Old 02-11-2013, 01:25 AM   #1 (permalink)
Default Which RPM sensor?
Does anyone here run an external governor on their Mini P? I'm thinking about using the governor on my Skookum SK540 instead of the YGE gov. Mainly just to play around with it and learn about it before I stretch it. Which RPM sensor would you recommend?
SAB Goblin 500- Quantum 4120-1200KV, YGE 120 LVK, SK540, BK HV servos
Mini Prôtos
-Scorpion 2580KV, YGE 60, SK540, KDS N300, MKS DS95i
Futaba 8FG Super
Dogga is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 01:57 AM   #2 (permalink)
Default Re: Which RPM sensor?
Hobbywing. cheap, digital, reliable.
Sent from tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 02:07 AM   #3 (permalink)
Thanks mate. Hmmm can't seem to find any in Australia
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 04:13 AM   #4 (permalink)
I got mine here: http://helidirect.com/rpm-sensor-p-26366.hdx. Few shops carry them.
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 04:16 AM   #5 (permalink)
Thanks how did the installation go? Is it simple? Do you have to solder it to the motor wires? Would you say it's worth the hassle over using the ESC gov?
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 04:31 AM   #6 (permalink)
Here's my write up about enabling the v-bar gov on my mini -> https://www.helifreak.com/showthread.php?t=460223
I soldered to motor side of the ESC rather than motor wires - I wanted an external governor enabled speedo after all Pretty easy procedure and SOOOO MUCH worth it
Tom
Goblin 700
Carbon |
Old 02-11-2013, 04:40 AM   #7 (permalink)
Thanks mate I'm most scared about soldering the wires lol. So did you just need to cut off the existing shrink tube, solder then re-shrink tube? I've heard the Skookums gov is decent so want toplay around with it
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 04:53 AM   #8 (permalink)
Nothing to be afraid of I used a scalpel to peel off a couple milimeters off the insulation, put a turn of the sensor wire around the motor cable and soldered the whole thing together.
I always use double shrink tube on motor connectors just to be sure. It's not necessary on these small motors as voltage is not high enough to produce the same kind of sparks big motors do.
Btw, you have Revolectrix packs in your signature.... How do you like them? I just got a PL8 from Revo and holy something of someplace, that thing works awesome! Got me thinking a bit
Tom
Goblin 700
Carbon |
Old 02-11-2013, 05:14 AM   #9 (permalink)
Thanks for the info I can't get over how cheap the sensor is!
I have a Powerlab 6. What awesome chargers they are. Love the PC software too! I love the Revo batteries, especially the quality for the price! I run a flat line curve of 75% on normal and get 6min flight time with 30% left in the pack. I use the platinum label packs (40C rating)
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 05:20 AM   #10 (permalink)
Nice! Might go get me a couple packs to try. Thanks mate
Tom
Goblin 700
Carbon |
Old 02-11-2013, 05:28 AM   #11 (permalink)
No worries mate thank you! Once you go the revo's you wont look back. Just about to order that sensor, might MSG you if I have any trouble
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 05:49 AM   #12 (permalink)
Just found my hobby shop i usually order form in Australia stocks the Hyperion ones : http://www.zeejayhobbies.com.au/elec...prod_6523.html
It says "solder up a male/female connector adapter for convenience". How would you solder up an adapter so you don't have to solder to the main wire itself? I can't picture it in my head.
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 06:01 AM   #13 (permalink)
I wouldn't solder any more connectors, it just adds a failure point to a place you won't ever need to disconnect anyway.
Tom
Goblin 700
Carbon |
Old 02-11-2013, 07:29 AM   #14 (permalink)
I got my hw sensors from the Aussie importer of hobbywing, can't remember their name right now, but lookup hobby wing website and find Aussie distributor, send them an email and get some.
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 07:52 AM   #15 (permalink)
I went with a hobbywing sensor. I have a picture in the last post.
https://www.helifreak.com/showthread.php?t=491970
A lot of RC stuff:
Heli's, Quads, FPV gear, Tools, Chargers, Transmitters
jmisuraca is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 03:28 PM   #16 (permalink)
Thanks Ross I checked it out looks like its a business called Hobby Habit. I flicked them an email
Thanks for the pic jmisuraca how did you solder the sensor? Did you cut away at the rubber at the top of the ESC wires?
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 07:22 PM   #17 (permalink)
OK so I emailed both Hobbywing dealers in Australia and here are their replies:
1 - "We do not stock this product. We can only buy Spektrum RPM sensors that suit Spektrum Radios."
2 - "Rpm sensor we do not manufacture maybe you need to contact hobbyking"
Useless I tell you. What's the point of being a dealer for a brand if you won't get their stock in....
Mini Prôtos
Futaba 8FG Super
Old 02-11-2013, 10:25 PM   #18 (permalink)
I cut off the plastic shrink tube off the ESC and Sensor.
Soldered on the correct wire for the power and signal side of the sensor then heat shrinked it. Soldered the motor connections of the sensor to the ESC. Put it all in new shrink tube.
A lot of RC stuff:
Old 02-11-2013, 11:02 PM   #19 (permalink)
Well doesn't look like the Australian dealers want to help. Guess I'll take my business overseas!
Mini Prôtos
Futaba 8FG Super
Tags
mini protos, rpm sensor, skookum 540
