Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Like Tree1Likes
  • 1 Post By eltavito
Old 02-05-2017, 02:35 PM   #1 (permalink)
Default New Diabolo Black Edition maiden
I’ve finally finished this heli and conducted the maiden flight today. The machine felt extremely locked in, it hovered hands-off on the first takeoff. I must add that the customer service from Gerd has been excellent! I picked up the kit in person from the Minicopter factory and since then, Gerd has been accessible on his personal phone to answer the few questions I had during the build.
Setup:
-Diabolo Black Edition with Diabolo L lower frames, carbon landing bows and rubber belt tensioner.
-Titanium frame screws (70g weight savings).
-FBL unit: Vbar NEO with Vlink.
-Motor: Pyro 850-50 competition (18T pinion = 10.91:1 gear ratio).
-ESC: Kosmik 200 with Mikado Telme unit for telemetry.
-Cyclic servos: Futaba BLS 273sv.
-Tail servo: Futaba BLS 276sv.
-Main blades: VTX 717.
-Tail blades: Rail 116mm.
-Batteries: 2x 7S 4400 mah Thunder Power 70C Rampage series.
Headspeeds:
Bank 1: 70% throttle – 1800 rpm
Bank 2: 74% throttle – 1900 rpm
Bank 3: 78% throttle – 2000 rpm
Below are some pictures of the new flagship of my fleet.
ID:	692774   Click image for larger version
ID:	692775   Click image for larger version
ID:	692776   Click image for larger version
ID:	692777   Click image for larger version
ID:	692779   Click image for larger version
ID:	692780   Click image for larger version
ID:	692781   Click image for larger version
ID:	692782   Click image for larger version
ID:	692784   Click image for larger version
ID:	692785   Click image for larger version
ID:	692786   Click image for larger version
ID:	692787   Click image for larger version
wstuart likes this.
eltavito is offline        Reply With Quote Quick reply to this message
Old 02-05-2017, 02:38 PM   #2 (permalink)
The Vbar NEO reported vibrations of 480 on the first spool up at 2000 rpm with blades on. Not sure how good these results are.
Old 02-05-2017, 02:41 PM   #3 (permalink)
congrats on the first flight. Very nice bird.
Trying to enjoy everything the RC hobby has to offer
Ramflames is offline        Reply With Quote Quick reply to this message
Old 02-05-2017, 09:15 PM   #4 (permalink)
Very nice congratulations almost exactly the same setup I have on my Triabolo balk except Pyro 750 Comp and 3 Digi.
A\ziz - Citizen 672
Minicopter Diabolo 700 Black, SAB Kraken 700, Kraken 580, Minicopter Diabolo 600, Minicopter Diabolo 550, Henseleit TDR Mark II, Henseleit TDR
Jeti DS24 / VControl Touch
aziz76 is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 12:31 AM   #5 (permalink)
Just beautiful machine.
|Michalis|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 03:13 AM   #6 (permalink)
I forgot to post the weight of this beast. 5.57 kg ready-to-fly at the moment. I'm hoping to reduce this by about 70g when Minicopter releases the much anticipated carbon fiber canopy. Then I should be able to get the weight down to 5.5 kg (12.1 lbs). Quite respectable for a 14S Pyro 850 setup.
Old 02-06-2017, 11:24 AM   #7 (permalink)
Nice. Where did you get the titanium screws set?
Verstuurd vanaf mijn SM-G920F met Tapatalk
bullet3030 is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 01:35 PM   #8 (permalink)
Most of them from:
https://www.lunsfordracing.com/mm5/m...ry_Code=METRIC
And some from:
https://shop.easyelox.de/
Old 02-10-2017, 06:30 AM   #9 (permalink)
Fastest and the most stable machine iv ever flown
Throw away anything at it and you will feel locked in the whole flight.
iv flown it at 1600,1800,2000 and 2200 and it is a monster..
Team Pilot SAB Heli Division.
Team Pilot Scorpion Power Systems.
Team Pilot BK Servos.
Team Pilot KDlipo Batteries.
Helimaster1 is offline        Reply With Quote Quick reply to this message
Old 02-11-2017, 12:07 AM   #10 (permalink)
What's the story on the top gear on the main shaft? My black edition has a steel gear there. Yours looks like the delrin or peek or whatever. You didn't convert it over to the smaller main shaft to go with standard gears did you?
I ask because since I won't likely fly aggressively enough to strip that gear in flight, I thought maybe I'd switch from a steel gear to a plastic one to reduce the need for lube between gears. I didn't think such a conversion was possible, without going to a smaller main shaft, and therefore the head, spindle, grips, etc...
corrosionate is offline        Reply With Quote Quick reply to this message
Old 02-11-2017, 02:48 AM   #11 (permalink)
The Black Edition now comes with high strength peek intermediate and main gears. They have been handling the power of the 850 competition pyro with no problem (3D flying). The peek gear is considerably lighter than the steel. The main shaft is the same diameter as yours.
Old 02-11-2017, 09:31 AM   #12 (permalink)
Hmm... cool :-). I'll have to check into picking those gears up one of these days. Thanks!
