Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > N7
Old 05-07-2015, 03:12 PM   #1 (permalink)
Question Boto Sizer or Options for my N7
I purchased a N7 to join the Synergy family but I am stuck. The build is practically complete but I cannot locate a ball link sizing tool to save my life.
Any suggestions or recommendations would be greatly appreciated!
John
azfishguy76 is offline        Reply With Quote Quick reply to this message
Old 05-09-2015, 02:11 PM   #2 (permalink)
If you have an extra ball, carefully cut an edge into it and you can use that. Just make sure that it's a clean edge with no burrs.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 05-09-2015, 08:50 PM   #3 (permalink)
+1, that's what I did and works great.
Chuck it into a drill or dremel. Doesn't take much so be careful, especially with a high speed rotary tool like a dremel. Literally a second or two with one of those. (Use the drill if you have it )
"You need more rockets. Everything is better with rockets"
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote Quick reply to this message
Old 05-10-2015, 07:44 PM   #4 (permalink)
You can also just squeeze the links while on the ball. This will loosen them enough to move freely. I use a ball link plier.
John
Team Synergy, Rail Blades, Lynx Heli
Citizen #396
jmiceli11 is offline        Reply With Quote Quick reply to this message
Old 05-11-2015, 05:05 AM   #5 (permalink)
All these tricks do work and work well. The squeeze also works with these links but you will be doing it again in two weeks are so .
For the T/R control rods I strongly suggest you resize the links and get those silky smooth.
halfcab is online now        Reply With Quote Quick reply to this message
Old 05-11-2015, 09:43 PM   #6 (permalink)
I tried using the Boto sizer... It took too much meat leaving my links way too loose... Granted it was my first time ever trying to size ball links... I didn't like it.. Ended up getting new links for the entire bird... I just let mine wear in...
cml001 is offline        Reply With Quote Quick reply to this message
Old 05-12-2015, 10:20 AM   #7 (permalink)
You do have to loosen the screw in the end when they are new or it can cut too much. I have wasted a couple links learning mine for sure. But it's worth it, particularly on the tail control rod and pitch links.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 05-12-2015, 11:45 AM   #8 (permalink)
I think I got mine from Ralph at FLB Rotors, and it was set, I didn't have to do anything to it.
Grimmy is offline        Reply With Quote Quick reply to this message
Old 05-16-2015, 03:44 PM   #9 (permalink)
Hummmm.. How do u know how much to back it out?
Old 05-18-2015, 09:53 PM   #10 (permalink)
I backed the screw out till the tension was off, then screwed it back in just a bit, till I felt some resistance.
It took only a turn or two with the Boto sizer to get the links to size after that.
After doing most of the links in the build, I tightened it just a hair more, to get the last ones.
Al
T-Rex 500GF, Compass Knight 3D,Raptor E700, Rave 450
Newest member of the fleet: Synergy N7
Futaba 14SG
airpup86C is offline        Reply With Quote Quick reply to this message
Old 06-20-2015, 10:47 AM   #11 (permalink)
I just ordered one as well, hoping to finish my N5c up soon.
flyswatter40 is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 08:29 AM   #12 (permalink)
Careful, as I found out its easy to overdue it and end up with sloppy balls
datatools is offline        Reply With Quote Quick reply to this message
Old 06-23-2015, 12:30 PM   #13 (permalink)
I have used several different brands of ball link sizers over the years and the Boto sizer has worked the best. They are reamers and are all adjustable so yes you have to start small (very little tension on the set screw) and work your way up until you have it set correct for the links. I do one at a time and once the sizer is set I will only do a few twists in a new link and test the fit on a ball then maybe one more until I have the fit I want. Even when set if you do a bunch of twisted in the link it will cut oversize . Slow and carful will produce perfect fitting links that within a half dozen flights will have zero slop and very little friction . The old measure twice cut once deal
Rotor-Tech Blades
Old 07-06-2015, 09:07 AM   #14 (permalink)
The sizer arrived, slickest little device, highly recommend it. After reading here first I never ruined one link , they are all perfect, Awesome!!
Old 07-08-2015, 06:56 PM   #15 (permalink)
Well.. I may pull them outta the drawer for my next build then.. Good to hear!
