Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 01-09-2017, 08:19 PM   #1
mbaulfinger
Default New build - header tank
Hi All, Have a quick question about the header tank that gets installed on the right side of the pantera. Put the tank together. There's a rubber grommet that I assume is supposed to go in the mounting hole of the tank bracket. Its so tight that I'm having a tough time getting it in where it needs to go. Anybody have any suggestions? I thought I might cut a slot into the mounting hole to make it easier to get the grommet in there. Thanks for any recommendations.
Mark
mbaulfinger is offline        Reply With Quote
Old 01-10-2017, 06:21 AM   #2
Yooper42
Cant quite remember but i believe i drilled the hole in the bracket a little bigger, silicone grease the grommet and shoehorn it in
Say "Ya" to da U.P eh!?!
I drive WAY too fast to worry about cholesterol................
Yooper42 is online now        Reply With Quote
Old 01-10-2017, 06:27 PM   #3
mbaulfinger
Thanks Yooper! Appreciate the advice. I'll probably post more on here as I go. The instructions look pretty nice but I'm sure I'll get stuck a time or two as I'm pretty new to helis.
Take care,
Mark
