Go Back   HeliFreak > R/C Helicopters > Zeal Rotor Blades
Zeal Rotor Blades Zeal Rotor Blades Support and Discussion
Old 02-15-2016, 01:50 PM   #1
txikarron
Default Zeal On Goblin 630 competition ?
Hello, I have a technical question. buy 2 sets of blades, Zeal 600 energy for a competition Goblin630 I bought. h I have a problem, screw hole main blade is small (4mm) and sab uses 630 5mm hole. I've looked at the 620 Zeal and having hole 4mm, the question is. there is an upgrade to accommodate the blades? or you can not put Zeal in Goblin 630? thanks
LOGO 400 3D VSTABI V5.1 6S
LOGO 600 CF VSTABI V5.1 10S
*********FUTABA FG8**********
txikarron is offline        Reply With Quote
Old 02-15-2016, 03:16 PM   #2
Seasick78
Have you tried pressing out the brass bushings in the blades?
Regardless, 600mm is quite small for the heavy 630.
Team - "Self Interests" -
Seasick78 is offline        Reply With Quote
Old 02-16-2016, 12:50 PM   #3
Simon_S
I believe the 640's are the ideal blades on the 630. Considering people run 660's on the 630 safely, the 640's extra length shouldn't be a problem.
Gaui X3 - T-Rex 550 - Goblin 630 - Gaui X7
Simon_S is offline        Reply With Quote
Old 02-16-2016, 01:55 PM   #4
Grumpy_Old_Man
The pressing out of the bushings is quite 'controversial' .. Some think it's fine. Personally i think the bushes are in there for a reason and i would not be happy to remove them. IMHO if they were intended to be removable the manufacturers would say so. But each to their own, you do it at your risk.
+1 on above point that 600mm blades are really too small for the Goblin 630. bear in mind that the G630 is much closer to a 700/770 size heli than it is to a traditional 600. It shares all mechanical components with the 700/770 so it's 'chunky'. You would need to run stupid high headspeed to get decent performance. I use 660 blades on mine.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 02-16-2016, 02:00 PM   #5
Seasick78
I've also used 630's, 640's and 660's. My favs were the 640's.
The 660's made the dragonfly agility seem slower than I liked for that airframe. 640's felt like a perfect balance for me. Better than 630's but no loss of agility as compared to 660's.
Old 02-16-2016, 11:21 PM   #6
Mr dan
They can be pressed out and replaced with the 5mm sleeve. You would have to drill out the root a bit to accommodate the larger brass sleeve. I've done this by using a drill press to assure a perfect 90 angle. SAB sells the 5mm brass sleeves. They also sell 4mm adapter that allows the user to accommodate the 4mm root mains on the market.
Align Trex 700x
Trex 700L dominator
Trex 600 L dominator
Trex 150x
Mr dan is offline        Reply With Quote
Old 02-16-2016, 11:42 PM   #7
Mr dan
http://www.amainhobbies.com/rc-helic...yx0314/p454010
The adapter is made by lynx heli. Its available at amainhobbies.
Align Trex 700x
Trex 700L dominator
Trex 150x
