Old 07-29-2008, 05:51 AM   #1 (permalink)
Default Carbon frame available now.
http://www.infinity-hobby.com/main/p...oducts_id=3418
If someone tries it, please post a review.
T-rex 600N, 8717, V-bar, 8900, YS50.
MSH Protos, 3517, Mini V-Bar, 3500.
JR DSX9
Rune
Roadrune is offline        Reply With Quote Quick reply to this message
Old 07-30-2008, 08:30 AM   #2 (permalink)
Have one incoming.
Will make a review.
Wesp
wespen is offline        Reply With Quote Quick reply to this message
Old 07-30-2008, 02:02 PM   #3 (permalink)
Cool. Looking forward to it!
They say the cf frame comes in lighter than the plastic frame.
BEAM: jazz 40, scorpion-8, 3xHS65mg, gy401+9257
FBL Compass Atom: Stock motor, YGE80, 3x9650, 9254
akshaw is offline        Reply With Quote Quick reply to this message
Old 07-30-2008, 09:07 PM   #4 (permalink)
Originally Posted by wespen View Post
Have one incoming.
Will make a review.
Wesp
Wesp, could you pls check whether the stock plastic battery tray and bottom plate can fit into the CF frame that you're having, don't like the CF bat tray cus it has no place(flat surface on top) to stick velcro on it.
Thanks a lot, looking forward to your review.
cheers,
Richard (rich)
Trex SE v2 -- HS65MG, GY401+9257, CC35, 430XL, GG, G Paddles, K&B Tail Blades
Trex 500 CF -- HS82MG, GY401+9257, stock ESC and motor, Align metal upgrades, K&B Tail Blades
heliboy88 is offline        Reply With Quote Quick reply to this message
Old 07-31-2008, 03:50 AM   #5 (permalink)
Will do.
Ill weight the stock frame (have one unopened spare) and the new CF in thousant of a gram
Wesp
Old 07-31-2008, 06:51 AM   #6 (permalink)
cheers,
The stock plastic battery plate and bottom tray are part of the solid plastic framehalves....Not separate pieces.
So impossible to re-use.
The "Complete" Carbon frame has a flat battery plate and bottomplate.
You can fill it with as much Velcro as you like
I never use Velcro for my Lipos BTW, I CA a couple of rubber strips on the tray (Tire repair rubber).
Rocksolid, better cell cooling, and i never have to put velcro on the lipos.
Eric
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRÔTOS
EricW is offline        Reply With Quote Quick reply to this message
Old 08-01-2008, 01:41 AM   #7 (permalink)
Hi Eric, thanks a lot for the heads up, i know the CF bat tray is flat, but they cut out all the materials in the middle to save weight, so there seems to have no place(surface) to stick the velcros on it.
Btw, how do you secure your lipo on the tray without using velcro(even straps?), do you mind to show a pic, if it's safe enough i might go the same route too.
cheers,
Richard (rich)
Old 08-01-2008, 05:31 AM   #8 (permalink)
I use the supplied O-rings in the kit to fasten the lipo.
In one photo you see the rubber strips on the tray, the other with the lipo mounted.
When you use the carbon base plate,
You could use the plate as a scribe tool to make rubber fit exactly on top of the plate.
Your only concern during a flight is that the lipo stays in place in all cases.
Velcro does it, but this does it even better and simpler Imho, and you don't have to velcro your lipos.
Eric
ID:	57277   Click image for larger version
Old 08-03-2008, 09:33 PM   #9 (permalink)
Thanks a lot for the tips(and pics) Eric, i might try that method of yours, it really looks simpler and yet safe for my flying style.
cheers,
Richard (rich)
Old 08-08-2008, 05:34 AM   #10 (permalink)
Got it in a mail today.
Just a few snaps before I start.
Looks really nice.
Wesp
ID:	58185   Click image for larger version
ID:	58186   Click image for larger version
Old 08-08-2008, 06:10 AM   #11 (permalink)
Please let us know how it fits and how you get around with installing the electronics, resulting COG etc.
Looks great.
Eric
Old 08-08-2008, 11:42 AM   #12 (permalink)
I put it on digital scale.
Stock frame - in unopened pack (so shave down a few grams) - 140 g
Carbon frame - 121 g
RTF with stock frame and 7S A123 - 1743 g
RTF with carbon frame - will see when its done
For sale - new unopened stock frame
Wesp
ID:	58205   Click image for larger version
ID:	58206   Click image for larger version
Old 08-08-2008, 05:48 PM   #13 (permalink)
A few more snaps before I go to bed.
Electronics first thing in the morning.
Wesp
ID:	58220   Click image for larger version
ID:	58221   Click image for larger version
ID:	58222   Click image for larger version
Old 08-09-2008, 04:54 AM   #14 (permalink)
seems they are sold out now.
helipete is offline        Reply With Quote Quick reply to this message
Old 08-10-2008, 03:11 PM   #15 (permalink)
All done.
Now I only need AR6100 End Pin version to clean up the wires and its ready for maiden.
Review coming up after that.
Wesp
Old 08-15-2008, 04:58 PM   #16 (permalink)
Sneak peak from today's flight
Protos:
- stock motor
- CC60 + CC Bec
- CSM 760 + InoLab 261
- 3xMKS 9660
- 7S A123
- 1730g
Trex500
- Z20-1400
- CC60 + UBEC
- 401 + 9254
- 3xInoLab 260
- 7S A123
- 2100g (man, friends Hurri 550 is 2500g)
Guess which one is better
Wesp
ID:	59136   Click image for larger version
Old 08-28-2008, 09:47 PM   #17 (permalink)
Anyone know how durable this frame is? Cause I have heard quite a bit about the stock frame being weak in a crash. Not that I expect anything to be invincible, but frame replacements suck.
Jimmy! is offline        Reply With Quote Quick reply to this message
Old 08-29-2008, 08:54 AM   #18 (permalink)
Honestly its not that bad. The frame is 2 sides with a few screws. You can easily replace the entire frame in under 30 minutes.
Plus the fact that they are $25 each, you can buy nearly 4 complete frames for the price of this C/F one.
Ecaf is offline        Reply With Quote Quick reply to this message
Old 08-29-2008, 10:47 AM   #19 (permalink)
Hmm... I just hate having to reposition, rewire, reset, etc, everything in a frame replacement. But how fragile is the plastic frame, and compared to the CF? Or what kind of crash tends to result in a frame breakage?
Thanks for the help, I'm going to get a 500-size heli and I want to be sure its the right one before i spend the money
Old 08-29-2008, 11:38 AM   #20 (permalink)
Show me a frame that doesn't need rewiring or repositioning after a hard/framebreaking crash.
All other positive factors, like price ,performance, design make the frames the least important in your choice Imho...
Better performance = more power/time to recover = less crashes
The stock replacement frames are indeed inexpensive and the fact you can buy these very nice carbon upgrades for it already, is just a big plus when you make a comparison.
Maybe people crash hard because they feel a bit to comfortable with the Protos and forget what they really master and what not....
It flies great with both, that's for sure
