Old 03-18-2011, 08:44 AM   #1 (permalink)
Default Hyperion 320 first flights
I figured out that you can file the JST connector down that comes with the Hyp 320, and it will then fit in the mCP's connector. This is taking a risk on my part, as you can put it in reversed and fry your heli...
Well, this battery certainly provides more head speed. It also gives the tail more authority to the point that I had to trim it nose left for roughly the first two and a half minutes of the battery, whereupon the head-speed comes down to normal and the tail starts holding once more. The initial "hit" lasts about 1:30, and then about another minute where it falls off slightly but is still stronger than stock.
I was just hovering it indoors to get an idea of the capacity with a few pitch pumps to gauge power. Where 5 minutes puts my Eflite battery to about 17-22%, 6 minutes on the Hyp 320 took it to 3.76 V or 17%. This was only the second run of the battery, but that conforms to what I expected based on the 1st battery, which was 3.79 V or 27% at 5 minutes. For the third run, I did not hear the minute beep at 6 minutes and ran it to 6:50, which resulted in 3.72 or 15%. The voltage came up some after a few minutes, and when I put it on the charger, it started at 27% and took 242 mah. I believe that the cycling improved the battery's performance some.
Another interesting thing is that the Hyperion ran 11F cooler than the Eflite battery that I flew between the two Hyperion flights.
I then took it outside and loaded an Eflite battery and did a few hard pitch pumps then switched it out for the Hyperion. The extra power is very noticeable. I'd say the climb on a pitch pump is just about doubled. You can still hear the motor load up, but the heli just jumps.
The extra climb was so unexpected that I wound up going too high in the evening twilight and loosing orientation. I ended up crashing the heli, and not getting to TH as soon as I normally do, so the main gear popped completely off and I lost the lower main bearing.
If I can find a bearing today, I'll put the 240 Hyperion in and try that out, but so far, I think the 320 is going to be a big hit. I still find it hard to believe that this battery made such a big difference in performance, but it does. I wish I had been able to do some more outdoor pitch pumps to see how it compared at the lower end of the battery. Maybe today...
[ame]http://www.youtube.com/watch?v=BtmVuOAL9c8[/ame]
[ame]http://www.youtube.com/watch?v=iZV3g3Ig65M[/ame]
[ame]http://www.youtube.com/watch?v=WOtavKCtsUc[/ame]
Wayne Bengston
Gootch 450 Pro, Walkera 4G3 & 4G6
Blade 120 SR and mCP X
PZ Night Vapor, Ember and UM Mosquito. M-A-E Penguin
VaderSS is offline        Reply With Quote Quick reply to this message
Old 03-18-2011, 08:55 AM   #2 (permalink)
Cool! Thanks for the info. You could mark a red dot with a sharpie on your battery connector as a reminder of which way to plug it in. Did you have to modify the stock battery holder to get the new battery to fit?
The glass is neither half-full nor half-empty. It's exactly as full as it needs to be.
teknokreeper is offline        Reply With Quote Quick reply to this message
Old 03-18-2011, 09:05 AM   #3 (permalink)
I taped the battery to the bottom of the canopy for my tests. I have the Dylwad mounts for Hyperions, but have not installed them yet. I plan on putting them on spare landing gears for easy swap outs.
Thanks for the tip!
Wayne Bengston
Old 03-18-2011, 09:32 AM   #4 (permalink)
Thanks for the tip!
So the 240's and 320's are the same size and both will fit in Dylwad mounts?
Blair
T Rex 600 pro Mikado ,Blade 150s,mCPX brushless,3D Hobby Shop AJ Slick,Funtana X100, Dynex 2.4, Nano CPX, Mako, Crac Yak,Venom FPV Hex
BPINE is offline        Reply With Quote Quick reply to this message
Old 03-18-2011, 10:48 AM   #5 (permalink)
Blair
No, there is a different mount for each. I plan on putting the mounts on 2 different spare landing gears so I can easily swap them out.
Wayne Bengston
Old 03-18-2011, 11:38 AM   #6 (permalink)
I just figured out that the Dylwad 320 mount will also securely hold the Eflite and Hyperion 240 batteries. They bulge the mount a bit, but I don't think it will hurt it.
Wayne Bengston
Old 03-18-2011, 02:35 PM   #7 (permalink)
I'm very interested in trying this out. I'd love to do anything to get a bit more tail authority... after the first minute or so it has a hard time keeping up with more aggressive manuevers.
WonderedUnder is offline        Reply With Quote Quick reply to this message
Old 03-18-2011, 02:54 PM   #8 (permalink)
where do you get the mounts and battries???
superjet112x is offline        Reply With Quote Quick reply to this message
Old 03-18-2011, 02:56 PM   #9 (permalink)
You get them here.
http://www.rcgroups.com/forums/showthread.php?t=1405618
Old 03-18-2011, 03:04 PM   #10 (permalink)
Thanx!!!!!
Old 03-20-2011, 02:03 PM   #11 (permalink)
How are you getting 5 minutes of flight time with the stock battery? At 3 minutes my mcpx doesn't even have the power to lift off the ground!!
heliface is offline        Reply With Quote Quick reply to this message
Old 03-20-2011, 02:07 PM   #12 (permalink)
Flying in normal mode. I can fly it over 6 minutes before it hits the cut-off. 5 minutes takes it down to 16-22%. Done that since new.
Gets squirrelly in the last minute though.
Do you have zero pitch at mid stick?
Wayne Bengston
Old 03-25-2011, 11:32 AM   #13 (permalink)
Has anyone taken the risk to try the 500mah 12C from the 120SR? I used alittle heat from a lighter to soften the stock mcpx battery tray/holder, then the 120SR battery slide right in. After a few rounds it fits no problem......BUT i havent changed the plug on the battery in fear of frying the board. I have a spare eflite charging adapter for it that i could use the female end and solder to the boards battery wire to accept this battery.
Im also in the process of doing a brushless main and tail swap in my "spare" mcpx, lol. If the only problem is the that the stock main and tail motors cant handle the 500mah battery but the board can then maybe i could still use it in the brushless setup...https://www.helifreak.com/showthread...ight=brushless
anyone have any thoughts???
ID:	217301   Click image for larger version
ID:	217302   Click image for larger version
daneger21 is offline        Reply With Quote Quick reply to this message
Old 03-25-2011, 11:36 AM   #14 (permalink)
and yes that was a spare landing gear that was broken, and yes the batterys alittle tweaked. i did that in about 3secs of work, bahaha
Old 03-25-2011, 11:42 AM   #15 (permalink)
The battery charge lead from the 120 will fit the mCP connector if you wiggle it back and forth to get the mCP connector's terminals to slide in. I have no idea what the current rating for that lead is though.
You can also file down the connector on the 500 and it will fit in the mCP's connector. You MUST make sure you have the polarity right when you plug in though or you WILL fry your board. Once filed down, it can also be inserted reversed in the 120 SR and in the charger lead.
I have not tried the 500, but I have tried an Oversky 400. It had rougly the same discharge curve as the stock 200, but I was able to make an 8 minute hovering flight. The last couple of minutes felt like the last minute on a stock batt.
Wayne Bengston
Old 03-25-2011, 11:49 AM   #16 (permalink)
I would assume white to white, black to black...?? lol
Old 03-25-2011, 01:35 PM   #17 (permalink)
Yes, but if you get in a hurry...
'Course, some manage to stuff keyed connectors in the wrong way.
Wayne Bengston
Old 03-25-2011, 05:16 PM   #18 (permalink)
your right, not sure if im still gonna try it. ill wait until im done with the dual brushless setup to see if i need more juice
Old 03-25-2011, 05:51 PM   #19 (permalink)
Well i gave in, i tried the 500mah 12c from the 120SR. Waaay to heavy, havent flown my 120 in awhile so maybe the batteries alittle weak from not using. Either way i only flew it once with the one battery, but it just seemed way to heavy, bogged the head big time on pitch punches.
Maybe my battery or maybe just to heavy. Im sure others will try...
