Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 05-28-2016, 06:17 PM   #21
Gyropilot
Default Miniature Bearing Packer Sketch
Attached is a hand drawn sketch that was used to build my prototype miniature bearing packer along with a couple of 3D renderings from eMachineShop.com CAD software.
NOTE that the actual prototype was made 1" OD instead of 3/4" OD as listed on the sketch.
Regards,
John
Blade 120SR (callsign: The No-Wind Heli)
Lynx (Blade) 450Xv2 w/Microbeast Plus Pro-Edition FBL unit (callsign: The Money Pit)
DX6i, DX9
Rotor thumping member of the AMA
Gyropilot is offline        Reply With Quote
Old 05-30-2016, 06:06 AM   #22
tony#1
Regards,
John
Thanks for sharing the information, Gyropilot.
It is very generous of you,
Tony
tony#1 is offline        Reply With Quote
Old 06-01-2016, 01:25 PM   #23
LoveToFly1
don't think new grease in a damaged bearing will help much guys...
Gasser Mike
Team Synergy, Team KDE Direct, Rail Blades, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote
Old 06-01-2016, 03:33 PM   #24
Gyropilot
Unless I missed it, I don't think anyone in this thread mentioned greasing damaged bearings.
The idea behind regreasing is preventive maintenance so the bearings will run smoothly and last a long time.
Happy flying,
John
DX6i, DX9
Old 06-03-2016, 11:51 AM   #25
Icantdefygravity
Default Bearing Packer
Does this really work. Can it get grease inside of the shields?
Icantdefygravity is offline        Reply With Quote
Old 06-03-2016, 12:10 PM   #26
Gyropilot
Yes and yes.
John
DX6i, DX9
Old 06-07-2016, 08:38 AM   #27
LoveToFly1
the point is once a bearing is in need of "regreasing", its probably notchy, right? that notchyness doesn't go away, that's in the balls and races inside the bearing. putting a ton of grease in it will just make it smooth until you run it again.
Gasser Mike
Old 06-07-2016, 10:02 AM   #28
Gyropilot
I respectfully disagree with your thinking on this.
I happen to have a travel trailer on which I clean and regrease the bearings annually to prevent them from wearing out. I don't wait until the bearings are worn or failing before I clean and regrease them.
Well my RC heli is the same way. Depending on the flight hours accumulated over the year, I'll pull and regrease the bearings annually as a preventive measure. I don't wait until they get notchy to lubricate them, but if I did detect a notchy bearing prior to regreasing, yes I'd certainly replace it!
DX6i, DX9
