Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 05-10-2015, 11:50 AM   #1
mototogo78
Default the Greaser for bearing maintaince
Hey guys and gals
Is anyone using Precision RC Products the Greaser? I saw one a while back in a video or somewhere else but can't find much talk of it on H.F. , If nothing else I figured it would be great for my 1/8 cars.
When I purchased it I also picked up some of Pete's Hobbies Recommended grease, Multipex Red NLGI #2.
If you are using this on your heli which bearings are you greasing, are you spinning the bearings up after repacking to loosen them up, and what is the smallest bearing and heli you have used this on?
mototogo78 is offline        Reply With Quote
Old 05-10-2015, 01:27 PM   #2
Larry227
I've never used it but the people that have swear by it. If you go to the Main Forum and search for "greaser" you'll probably find some threads about it. I think there was a new thread about it started not long ago.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote
Old 05-10-2015, 01:28 PM   #3
Larry227
Here I found a couple of the threads for you
http://www.helifreak.com/showthread....hlight=greaser
#nodroneshere - 104
Old 05-10-2015, 01:53 PM   #4
mototogo78
Thanks Larry
I did a quick search but only in this section. Next time I'll remember to search the main forum.
Old 05-15-2015, 09:32 PM   #5
TheMark
I use mine all the time. I've used it for more for non-RC bearings than anything else. The smallest bearings I've done were on my Warp main shaft
TheMark is online now        Reply With Quote
Old 05-19-2015, 04:10 PM   #6
truckermusic
i know that there is a huge discussion on wether to grease or oil.....
at the end of the day, as long as it is lubbed your good...
I will continue to use my Greaser no matter what.
I'm Old enough to know better........young enough not to care!
Blade Mcx2, Mcx 300, (2) Mcpx V.2's, One T Rex 450 DFC Pro and a Spektrum Dx8
truckermusic is offline        Reply With Quote
Old 05-21-2015, 03:10 PM   #7
MrBrink
Wasn't this product discontinued? I ask this because I was interested in this as well a few months back but could never find one.
In the immortal words of Socrates... "I drank what?"
MrBrink is offline        Reply With Quote
Old 05-21-2015, 03:58 PM   #8
B.R.C.
Ronlund.com has them still. I was going to buy one but found one used instead.
Avant Aurora 90 nitro..Trex600NPro..Trex600EFLPRO .... Trex450SE V2..JR Venture 30..350QX..130x..
B.R.C. is offline        Reply With Quote
Old 05-23-2015, 09:33 PM   #9
mototogo78
Pete's Hobbies (online) is where I got mine. I've also read the debates about it packing the bearings with to much grease and not allowing the balls to freely roll. I know its recommended to use a drill or such to spin it up and work some grease out of the bearing before reinstall. I ended up purchasing a tube of Pete's recommended grease, Multiplex Red. I also had read that Lubriplate Electirc motor bearing grease is good also. You can get the Lubriplate grease thru Ron Lund. Maybe I'll maiden the greaser on a few bearings on my 450.
Old 07-11-2015, 03:11 PM   #10
Gyropilot
Default Miniature Bearing Packer
Hi everyone,
I recently made a CAD drawing of a 2-piece miniature bearing packer which uses a standard insulin syringe to inject the grease. It's sized to fit tiny bearings found in the tail grip of a 450 all the way up to bearings nearly 1" in OD. I had a friend machine up a prototype out of aluminum for me and it works fantastic!
What do you think the interest would be in a tool like this if I were to have a batch manufactured and sell it as a kit (the bearing packer with a syringe) for under $30.00?
I ask because I know there are fans of greasing RC bearings out there (like me), but are there many of us? I just can't believe someone else isn't making a simple, inexpensive, miniature bearing packer already... or have they and I've missed it?
Note that I'm aware of the Precision RC Bearing Greaser (I have one), but it's big, a tad on the expensive side, and overkill for smaller bearings.
Best regards,
John
Blade 120SR (callsign: The No-Wind Heli)
Lynx (Blade) 450Xv2 w/Microbeast Plus Pro-Edition FBL unit (callsign: The Money Pit)
DX6i, DX9
Rotor thumping member of the AMA
Gyropilot is offline        Reply With Quote
Old 07-15-2015, 01:52 PM   #11
Rotarywing
I would be interested, As a cheaper alternative.
Rotarywing is offline        Reply With Quote
Old 07-15-2015, 02:00 PM   #12
Gyropilot
OK thank you.
DX6i, DX9
Old 11-27-2015, 11:28 PM   #13
OzDruiD
Same - did this go anywhere?
JR XG8 and DX7 Mode2 & Phoenix Sim for rainy days!
TSA 700N Platinum,OS105HZ-R+Hatori Pipe, DS615\DS655, BeastX,SwitchGlo
Align 600EFL PRO - Vbar Mini,DS610's\DS650,CC 80HV Ice, 12S - Turnigy 3600
Gaui EP550 CF PRO - DS610's, 6100T\6100G Combo
OzDruiD is offline        Reply With Quote
Old 11-28-2015, 06:26 PM   #14
Gyropilot
No... I decided not to pursue it after all.
DX6i, DX9
Old 02-29-2016, 12:19 PM   #15
noviceflyer
Gyro,
Would you be interested in posting your drawing for the bearing greaser?
noviceflyer is offline        Reply With Quote
Old 02-29-2016, 09:28 PM   #16
CrashAddict
I have one for sale if anyone wants one. http://www.helifreak.com/showpost.ph...47&postcount=1
Well, that was quick. It is sold now.
Mini Prtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
CrashAddict is offline        Reply With Quote
Old 05-19-2016, 06:04 AM   #17
tony#1
I would pay top dollar if anyone has THE GREASER for sale.
Tony
tony#1 is offline        Reply With Quote
Old 05-28-2016, 02:28 AM   #18
tony#1
Hi Guys,
Anyone smart enough to come up with a design for a substitute for the Precision RC Greaser, particularly for bearings as small as 5mm outside diameter? No suggestion here that this should involve infringing the intellectual property rights of Precision RC or of Gyropilot.
Can it be done?
Any information gratefully received.
Thanks for taking the time to read this post,
Tony
Originally Posted by Gyropilot View Post
Hi everyone,
Best regards,
John
Old 05-28-2016, 01:36 PM   #19
Gyropilot
Originally Posted by tony#1 View Post
Hi Guys,
Can it be done?
Tony
Hi Tony,
I have a miniature bearing packer prototype made up by a machinist-friend and it works great!
I'm so thrilled with the concept, that at one time I looked into having it manufactured. But between the initial upfront cash investment needed to start production, the hassle of selling, taking orders, collecting money, packing, and finally shipping, I decided it just wasn't something I wanted to take on. I've got WAY too many "hobbies" already and so many other things on my plate that adding "tool merchant" to the list isn't going to happen.
BTW, I once tried to convince Lynx Heli they should make and sell something like this. I think they (or a similar RC heli company) would be well suited with their existing manufacturing connections and retail infrastructure. But I guess they figured it wouldn't be a good seller as nothing ever materialized... as far as I can tell anyway.
Later today I'll try to post the sketch used to make my prototype and some photos of it. You're more than welcome to take it from there. I'd love to see someone make these.
Best regards,
John
DX6i, DX9
Old 05-28-2016, 06:14 PM   #20
Gyropilot
Default Mini Bearing Packer Photos
Attached are photos of my prototype miniature bearing packer. The bearing used for the photos is 10mm OD x 5mm ID so you can get an idea of the size. The smallest ID bearing this packer can accommodate is limited by the OD of the 4-40 machine screw in the center (approx. 1/8"). The largest bearing the packer can accommodate is limited to the OD of the packer itself, which is just under 1".
The packer uses a common insulin syringe (available from most drugstores) to inject grease under pressure. I fill the syringe directly from a tube of Tri-Flow TF23004 Clear Synthetic Grease.
A sketch of the packer and some 3D renderings will be attached to another post (running out of room on this one).
Regards,
John
ID:	654453   Click image for larger version
ID:	654454   Click image for larger version
ID:	654455   Click image for larger version
ID:	654456   Click image for larger version
ID:	654458   Click image for larger version
DX6i, DX9
