Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 500X
Blade 500X Blade 500X Helicopters Information and Help
Old 12-09-2013, 08:59 PM   #61 (permalink)
Originally Posted by Relisys190 View Post
Thanks for the size comparison. Now I REALLY WANT one ))
You're welcome! Glad I can be of service. You must buy one!
(lll)---------------TEAM FLYBAR!---------------(lll)
--Blade 500 3D--Blade 360CFX--Blade 450 3D--Blade 230S--Blade 130S (x2)--Blade MCPX BL--Blade MSR-X--Blade MSR--Estes Proto X--UMX Radian---DX8 Gen 2--Heli-X 4.2 Sim--
helitack32f1 is offline        Reply With Quote Quick reply to this message
Old 12-09-2013, 09:05 PM   #62 (permalink)
Originally Posted by SFT2 View Post
I'm not doing a whole lot to mine. I'd like to get all the aluminum rotor head parts, main and tail, but that's a large fortune. I swapped out the gyro for a 401 and I have a Castle Ice 75 ESC on the way so I can have a governor. Not much to do beyond those, it's a pretty solid bird.
I too have the desire to hop up the head, mostly so i can sit and look at it, much like I already do. The parts at the website below are quite a bit cheaper than elsewhere so go for it!
http://www.hopmeup.com/air-parts/blade-500-3d.html?p=1
Old 12-10-2013, 12:04 AM   #63 (permalink)
I finally received mine today about 7pm this thing is bigg. I was checking the price yesterday at HMU an yes they're cheaper than anybody else for the 500 but I use them for my 300X & 450X. I was checking the prices for upgrades for the 500 just see how much for FBL or metal upgrades. Need to checkout how it flies stock.
vronny is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 03:15 AM   #64 (permalink)
Apparently I'm in the minority, but I think the 500 is fairly small. My wife said it was cute sitting next to the Raptor. Funny thing is the E360's boom is almost as long as the Blade's.
See 2nd pic: I think I can make this work with a little quality time with the Dremel and a sanding drum. If so I'll repaint the canopy in the MSH scheme with Blade 500 instead of Protos down the middle.
Name:	photo 3-1_2.jpg
ID:	470848   Click image for larger version
Name:	photo 2-2_2.jpg
SFT2 is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 10:55 AM   #65 (permalink)
Yeah, size is all relative. When I first got mine my wife was all "My God, what did you do!" A few days later I took her to IRCHA and she saw all the 700s buzzing around--then she thought it was "cute" too!
Current Fleet: Raw 700, Black Thunder 700, Raw 420, Oxy 3, Oxy 5, Oxy Flash, OMP M2, Specter NME
Member of: AMA, Fort Wayne Flying Circuits, Summit City Aerospace Modelers
ArmchairNinja is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 11:49 AM   #66 (permalink)
Default The blade family
Some pictures of my blade birds below:
ss1-2013 is offline        Reply With Quote Quick reply to this message
Old 12-10-2013, 11:52 AM   #67 (permalink)
Blade 500 3d, 450 3d x2, 450x...
ID:	470912   Click image for larger version
ID:	470913   Click image for larger version
Old 12-14-2013, 02:49 AM   #68 (permalink)
Being a lousy heli pilot, I didn't want to blow up a set of perfectly good and expensive carbon blades, so I ordered a couple of pairs of cheap glass 430mm blades from Helidirect. However, they're for lowly Align 500s with their puny 3mm blade bolts, so, naturally, they won't fit with the huge 4mm bolts on the Blade. Solution? Simply press out the bushings with an arbor press, chuck each up in the lathe, bore them out with a 5/32" drill (nearly exactly 4mm), deburr, and press them back into the blades. Problem solved in 10 minutes
Without a lathe I'd say your best bet is hunting down someone with a lathe or finding some 5mm OD x 4mm ID x 10mm brass bushings, possibly at Fastenal, McMaster, or similar. If you're near the north side of Houston PM me and I'll do it. Takes about 10 minutes if I don't have everything ready. The $12 blades aren't perfect, but they fit the grips very well and they're cheap. Order a couple of sets and match them by weight. It took 5 pairs of 325mm blades from the same people to get a set of 5 for my MD500E within .1 grams, but I'm a bit nuts about that.
Old 12-14-2013, 05:00 PM   #69 (permalink)
The replacement revolution blade for the 500X has to be punched also an they fly them with no the inserts. I have some $14 430mm Hobbypartz CF blades same small insert just punched out with a Phillips screwdriver seems to fit fine no shim is needed in blade grips. p.s. I was at Ultimate hobbies today an there walk in price for the 500 3D was $234
Old 12-14-2013, 08:39 PM   #70 (permalink)
Some blades have a 4mm hole bushed to 3mm, which just need the bushing pushed punched out, others have a 5mm hole the needs to be bushed to 4mm. Don't try to fly with that much slop, the carbon or glass will chew through the screw.
Old 01-18-2014, 01:06 AM   #71 (permalink)
Just got a set of Revolution carbon blades from Horizon for $15, knowing they wouldn't bolt on. Punched out the bushings in the arbor press, turned new bushings, bored the blades to fit, pressed in new bushings, and they're perfect. Took maybe half an hour and I had some 1/4" 6061 sitting around. The blades are within .05 grams overall and less than .10 grams different at the tips. Works for me, so I ordered another pair to have around for the inevitable rekitting.
Old 01-19-2014, 06:21 PM   #72 (permalink)
The Blade 5003D is now history!, It has been shit canned on Horizons site!....
Raptor 50 Titan,Align Trex 450 Sport V2, Blade 500X, Blade Mcpx V2,Blade 180 CFX,Traxxas Aton Quad,Blade 230S,Mia Microflight Gyro Copter,Jr 8103, Spektrum DX8,Spectrum DX7g2...
VortechZ230 is offline        Reply With Quote Quick reply to this message
Old 01-19-2014, 08:54 PM   #73 (permalink)
I still see it on both the Bladehelis site and then when you click buy it now, it takes you to the Horizon site where it says back ordered.
Old 01-21-2014, 01:59 PM   #74 (permalink)
Default Why not just get a 500X for $461 ?
advantagehobby.com has a 500x for $461.00 free shipping!
Use coupon code “NEWCUSTOMER”
Figure the Beastx & battery are worth $250. That’s $211 for a 500 size Heli.
seenemcrash is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 06:07 PM   #75 (permalink)
Default blade 500 3d swashplate mix help
Hi fellas, I am a newbie to this web site and I need some help setting my swash plate mix. I have a blade 500 3D and I am using a JRx9503 aircraft radio, I have all other setttings correct but cannot figure out what the swashplate settings should be, can you assist me in getting this figured out? Any help would shurely be appreciated.
Mark43 is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 08:13 PM   #76 (permalink)
Not sure exactly what you mean by a "Jr Aircraft Radio", but by my definition of what an aircraft radio is (or at use to be), it won't work with a heli. You need a heli option.
On the otherhand if you mean it is a transmitter for flying aircraft (any kind) as opposed to a surface radio for cars or boats, and does have a heli setup, then you want the 120 degree swash for a flybar heli like the 3D.
I recommend you look over the Finless heli setups here.
ahahn is offline        Reply With Quote Quick reply to this message
Old 04-19-2014, 10:36 AM   #77 (permalink)
Blade 500 3d RTF is back on HH website for sale. If anyone wants to buy make sure sure read the 500 's forum and change the gyro with Futaba or Spartan quark....
Just a friendly advise!
Link below:
http://www.horizonhobby.com/browse/p...:cp=1/:ip=45/:
__________________________________________________ _______
Blade 500 3d, 2 450 3d, 450 x, 120 sr, nano cpx, nano qx...
2 dx6i
Old 04-19-2014, 11:14 AM   #78 (permalink)
Link below:
2 dx6i
That's a surprise maybe they realized that a lot of people where buying them
Old 04-19-2014, 11:32 AM   #79 (permalink)
+1
Old 04-19-2014, 08:11 PM   #80 (permalink)
Originally Posted by ArmchairNinja View Post
+1
Absolutely...
