Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 09-01-2016, 09:44 PM   #1
Yooper42
Default Head blocks
I have one center hub that the slots where the flybar passes thru are approx 12mm long and the other center hub slots are only about 8mm long, also has no "flats" machined where the seesaw hub bolts on....whats the difference here??? Machine is a P6
Say "Ya" to da U.P eh!?!
I drive WAY too fast to worry about cholesterol................
Yooper42 is online now        Reply With Quote
Old 09-02-2016, 06:43 AM   #2
jbeech
Hi Will,
Basically, it depends when we made a part because over time we incorporate minor modifications to our product as running changes. We've made dozens and dozens of updates since our 2004 market foray.
John Beech - GM (and janitor)
AMA # 47381
IRCHA #745
www.audacitymodels.com
407-302-3361
jbeech is offline        Reply With Quote
Old 09-02-2016, 07:16 AM   #3
Yooper42
Thanks John
Old 09-02-2016, 07:34 AM   #4
jbeech
How is your model flying? Are you happy? Anything you wish you'd done differently? Anything you wish we did differently? Or better?
AMA # 47381
IRCHA #745
407-302-3361
Old 09-05-2016, 09:27 AM   #5
Yooper42
Its flying great, just finished its 21st gallon of nitro in its life, im very happy with it. there are a few things that come to mind to change, BUT, in doing so it would raise the price of the model, cost of the replacement part, and just really arnt nesasary as things work well enough now and when the stock things do need to be replaced, they are cheap to replace. Example that I think would be a nice touch are metal threaded inserts in all the bearing blocks like found above the clutch stack. Metal swashplate (i see in research you used to offer one) there is at times some flex in the stock one, can i notice that in flight for my style?, no so again, would be nice but not nessasary, as stock ones last as are and a replacement wont melt the VISA. Ive spent many hours at the field this last year with it listening to people say "my (insert high $$, 75 dollar tail boom heli) dosent have all that plastic on the head, tail, slight play in grips,etc" ......to which i usually reply take it for a ride and see if any of that makes a differance, it dosent. Dont get me wrong, i still love my minair, bergen twin, but it would be just short of a mortgage payment if i dumped one of those to fix it. In 21 gallons on the pantera ive only replaced dampers, the few hard meetings with mother earth have resulted in, 3 head axles, 1 main shaft, 2 tail booms, a set of struts, and just the other night a set of blades. All those parts together dont add up to half the cost of a set of rotor blades for my bergen twin MAH 810's. Planning is in the works right now to build a seperate bb pantera to add to the fleet this winter for my quad head thats sitting on the bench.
Cheers all
Old 09-05-2016, 02:03 PM   #6
jbeech
Off hand, I cannot for the life of me think of a higher compliment than a guy wanting to build another of my birds, but not like those guys who buy two at once, or one of each size in a line . . . but years after the fact.
Speaks volumes . . . thanks for sharing.
AMA # 47381
IRCHA #745
407-302-3361
Old 09-14-2016, 06:04 PM   #7
Yooper42
Anybody whos running the aluminum head block, know where a head button can be found that fits???
Old 09-14-2016, 10:02 PM   #8
jbeech
Call me.
AMA # 47381
IRCHA #745
407-302-3361
Old 09-18-2016, 03:46 AM   #9
Atomic Skull
RJX 10mm swashplate will fit you just need to find a replacement for the pin.
http://octopusrc.com/shop/index.php?...product_id=222
I've been told a Vibe 50 swashplate will fit too.
Atomic Skull is offline        Reply With Quote
