Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 07-13-2016, 08:54 PM   #1
RcManChild
Default Sullivan Starter
Hey Everyone,
I have a sullivan starter and it is wobbly as all hell and will soon destroy the shaft where the starter goes.
the shaft that actually is in the motor slides in and out ever so slightly.. Is this normal?
I cannot for the life of me get this thing to spin straight... any advice?
I am going to call the manufacturer tomorrow to see what they say..
RcManChild is offline        Reply With Quote
Old 07-14-2016, 06:33 AM   #2
Geena
The slight movement of the starter`s motor shaft is normal. Mine does it too, and so does the one on my Hobbico starter.
Have you checked to make sure that the starter wand is not bent, or damaged?
I had one that was doing the exact same thing yours is doing, and it turned out to be that the wand shaft was bent. It was not much of a bend, but enough to cause it to have a bad vibration.
I don`t think that the starter`s motor shaft itself could be bent, but it would not hurt to check that too.
Gaui USA/Empire Hobby, YS Engines,Team Heliproz..retired,
Zeal blades, Demonaero/Bavarian Demon, Citizen00082
Geena is offline        Reply With Quote
Old 07-15-2016, 07:46 AM   #3
Puttputt maru
I had use the Sullivan starter for years and put up with it till I discovered, thanks to a friend, the Align starter.
It was night and day, so unbelievably smooth, no wobble and so compact too. If you can get your hands on one to try it, you will swap in an instant like I did.
TDR-IIto build, Triabolo, 2 X TDR, Kasama Srimok,90e FAIFA, T-Rex 700e DFC, Goblin700, BD 3SX, Jeti DC-16, Mezon,HW,Kosmik
CompArf 330 SC 2.6 BME 110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra ++
Puttputt maru is offline        Reply With Quote
Old 07-15-2016, 06:04 PM   #4
Geena
I actually have two Align starters. Don`t really care for them though. They were fine for starting my old OS 50 engines, but they struggled with 90+ size engines. At least from my own experience with them.
I much prefer the Sullivan starter with the Makita drill battery, and Sullivan starting wand. It`s heavier than most other starters, but I don`t have to charge it very often and has plenty of power to start my larger engines.
Old 07-16-2016, 09:08 PM   #5
FrankFuss
My Align starter turns over my 30cc (1.80 cubic inch) Zenoah gasser with authority.
Goblin 700 Gasser - Goblin 500 - T-Rex 450L (x2) - Spirit FBL for the win - Jeti DS-16
FrankFuss is offline        Reply With Quote
Old 07-16-2016, 09:19 PM   #6
BrokeDad
I just use a variable speed 20V lithium Black and Decker drill with torque sense. I passed it once to a guy with a .90 class heli who's flight box was dead and it didn't flinch. I prefer the pistol grip over a squeeze style starter. Walmart $70.
BrokeDad is online now        Reply With Quote
Old 07-16-2016, 11:03 PM   #7
Steve Graham
Strange thread. The dynatron is the gold standard of heli starters. Not sure what to make of the wobbly comments. Perhaps the bearings are bad in the unit. The starter wand by design sits in the rubber starting cone and will wobble if it's not supported at the other end by being inserted into a start coupler.
The Align starter is a complete POS IMO. It is a jackhammer with only two types of people who've used it. Those who've had something on their heli damaged by it and those who will. The latter usually see the light and move on.
Steve Graham is online now        Reply With Quote
Old 07-17-2016, 08:02 AM   #8
Ace Dude
I use the Dynatron/Makita combo myself.
Ace Dude is online now        Reply With Quote
Old 07-17-2016, 11:57 AM   #9
Steve Graham
LMFAO
Old 07-17-2016, 09:59 PM   #10
Puttputt maru
Yep strange thread indeed, I am far from a fan boy for Align but when 3 of us each with Dynatron at my field, which has worked fine for years, since we did not know better, I guess, tried the Align:
Is was a lot smoother
It was lighter.
But hey! we are all, more or less, grown man, pick what you want to champion.
Old 08-06-2016, 06:41 PM   #11
RcManChild
Returned starter to Dynatron, turns out the bearing housing in the front had been stretched out causing the wand to wobble. Unfortunately the align starter was not an option as there is no one way bearing on the SAB Nitro. You need a wand with a one way bearing.
Old 12-08-2016, 06:05 AM   #12
adam0702
Default hii
adam0702 is offline        Reply With Quote
