Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 01-15-2017, 09:55 PM   #1 (permalink)
Default Using main and balance plug to power things...
I'm adding a 40x40x10mm fan which is capable of 8.4 volts to my Goblin ESC. I use a 2s lipo under the belly. the fan has amp draw of .29amp, will the 2S lipo care if I use the balance plug(outer 2 pins = 8.4v) to power the fan... while the 12g supply wire feeds the FBL system simultaneously?
Thanks,
-Markus
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 01-16-2017, 02:57 AM   #2 (permalink)
Thanks,
-Markus
That's sounds fine to me. A good charger will pull more than .29A through those connections whilst balancing.
RCHN #280
Goblin 700
Align T-Rex 600EFL Pro, 550E DFC and 500 PRO DFC
Blade mCPX and mSR. Spektrum DX9
RC Flight and Battery Log App
DrSteve is offline        Reply With Quote Quick reply to this message
Old 01-16-2017, 07:15 AM   #3 (permalink)
Thanks, it's a 2200mah 30c 2s. I couldn't imagine it would have any issue delivering a bit more power to a small fan which would affect its ability to maintain power to my HV servos
Goblins like to heat up ESC's. I'm curious how much the fan will help
-Markus
*LINKS*
Old 03-06-2017, 01:18 PM   #4 (permalink)
FYI :
Several flights like this and no negative impact. I can't even notice a measurable difference in pack voltage after 3 flights while running the fan..
Great summer fix for a hot (ish) ESC!
-Markus
*LINKS*
Old 03-14-2017, 07:15 PM   #5 (permalink)
I powered my LEDs like this on my night flyer. Many flights and never an issue.
Fly it, Dare it, Damage it!!
shannimal is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 03:51 PM   #6 (permalink)
You can safely draw up to about 4 amps from the balance tap. My old power lab charger (4S) used to charge from the balance taps only and had a max current of 4a. Also modern balance chargers discharge at up to 1-2A from the balance tap when charging.
However you will need to keep an eye out for cell imbalance if you draw out too high current from a single cell.
jgiannakas is offline        Reply With Quote Quick reply to this message
Old 03-23-2017, 04:10 AM   #7 (permalink)
This would only be problematic if you don't tap into all cells of the lipo ausing cell imbalance. Event hat could be done and being balanced by the charger but you*'d get different IR over time. Since you run it at 8.4v I don't see how it could harm the lipo.
Kingtech KT-800, T-rex 700X, Tarot 550, Bell 222 (T-rex 600), Hughes 500E (450), Devil 420
Thoemse is offline        Reply With Quote Quick reply to this message
