Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 10-06-2008, 06:18 PM   #1
HeliDaddy
Default New Trex600 Nitro Canopy Mount
Please check out this new Carbon Fiber canopy mount for the TRex 600 Nitro
http://www.helidaddy.com/SearchResults.asp?Cat=24
Trex 600 Easy Canopy Mount. This item is designed to bolt between the gear legs and base plate. The rectangle piece of carbon is a spacer for the rear gear legs to make everything even. This set includes the canopy mount with mushroom post, rear gear leg spacer and grommet. Also included are longer gear leg bolts. The carbon parts are 2mm in thickness. This mount also helps to prevent canopy breakage in the event of a crash. With this design the canopy simply pops on the mushroom post in the front, then you pop on the rear stock posts and go. This is our favorite solution to the 600 canopy mount problem, easy on and off, no screws to lose.
HeliDaddy Team
www.helidaddy.com
Helidaddy@bellsouth.net
HeliDaddy is offline        Reply With Quote
Old 10-06-2008, 06:20 PM   #2
HeliDaddy
Here's the photos...
HeliDaddy Team
www.helidaddy.com
Old 10-06-2008, 06:36 PM   #3
HeliDaddy
One last try...
ID:	64893   Click image for larger version
ID:	64894   Click image for larger version
HeliDaddy Team
www.helidaddy.com
Old 05-02-2009, 05:41 PM   #4
TurnerCanopies
Very nice set up
TurnerCanopies is offline        Reply With Quote
Old 01-17-2010, 05:28 PM   #5
face992
Is there any chance to purchase this in Europe?
face992 is offline        Reply With Quote
Old 09-26-2010, 12:13 PM   #6
rcflyerheli
Is this item still available. Can't find it at all.
rcflyerheli is offline        Reply With Quote
Old 12-28-2010, 08:51 AM   #7
Azalin
The site is dead now.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote
