SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters |
07-06-2014, 06:19 PM | #1 (permalink) |
goblin 500 and microbeast tail bounce
I am having slight tail bounce at low rpm hover and fast forward flight. I've tried increasing and decreasing the tail gain with no effect so far. Is there a setting in ar7200bx that i am missing that may help this?
specifics: hover bounce goes away at around 2200rpm and it is not a fast frequency bounce, maybe 2-3 times up/down per second. Then I only get it in FFF. -thanks |
07-06-2014, 10:22 PM | #2 (permalink) |
Hi
Double check your COG I had the same issue but with a MSH BRAIN. COG and a little tweaking fixed it Good luck |
07-06-2014, 10:34 PM | #3 (permalink) |
Sounds like dial 1 cyclic gain a little high.
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700 |
07-06-2014, 11:45 PM | #4 (permalink) |
I had that problem when I used the MB. Turning down pot 1 will fix it.
07-07-2014, 06:56 PM | #5 (permalink) |
Thanks guys. I'll have to give that a try.
07-07-2014, 08:29 PM | #6 (permalink) |
Pot 1 can go as high as about 10 o'clock on many of the 500s I've setup for people.
If you're getting the bounce and you're only at the 9 o'clock default then something is wrong. I found more than a few people that had not setup the servo frequencies for the swash servos and this makes a huge difference. Check your step B |
