Old 11-04-2015, 07:38 PM   #1 (permalink)
Default Piston skirt
This is a OS 55HZ and as you can see the chip in the skirt should I replace it or will it be ok. My next question is what would have caused it to break off?
glennwil is offline        Reply With Quote Quick reply to this message
Old 11-05-2015, 06:36 AM   #2 (permalink)
Did you use an engine crank lock tool to tighten your fan hub on to the crank shaft?
I've seen the skirt become damaged when guys use the crank shaft locking tool with the piston at BDC. The skirt gets pressed against the crank shaft locking tool and gets damaged as your tightening the nut. Piston needs to be TDC when using the tool.
dchekas is offline        Reply With Quote Quick reply to this message
Old 11-05-2015, 06:55 AM   #3 (permalink)
Hi Darrick, what means BDC and TDC ?
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 11-05-2015, 09:11 AM   #4 (permalink)
Bottom Dead Center and Top Dead Center.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 11-05-2015, 08:01 PM   #5 (permalink)
Took the engine apart to check bearings and discovered the chip in skirt,had lots of movement in piston pin so I have decided to change piston,ring,pin and clips also. I never use a locking tool on it don't know how it got broke.
