Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Like Tree1Likes
Old 06-10-2014, 12:15 PM   #41 (permalink)
Thanks for the help
700L SXTS Neo | Goblin 700 KSE Neo | Goblin 380 KSE miniVBar | Nano QX
rando is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 12:31 PM   #42 (permalink)
did you try this without tailblades on?
Nano CPX, 130x, Trex250,
SAB Goblin 380, 500 & 700
Oxy3
- Lynx Team Pilot -
felborn is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 01:11 PM   #43 (permalink)
you have a 570? put that tail on the 500, see if it works, if so you know its some thing wrong with the tail. ill bet the 500 tail and the other side plate holes are off. making shaft not sq. worth a try
protos 500, 2 x SAB 380, SAB 500, SAB 570, DX7 G2 , MKS, TORQ, BK , YEG, KONTRONICK ,PYRO, XNOVA, SCORPION, TUNDRA x2 FLYZONE beaver x2 CZCUB all on floats BLACKOUT HEX x2 6", 5" HYPER 40 ,
pert is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 02:17 PM   #44 (permalink)
Without blades it is fine.
I dont have a 500 as I sold it. It flew fine but was just smaller than I prefer
Old 06-10-2014, 02:28 PM   #45 (permalink)
how is the boom attachment to the frame, solid?, it looked like the boom was flexing a bit in the 2nd video.
XLPower Specter V2 - Rotorflight - ELRS
OMP M2 Explore - Rotorflight - ELRS
TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS
P.I.Engineer is online now        Reply With Quote Quick reply to this message
Old 06-10-2014, 02:32 PM   #46 (permalink)
That tells a good bit. There is a possibility that one or both of the grips are not machined properly, or your tail dampeners are just too loose.
My first impression was that the thrust bearings were in the wrong order. I'm still wondering if the thrust bearings are contributing to this since it only shows up under load. I can't remember if you said you tried replacing them.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 03:13 PM   #47 (permalink)
I've replaced the entire tail rotor hub with new parts, grips, radials, thrust, spindle, dampers and blades -- no observed change in the behavior. The thrust bearings are installed properly with the smaller ID race on the outside. The shim/spacer is installed on both sides between the grip and damper and likewise between the thrust and radials. I could double up the dampers or toss more shims in there to tighten them up but would be kinda surprised that two sets produced this problem for me yet nobody else is reporting the same problem.
The boom is attached firmly. I think you're just seeing video artifacts from the vibration that create the digital illusion that it's flexing. I could swing the model like a baseball bat from the end of the boom and it wouldn't budge or flex.
Old 06-10-2014, 03:17 PM   #48 (permalink)
Come on over and take a look first hand.
Old 06-10-2014, 05:04 PM   #49 (permalink)
pushrod guide moving?
i'm looking through the manual for anything that jumps out at me.
Old 06-10-2014, 05:11 PM   #50 (permalink)
I've looked long at hard at the guide as the most probably interference target. I pulled it out and don't see any indication/wear marks from the belt slapping it. I haven't observed the push rod to have a more aggressive vibration than does the boom itself, like you might expect if the belt was somehow hitting it. As a test, I did consider mounting the push rod external (temporarily) or otherwise securing the tail in a deflected state to see if rod/guide interference were involved. I haven't tried it yet.
Old 06-10-2014, 08:04 PM   #51 (permalink)
Its gotta be the boom... Nothing left lol
Tri$tate 3D | BK Servo | Switch Blades | HeliDirect | Canomod
cjpainten is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 08:06 PM   #52 (permalink)
The Capi
Get a vbar.
Only old timer HF'er will get that joke
Old 06-11-2014, 10:03 AM   #53 (permalink)
Look on page 22 of the manual (bottom right corner of the page). Do you have HC026-S installed? That should take out any flex or play in the tail pushrod. Also be sure the rod is actually run through H0394-S.
Old 06-11-2014, 10:12 AM   #54 (permalink)
H0394, H0395 are both installed and secured by HC026. The push rod is running through H0394 and captured by H0395.
ID:	515147   Click image for larger version
ID:	515148   Click image for larger version
Old 06-11-2014, 07:52 PM   #55 (permalink)
You said you looked at the tail plates at the front? Mine became loose after a couple flights and made the same sound, see if your tail plates are secured at the drivetrain where the belt goes, same goes with the other plates form your main belt... Sounds like a hard one.
Goblin 500
3 Blade 130x All Upgraded
Mcpx Upgrades
LYNX TEAM PILOT
FlightTime500 is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 09:32 PM   #56 (permalink)
Nothing is loose.
Old 06-12-2014, 07:05 PM   #57 (permalink)
Building mine now. I see you have Logos and if you can get those tails working good you can get any tail working. Just wondering if you measured the 3 metal stand offs that separate the tail case halves? To see if they are identical. I had this issue with a Logo.
Logo 550SX, Modified Logo 400SE, Forza 450 3S
Lompma is offline        Reply With Quote Quick reply to this message
Old 06-12-2014, 08:09 PM   #58 (permalink)
I spent a couple of hours at RC Depot Hobbies today. We've now replaced everything from the boom back, including the belt and front pulley (except the push rod and hanger). The symptom remains. The head, main shaft and main gear wasn't installed for any of this testing so it can be ruled out.
I've previously removed, inspected and re-installed the secondary shaft and can find no issues with its installation. It turns butter smooth and has no play in any direction. Likewise the one way and gear. The motor belt is centered on the one way gear and tracks strait as shown in the video.
I'm nearing my wit's end on this one and the gents at RC Depot Hobbies are equally baffled. It sure seams like this bird needs a tensioner to keep the belt from going nuts under load. Can anyone out there demonstrate that their G570 does NOT behave like mine in the video? If yours were doing the same thing, it's quite possible you might attribute the strange sound hard tail loading as the "normal Goblin tail sound". Spool up on the bench without your mains and deflect your tail to the sides and give it a test. I'd be very interested to see some results.
Old 06-12-2014, 08:32 PM   #59 (permalink)
Default ?
I have been looking at the g570 as one of my next machines, so don't have one yet, nor the manual to correctly describe the parts.
But, my 2c are a bad bearing in the shaft at the front pulley for the tail belt. Take the bearings out and apply heavy lateral pressure while turning with a shaft running through them.
If you feel ANY notchy-ness or if they are sloppy chuck them and try a higher rated bearing.
Worth a shot? Hope to help.
I have had a similar issue with the set up and seating of gears on some torque tube installations where if the mesh is too tight it puts too much lateral pressure on the radial bearings exposing early bearing notchy-ness.
birdcrazy is offline        Reply With Quote Quick reply to this message
Old 06-12-2014, 08:41 PM   #60 (permalink)
Default also...
what is the need for the dampened tail system? Is there a resonance in this particular size Goblin that needed equalizing? If so, then maybe you need to lube your tail dampeners.
