Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 03-11-2017, 06:08 AM   #1 (permalink)
Default Tribunus 120 / fullsize vbar / vcontrol
Are these 3 compatible?
Can't seem to be able to setup the tribunus on the vcontrol,
Have loaded the vbar parameters into the esc, and scorpion app on the vcontrol. Selecting Tribunus on the esc wizard detects nothing?
Main feed into esc port, red/black on slave wire to spare channel, rpm wire on slave to sensor port.
Any thought's? or is this just Neo compatible?
Tkx
Birdman
Drive safe, Play safe, Fly safe.
Agile 7.2 + 7.2 GaSSer, Vibe90,Logo 200x2 Gaui X3,X3L,X4II,X4II-NF,,GX4,X5,X6
Synergy E5,516x2,N5C,N556,G556,766S
Raw 420, Black Nitro, Tron 5.8. Roban AH64-700
thebirdman is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 07:10 AM   #2 (permalink)
I was told Neo only for Telemetry and Setup via VBC.
One good feature you can still use is Capacity Cutoff as setup with PC software.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 08:44 AM   #3 (permalink)
Thankx Gimpy, was hoping that wasn't the case
Not about to redo all the wiring to put on a Neo, so will probably just remove and put on a HW100 I have. As for capacity I can do that with the timer, pretty expensive timer if that's all I'm using It for.
Old 03-12-2017, 10:39 AM   #4 (permalink)
Flying by timer vs flying by capacity is the same especially if you fly different head speeds. It allows me on my Synergy E7SE to fly 7, 8 or 9 minute flight depending on headspeed.
soXos Strike 7.1 L, Diabolo 600, Logo 600, Kraken 580, Protos 380 Evo
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 05:31 PM   #5 (permalink)
Agree...100%
New hobbywing installed and setup....
Small issue with rpm display...say's 1685, actual tack reads 2413
New it wasn't correct by the sound
Have ran 3 batt's thought it on bench run up,"no blades"
Belt has been dressed and still taught....
Have to redo the tail pitch rod as heard a weird sound during the setup and noticed the carbon tube was split... going to go with the outrage 90 steel rod, need to pick up a 2mm die tomorrow so i can re-thread the shortened end.
Unfortunatly my main computer took a nap last night, using a backup now.
Hope i will be able to retrieve all the mod upgrades to pass on
Old 04-11-2017, 07:40 AM   #6 (permalink)
That should have said flying by timer vs flying by capacity is not the same.
