Old 10-16-2009, 12:53 AM   #1 (permalink)
Default AR6200 ( remote rx Flashes)
So I know that if both the Rx, ( main and the Remote flash)
There is a power failure and system rebooted and reconnected.
BUT what does it mean when only the Remote Rx on the AR6200 Flashes ?
I've seen this now on two AR6200.. one on a plane.. where Rx are Isolated from any wires ect.. and one on a Heli ..
Any one know.. ??
Thanks..
helinewbee300 is offline        Reply With Quote Quick reply to this message
Old 10-19-2009, 02:45 PM   #2 (permalink)
Typically this would be an issue with the connector cable to the remote. Another possibility is a spark hitting the remote antenna, which can happen on some setups of belt driven heli tails.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se
Sonic_BOOMER_SOONER is offline        Reply With Quote Quick reply to this message
Old 10-20-2009, 02:51 PM   #3 (permalink)
Default Thanks..
Sonic,
Thanks for your reply,
I don't have to much room on the air frame, But found a spot let see if that helps.
I did have the Remote Rx - mounted on the outside of the fail boom, on the frame.
Got is as far as possible now way from the boom .. Let see if that helps..
Thanks again..
Old 10-20-2009, 08:14 PM   #4 (permalink)
It could be that the voltage dropped enough for the sat to reboot, but not the main.
Since they are different pieces of equipment, they can have different low voltage cutoffs. When I tested mine, some pairs had as much as a 0.1 volt cutoff difference.
Terry
AMA#47402, IRCHA # 3395
Old 10-21-2009, 10:32 AM   #5 (permalink)
Have you simulated it on the bench?
Make sure they both flash, you might just have mismatched firmware.
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote Quick reply to this message
Old 10-24-2009, 08:47 PM   #6 (permalink)
I find this believable, I have the stock Regulator running DS610's and I have the same problem if I work the stick vigorously (on the bench) the remote will flash.
I feel this is a current issue, everything is fine until the voltage on the Receiver pack drops slightly. I have an upgraded BEC on it's way to replace the stock and I'll let you know the outcome.
T-Rex 600e – 12's – Full KDE upgrade – elogger – Spider gear – Align 610 cyclic's, 650/401 tail – CY 600 main 95 tail – CC HV85 – Scorpion 4025-630/6mm shaft - boca bearings - 700 main gear
T-Rex 450SE – 430x – Align BL35X ESC – 401/S9650 tail – Hitec HS-65HB – Custom canopy – elogger – AR6200 – 3S1P 2250mAh 30C Trainer
AMA Member - 937052
bobkat is offline        Reply With Quote Quick reply to this message
Old 10-27-2009, 06:02 PM   #7 (permalink)
I did replace the stock BEC (keeping the stock rx battery) and my problem went away. I'm using the CC BEC Pro; set at 5.8v (using the castle link). I hope to stick with this BEC (if it pans out) when I go 12's.
-bobkat
AMA Member - 937052
Old 11-16-2009, 11:28 AM   #8 (permalink)
does it happen when flying or when powering up
I have seen many flash if the TX is too close on power up
Compass 7HVU HBL980/950 Ar7200bx Edge160-- Compass 6HV, 610/650
TRex 700LE , Beastx 610/650, Warp360 TracX 92A+
1BADAIR is offline        Reply With Quote Quick reply to this message
