Old 02-06-2017, 12:52 PM   #1 (permalink)
Default TRex 700E, alarm issues
On my Trex 700, when I power it up, there is an alarm that sounds like it coming from the 3 cyclic servo area. It's not the ESC (Castle), not the 720.
My rear center servo apparently has a bad gear which I found after checking the unit out.
I just don't know where the alarm is coming from, all functions work, but the Helo won't spin up. All lights are green, I know the process of taking off.
I am stumped on this one, I will put a gear kit in the 700 tonight. But I though it should still spool up even with a bad servo DS615.
Anyone run into this?
Dennis
TRex700MRX is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 01:16 PM   #2 (permalink)
Dennis
Dennis, the HC3SX/BD3SX only passes the throttle signals through, the only warning you will get from the FBL will be blinking or solid colored LED on the unit and won't give you any warning for throttle. The warnings from the esc will come from the motor. Make sure that your TC isn't zeroed so the esc won't arm, check your TCs. I would definitely be checking the ESC, does the motor turn freely as normal, main shaft not locked up. The cyclics won't have any affect on ESC arming and motor spool up. You're just going to have to go through one item at a time, double check everything.
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 02-07-2017, 02:09 PM   #3 (permalink)
i wonder if its a timing issue or a bad solder joint on the motor/esc ? they will make a squealing noise if something wrong, if its this , dont let it do it too long ,can burn stuff up ..
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 02-07-2017, 03:15 PM   #4 (permalink)
It was an audible alarm coming from the cyclic servo area (DS615's), About 6 beeps with a pause. That's when I noticed the rear servo acting funny, the more I played with it, the worse it got. I know I have to put a gear kit in it. Otherwise, I don't have a clue as there is nothing else there the alarm can come from. I had the unit up to my ear.
Dennis
Old 02-07-2017, 03:34 PM   #5 (permalink)
Dennis
I've never had ds615 servos or servos that sounded an audibe alarm. Still suspect esc/motor.
~Jim~
Old 02-07-2017, 07:35 PM   #6 (permalink)
if you know its from the servos and you know one is bad.. change them.
Protos 700N, Kraken 580N, Align 700N pro, SAB drake 700, Xlpower V1 , Xlpower V2, Goblin380, XLpower 550. Protos 700 leggero, Protos 700 Evoluzione
Mr dan is offline        Reply With Quote Quick reply to this message
Old 02-08-2017, 03:58 AM   #7 (permalink)
I am changing the gear kits out, or I will change the servo out if necessary.
I don't know if the alarm came from the servo's, I thought it was the ESC (Castle), Again, I put my ear right next the the frame, and whatever is sending the alarm is in the servo area.
I will find it, just seeing everyone's opinion, it's strange.
Dennis
Old 02-08-2017, 04:00 AM   #8 (permalink)
Yes, the motor spins freely. It does not respond to the transmitter. When changing modes, it will jump a little, that's all.
Dennis
Old 02-08-2017, 07:49 AM   #9 (permalink)
Dennis
Does your ESC go through its normal arming sequence on power-up? If not you might try re-binding and then verify throttle ATV's.
~Jim~
Old 02-08-2017, 08:38 AM   #10 (permalink)
I don't ever remember binding the Castle ESC. I will have to look this up. I have the Castle Link and set the parameters to my preference!
Thanks, Dennis
Old 02-08-2017, 09:06 AM   #11 (permalink)
Thanks, Dennis
After you set up your model its always a good idea to re-bind/relink your model.
You not binding the ESC, but you need to establish zero throttle endpoint or at least make sure your ESC sees your Tx 0 stick. If you haven't set the low throttle endpoint so that the ESC sees 0 (zero) throttle it then the ESC can't arm. This may be the problem. You can go on YouTube and find CC Throttle calibration videos, just follow their instructions.
~Jim~
Last edited by KSHeli; 02-08-2017 at 09:15 AM.. Reason: added; 1st sentence and 0 (zero) throttle
Old 02-08-2017, 09:17 AM   #12 (permalink)
Thanks, Dennis
If you haven't set the low throttle endpoint so that the ESC sees it then the ESC can't arm. This may be the problem. You can go on YouTube and find CC Throttle calibration videos, just follow their instructions.
~Jim~
Old 02-09-2017, 10:32 PM   #13 (permalink)
I put a gear set in the Center Servo, works great.
YOU ARE CORRECT, it's the MOTOR!
You can actually feel pulses in the motor when it's beeping.
Sometimes it's 1 beep, pause, then 3 beeps.
Next time it's 2 beeps, pause, 2 beeps
Another time it was: 1 beep, pause, then 3 beeps
All beeps are continuous, non stop.
I have search all over for an answer. I have reset, recalibrated, and anything else I could find that's related.
It was working great and Sunday I plugged it up and it started doing this.
I guess I will call Castle tomorrow.
It's a Castle Edge 120 HV
Dennis
Old 02-09-2017, 10:33 PM   #14 (permalink)
For the record, all the below has been done.
This model was working flawlessly. Sunday I plugged it up and this problem appeared. I have no clue what happened.
Old 02-09-2017, 11:23 PM   #15 (permalink)
Most likely it's the ESC then, the ESC sends it's signals through the motor, CC will get back to you. I hope it's a minor issue for you.
~Jim~
Old 02-09-2017, 11:38 PM   #16 (permalink)
ESC's just decide to go out like this?
Dennis
Old 02-10-2017, 07:42 AM   #17 (permalink)
Dennis
Its electronic dealing with a lot o V's and A's let's see what CC has to say.
~Jim~
Old 02-10-2017, 07:51 AM   #18 (permalink)
OK
Old 02-10-2017, 04:37 PM   #19 (permalink)
I am somewhat embarrassed. I called Castle today and they were more than helpful.
He listened to the beeping alarm on the phone and knew where to check. The ESC was trying to communicate with the motor, but the motor was detecting full throttle!
Somewhere, somehow, the polarity was switched. I am not quite sure where, it could be the Skookum, or it could be my radio.
After reversing the throttle on the radio, and checking everything in the Castle, the motor will spool up now. All functions are operating normally, except the Skookum software.
But it's not right as my Skookum data switch now shows the throttle reversed! I have not figure out how to correct this.
I didn't make any adjustments other than to my throttle curve. The reverse switch is in a different area on the JR9503.
Now I have to figure out why the Skookum is now reading backwards. I was thinking about just starting up with a new model as it's really not that hard, but I would like to correct it through the Skookum 720 first.
Thanks, Dennis, and let me know if you have an idea of the new issue now.
Thanks to all who have helped, I just have to figure out the collective and throttle being backwards now.
