Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 180QX
180QX Blade 180QX Helicopters Information and Help
Old 01-30-2014, 11:15 AM   #41 (permalink)
Still saves as a php file
Old 01-30-2014, 11:17 AM   #42 (permalink)
Try the link at the bottom of the page that goes to a zip file and let me know.
or right here http://www.rcgroups.com/forums/showt...4#post10893316
I am not sure why a direct drop in doesnt work correctly
indoorheli is offline        Reply With Quote Quick reply to this message
Old 01-30-2014, 11:20 AM   #43 (permalink)
Both files on page 1 and the link download as php files
Old 01-30-2014, 11:30 AM   #44 (permalink)
I have a feeling it's the HF servers not recognizing the filetype...your computer generated the file so it will download for you as spm...but not for anyone else
I think we will have to find a place to store it online...without going thru a website...
Or. just get 5 or 6 guys to help with email distributions
Old 01-31-2014, 02:48 PM   #45 (permalink)
Originally Posted by JonJet View Post
...Hey Ivan...Octane is gonna do a step-by-step picture tutorial for the DX6i...
Any updates on the tutorial?
"Nothing is as constant as changes"
DX9, DX6i, Blade Nano CP X, ZYX "Blade" 130X, Blade 180 CFX, Blade 230S, Blade 300X, Blade 450 3D (about 2 b FBL; have the parts, not the time), Blade 180QX, Blade 230S V2, Convergence, Mini Convergence.
Neunerball is offline        Reply With Quote Quick reply to this message
Old 01-31-2014, 02:51 PM   #46 (permalink)
yes..its posted in the 350 QX Thread for StaGility...its on page 11 or 12 I believe
Old 01-31-2014, 02:52 PM   #47 (permalink)
It's post #220
Old 01-31-2014, 03:12 PM   #48 (permalink)
Thanks JJ!
For anyone looking for that post, here's the direct link to it.
https://www.helifreak.com/showpost.p...&postcount=220
Old 01-31-2014, 04:16 PM   #49 (permalink)
Added video instructions and download link on the first post.
here is the DL link as well
https://www.dropbox.com/sh/gwz4drycp49c36n/t_RnSfuFUW
Old 02-01-2014, 03:35 PM   #50 (permalink)
Am I right in saying that stagility only works if the 180 is in stability high angle (flashing blue) mode. This was the only mode it seemed to work correctly in.
T-REX 550 DFC, Hubsan X4 v2, DX9, DJI P3A
helidan is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 03:41 PM   #51 (permalink)
Yes...start in Stability and add the StaGility switch
Old 02-01-2014, 03:47 PM   #52 (permalink)
Default Re: Stagility, Its a new flight mode!
Depends on how you have your radio programmed.
It should be able to work on high or low angle stability.
For me on my 350 I have smart, stability and then stagility as separate function and no agility anymore.
It will not work in agility mode as you need it to have stability on when no stick input is given
Wait for my edit..I never say it right the first time!
Old 02-01-2014, 03:54 PM   #53 (permalink)
I have my DX7s setup as per the settings in the manual.
After programming stagility and switching on the mixes it seems I can only go between stability high angle (flashing blue) and agility (red)
If I enable stagility and leave the other switches in stability low angle then stagility switching does not work properly.
Old 02-01-2014, 04:04 PM   #54 (permalink)
For standard dx7s programming It made to operate and to be toggled on from normal stability mode. You can't go from agility to stagility, it will only be agility.
Though curious how does it act on low angle stability, what is odd about it?
If it is just low rate stability it should work in that mode too
Old 02-01-2014, 04:13 PM   #55 (permalink)
The LED changes from solid blue to flashing blue when stagility in enabled and the cyclic stick is moved, but no red LED. I've checked and confirmed the mix behavior in the monitor screen.
Using original factory DX7s programming and leaving F-mode and T-hold in the 0 positions (stability low angle) if I switch on the stagility mix I cannot get to agility (red light) I need to switch F-mode to position 1 first. I've got stagility tied to the elev D/R switch as I don't use that one.
Old 02-01-2014, 05:19 PM   #56 (permalink)
Do you want it to work in low angle?
What is your gear to gear % value?
If it is 45% or less try 46- 50% and see what happens
Old 02-01-2014, 06:32 PM   #57 (permalink)
From the first post
"FOR ANY RADIO YOU MUST ALREADY BE IN STANDARD STABILITY MODE TO BE ABLE TO PROPERLY ACCESS STAGILTY!"
Standard Stability Mode is referring to Stability High Angle with the 180qx.
Steve - KT4RJ
NT7R is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 06:37 PM   #58 (permalink)
A big wave to NT7R...if you're active on 20m...listen around just above 14.2 MHz for K6MB or W6ZR... it's the Ray & Jay Show and I haven't been there for years
Give a big wave for Me if you hear them...WW0WR
Old 02-01-2014, 06:45 PM   #59 (permalink)
I was under the impression that low angle stability on the 180qx is stability on low rates, no?
If it is a full different mode and is +100 gear (350qx is -100agility, 0 stability and +100 smart)
then it will not work.
If it is a +100 setting It will only hit stability with stick input of up,down,left or right but will hit stagility with stick input at any angle from center
Old 02-01-2014, 06:47 PM   #60 (permalink)
You are 100% correct...that is exactly what I just found out, it's only StaGility in Low Angle Mode if you use diagonals from cyclic center
