
nabl74 is offline        Reply With Quote
Old 08-30-2016, 07:41 AM   #7
CZorzella
G'day mate!
I run my 600 at 2450 using Align 600 3G Carbon Fiber Blades (AGNHD600E) and Align 600 95mm Carbon Fiber Tail Blade (AGNHQ0950B) for the past three years and I haven't noticed any issues like you described, yet!
Carlos
CZorzella is offline        Reply With Quote
Old 08-30-2016, 08:46 AM   #8
Heli.Maniac
Running 2200 and occasionally up to 2350 and Align 600mm new edition blades, I have never had an issue with bolt hole elongating even after 300 flights on a set. Maybe your blade bolts are not in a good shape and are eating up the blade hole. Also ensure that you run your blades tight (I run mine very tight). And lastly, if the blade inserts are worn down but the actual CF around the holes is fine, then you may be able to swap the inserts out for new ones from another blade. After all, these inserts are removable.
Stock pinion with 600mx and Castle held great at 2350 and only time I felt the governor maxing out was when running a tired set of batteries.
Andreas (formerly known as anmatheextreme)
Compass 7HVU
Logo 600SX CF
Blade 450X
Heli.Maniac is online now        Reply With Quote
Old 08-30-2016, 06:01 PM   #9
nabl74
Intersting. There was a period of time prob e months or so where my headspeed was 2500 before i dropped my gov backto 2400.
Agree if pwm and timing are setup right governer works well at 2300 2400 but i found sweet spot at around 2450.
Might just get another set of aligns as they fly good enough for me.
Sent from my SM-G928I using Tapatalk
Old 09-01-2016, 04:01 PM   #10
apper001
I have switch on mine, fly great give some lighter load on the disc.
gonna get me some VTX 600 when they come out, but might wanne go with boom extension and 620mm (might cause a bit of a cog problem)
apper001 is offline        Reply With Quote
