Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-19-2014, 04:18 PM   #21 (permalink)
Banned
$850 WITHOUT gpro. Gotta read it
skyeboy is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 04:23 PM   #22 (permalink)
I've never seen anyone at my flying field run a gpro but to each it's own I guess lol
Sent from my SM-N900V using Tapatalk
Goblin 700 Competition, Goblin 380, Oxy 3, 180 CFX
bladeguy5 is offline        Reply With Quote Quick reply to this message
Old 10-19-2014, 04:26 PM   #23 (permalink)
Yes that's the price i paid for mine I'm running a ar7200...
Old 02-10-2015, 10:07 AM   #24 (permalink)
Default Stock Trex 550L
Hi Guys,
Need to upgrade this 550L of mine, as the Talon 90 is way inadequate.
With the stock 730MX 850KV Motor, I'd like to upgrade the power system to the following:
ESC: Phoenix Edge HV 120
BEC: Western-Robotics Hercules Super BEC G2
Keeping it 6s with a stock motor until the next upgrade to 12s, my question is:
Running this new above mentioned power setup, will the stock 730MX 850KV Motor handle the extra power??
Regards
MurdockMadness is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 11:12 AM   #25 (permalink)
Ur about to find out that 730MX is way inadequate. See the light change the motor...
Jeff B
800E Trekker - 700E DFC - 550v2 - 500 DFC - 450 DFC - Goblin 630
RV_7A is offline        Reply With Quote Quick reply to this message
Old 02-10-2015, 03:52 PM   #26 (permalink)
Jeff B
why isn't 730mx good?
ReadyToCrash is offline        Reply With Quote Quick reply to this message
Old 02-12-2015, 10:26 AM   #27 (permalink)
Default 730MX 850KV
730MX 850KV Max continuous current: 115A/195A(5sec)
run off a CC Edge HV 120 in a T550L ?
Also its only 6s for now..
when changing to 12s, that'll necessitate motor upgrade..
I think its good..
Old 02-12-2015, 10:42 AM   #28 (permalink)
The 730MX motor lacks rpm (kv) IMO. For most sport fliers is adequate. I'm simply stating that changing the ESC out to a higher amperage unit is not going to be cost effective for the return. I've done it. It wasn't worth the $ or effort. However replacing the 730MX motor with the 890kv scorpion was a far better return for the investment. This Heli loves the higher head speed and having overhead within the ESC is key to proper governing. To each his own though. Just trying to keep others from making the same mistake I made.
Jeff B
Old 02-12-2015, 11:14 AM   #29 (permalink)
Default LOL
swapping my dominator 850kv motor for a 890kv scorpion (40kv extra) vs changing the motor pinion adding more teeth for ultimately higher rpm.. same result less $$
or am I just smoking my socks ?
Old 02-12-2015, 01:12 PM   #30 (permalink)
havent flown mine yet. still have do ikon and esc setup.
How does everyone get on with the canopy stand offs? Ive been having a hard time taking the canopy on and off, its fiddly. im thinking of changing them for thumb screw fixings.
gileswalmisley is offline        Reply With Quote Quick reply to this message
Old 02-12-2015, 01:58 PM   #31 (permalink)
is anybody flying 550l on 12s? i'm thinking of making this conversion. i upgraded a 600pro i had with a 550l frame. it is, then, a 550l stretched that i fly 6s with the 650mx motor.
there is something wrong with this heli, though...
Old 02-12-2015, 02:14 PM   #32 (permalink)
Default 550L canopy stand offs
I was kinda disappointed with a few things on the 550L, going from a 550E.. the canopy is a mission..
As for 12s on the 550L.. I think it'll be terrifying, cannot wait!
Old 02-12-2015, 09:43 PM   #33 (permalink)
The motor isn't adjustable. Unless you machine the motor mount holes. And no one makes a 17 tooth pinion. And even if you found one you would be robbing torque from the already weak 730MX.
Jeff B
Old 02-13-2015, 08:21 PM   #34 (permalink)
BTW no one is gonna convert a 550L to 12S, there is no way you could ever balance it by shifting the packs to balance and the canopy fit.
Jeff B
Old 02-14-2015, 08:14 AM   #35 (permalink)
i think it would be possible if you placed a 3300mah battery on the tray and the 2nd one right under the main shaft, sitting on the bottom part of the frame. since there is no bottom plate anymore, some sort of plank or board would be needed.
i think i'm going to try this. for some reason the stretched 550l with the 650mx motor that i put together is not flying very well.
Old 02-14-2015, 02:14 PM   #36 (permalink)
Jeff B
I agree 100 percent on the 730mx being inadequate or a proper choice for the gear ratio of the heli. anything over 2300rpm and you have no headroom, anything below 2400rpm feels sluggish. nice job align.
i however wouldnt run the talon with the 730mx or scorpion, not for performance but for safety. i hit 175a+ multiple times a flight on my 730mx using a edge 120hv. i would sure be nervous running a talon.
What kind of current/watts are you pulling with the scorpion 890kv and what timing?
been looking for the best motor upgrade for my 550 that wont kill lipos
avoidthedog is offline        Reply With Quote Quick reply to this message
Old 02-14-2015, 03:17 PM   #37 (permalink)
Using a kde adjustable motor mount and bearing support will allow you to use any motor and pinion combination you want.
1100kv, 12t, and the 112t slant is what I use and it is 2600rpm @ 100 %
T-Rex 450 Pro DFC
xrayray is offline        Reply With Quote Quick reply to this message
Old 02-15-2015, 09:31 AM   #38 (permalink)
Please post the link here to this adjustable mount for the 550L.
Jeff B
Old 02-15-2015, 10:03 AM   #39 (permalink)
Jeff B
i think it is the same used on 600pro. you'd have to make two new holes on the 550l frame for the motor plate and maybe machine the counter bearing a little bit or it would touch the autorotation gear.
http://www.kdedirect.com/collections...cts/at600p-umm
Old 02-15-2015, 10:28 AM   #40 (permalink)
Yes same width between the 600 pro and 550L. Btw mesh is adjusted by loosening the side bolts, they slide on little rails.
T-Rex 450 Pro DFC
