Closed Thread
Old 07-25-2012, 05:11 PM   #21 (permalink)
Excellent thread, Scott!
Ah Clem is offline        Quick reply to this message
Old 07-25-2012, 05:54 PM   #22 (permalink)
The integrated swash driver pitch link is such a sweet idea. Surprised nobody had thought of that yet.
Ivan
9sec240 is offline        Quick reply to this message
Old 07-25-2012, 06:02 PM   #23 (permalink)
Thats why Charley is patenting it..Currently is Patent pending...
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Quick reply to this message
Old 07-25-2012, 06:33 PM   #24 (permalink)
Ivan,
Bro, this heli is sweet! I'm diggin' the build!
Scott
KBDD Team Pilot ):>
dunkonu23 is offline        Quick reply to this message
Old 07-25-2012, 07:38 PM   #25 (permalink)
well scott is doing a great job in detail so i will add some more pics for you guys
ID:	335290   Click image for larger version
ID:	335291   Click image for larger version
Trex 700e
hamstar78 is offline        Quick reply to this message
Old 07-25-2012, 07:39 PM   #26 (permalink)
couple more
ID:	335293   Click image for larger version
ID:	335294   Click image for larger version
Trex 700e
Old 07-25-2012, 07:56 PM   #27 (permalink)
Member
You guys going to burn the midnight oil tonight?
Sent from my phone
Bob O is offline        Quick reply to this message
Old 07-25-2012, 07:58 PM   #28 (permalink)
lol, not me im done for tonight i have to be up at 5:30 for work but i do have off friday and monday
Trex 700e
Old 07-25-2012, 08:08 PM   #29 (permalink)
Me thinks somebody will be maidening a new helicopter lol
Kevin Williams
Team OFH
Old 07-25-2012, 08:22 PM   #30 (permalink)
Raptor E720 uses it also.
(´・ω・`)
Blink 182 is offline        Quick reply to this message
Old 07-25-2012, 09:32 PM   #31 (permalink)
Yes, the Raptor head is similar in that it uses an integrated swash driver-pitch link.. But it is a different design still.. The raptor lever is longer and uses both sides of the lever. One side of the lever has the radius arm, the other side has the pitch link.
Kevin Williams
Team OFH
Old 07-25-2012, 09:40 PM   #32 (permalink)
Final head and swash plate assembly..
Bag 2 has the rest of the head parts and the swash plate, too.
Clockwise, 10mm spindle and bolts, grips, swash plate, pitch links and balls, pitch arms.
What's this? A scream mask? Nope, it's the inspiration for the ALeeS logo in the grip! Oh, there's a bag each of the grips...
The bags in the grips contain the thrust bearings, spacers, and grip bolts.
10mm spindle shaft and bolts.
It's recommended to lubricate the spindle with oil. I was fresh out, so I used a VERY thin film of synthetic grease. Synthetic lubricants will not ruin the dampers or flap insert.
Spindle shaft, installed.
Don't forget to clean the spindle threads. It's critical because...
There is usually oil used during manufacturing on the threads. If you only clean one thing, clean the spindle threads. Thread locker, even red, will not hold if there is oil on the threads. It's VERY dangerous to skip this step. You may get lucky, you may not. I go for caution, every time.
Thrust bearing order: Large hole in the race closest to the head, thrust bearing--open side in, small hole in the race to the outside of the grip.
Thrust bearing washer and packed thrust bearing. I used Triflow synthetic grease to pack the thrust bearing. Some folks like to use white lithium grease. The choice is yours.
Installing the pitch arms. Snug up the first screw, then tighten both screws evenly.
Head/spindle assembly with the damper spacer on the spindle. The damper spacer is beveled to one side. The slant side goes toward the damper. This is for preloading the damper.
Again, red thread locker on balls.
Installing the grips. Use the supplied 5mm allen wrenches--still can't get over this nice touch. It's just cool to get a helicopter with the things you would need to purchase, otherwise.
The underside of each grip has a flat spot to hold the nylock nut while tightening the blade installation--another nice touch. (There's that logo, again!)
The swash plate comes assembled. Check the 1.5mm screws for thread lock. Use blue thread locker if there is none on your assembly. This is a good practice for any assembly.
The swash plate with balls... yep... red thread locker on the balls.
The completed head. Links are set to 25.5mm per recommendation. Pretty cool looking head assembly, no?
At this point, it's recommended to install the main shaft. I'm going to hold off on that because later in the build I'll likely have to remove the head from the main shaft for setup. I just find this easier for me.
Next up, we'll start with bearing blocks, motor mount, and motor installation.
Scott
ID:	335319   Click image for larger version
Name:	What's inside Bag2.jpg
ID:	335320   Click image for larger version
Name:	No, it's not a Scream mask... Main grips, with something inside.jpg
ID:	335321   Click image for larger version
Name:	Thrust bearings and other goodies.jpg
ID:	335322   Click image for larger version
Name:	10mm spindle and 5mm bolts.jpg
Name:	Use either light oil or very little grease to install the spindle.jpg
ID:	335324   Click image for larger version
Name:	Spindle in the head.jpg
ID:	335325   Click image for larger version
Name:	Thrust bearing order Large hole-bearing-small hole.jpg
ID:	335326   Click image for larger version
Name:	Thrust bearings with Damper spacer.jpg
ID:	335327   Click image for larger version
Name:	Attaching pitch arms.jpg
Name:	Cleaning spindle threads.jpg
ID:	335329   Click image for larger version
Name:	Grease from threads.jpg
ID:	335330   Click image for larger version
Name:	Damper spacer--bevel in!.jpg
ID:	335331   Click image for larger version
Name:	Red Thread locker on balls!.jpg
ID:	335332   Click image for larger version
Name:	Installing grips -- red thread locker.jpg
Name:	Flat to hold nut for blades!.jpg
ID:	335334   Click image for larger version
Name:	Check screws!.jpg
ID:	335335   Click image for larger version
Name:	Swash assembly with balls--red thread locker on balls!.jpg
ID:	335336   Click image for larger version
Name:	Finished head - links are 25.5mm inside to inside.jpg
KBDD Team Pilot ):>
Old 07-25-2012, 09:48 PM   #33 (permalink)
Very nice writeup Scott. I am impressed with what I have seen of the heli so far. Looking forward to seeing it in person at IRCHA.
Ivan
Old 07-25-2012, 09:50 PM   #34 (permalink)
And see it you shall! Up close and personal, Ivan!
Scott
KBDD Team Pilot ):>
Old 07-25-2012, 09:59 PM   #35 (permalink)
Very nice Scott!
Kevin Williams
Team OFH
Old 07-25-2012, 09:59 PM   #36 (permalink)
scott, any realistic idea of when it will ready for the public to buy ?
are we talking weeks or months ?
also does anyone know how many kits will readyheli get in the first wave ?
dodgeboy is offline        Quick reply to this message
Old 07-25-2012, 10:06 PM   #37 (permalink)
I am hopeful we are down to weeks finalizing a few things first
Charley Stephens
Charley Stephens is offline        Quick reply to this message
Old 07-25-2012, 10:12 PM   #38 (permalink)
That's nice, how do those painters replicate that pattern every time? Do they use templates?
I can't wait for mine to arrive.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Quick reply to this message
Old 07-25-2012, 10:14 PM   #39 (permalink)
I see my name on one of those!!
Kevin Williams
Team OFH
Old 07-25-2012, 10:23 PM   #40 (permalink)
That's great news, Charley. Once folks get their hands on this kit, they'll have a Perma-grin, too!
Scott
KBDD Team Pilot ):>
Closed Thread
