Old 05-09-2014, 02:03 PM   #1 (permalink)
Default Will ikon fit in a 450L?
I'm thinking of getting a 450L Dominator with the Ikon FBL. I just noticed that the Ikon has connectors on all 4 sides, and is a little bit wider than the 3GX.
3GX dimensions: 36.5 x 25.2 x 15.6 mm
Ikon dimensions: 34 x 29 x 14 mm
Will it be difficult to make the Ikon fit in the 450L and still have access to all the connectors? Will any modifications be necessary? Are there any additional setup/tuning procedures to be aware of?
Oh, and this will be my first build.
Rotorious is offline        Reply With Quote Quick reply to this message
Old 05-09-2014, 03:10 PM   #2 (permalink)
Get the Bluetooth module if it blocks the USB port. The Bluetooth module plugs in next to the rudder servo and the sat plugs into the left side (looking down at the unit wires forward)
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 05-09-2014, 04:11 PM   #3 (permalink)
Good advice, but I don't have a smart phone to make use of the bluetooth module.
Old 05-09-2014, 09:57 PM   #4 (permalink)
neither do I, apple user here I got a $9 dongle from Frys and use my pc to make adjustments with it!! I have set up 3 trex 250's with ikon and you have to pull the tail servo to hook up to the usb so I ended up getting the Bluetooth module to avoid the extra work and it works great!
Old 05-09-2014, 11:55 PM   #5 (permalink)
It shoud fit the bottom gyro mount. The frame is 33mm wide inside and the access holes on the side of the bottom gyro mount allow access to side connectors. I mounted a Spektrum AR7200BX on the bottom.
FrankFuss is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 05:06 AM   #6 (permalink)
Ikon does fit the lower gyro mount. I have mine mounted with the usb port facing forward, and its pretty easy to plug in the usb through the battery bay.
Crash Artist
scrapheep is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 09:53 AM   #7 (permalink)
And if everything else fail mount it on the side of the frame.
Now you have access to all sides.
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is online now        Reply With Quote Quick reply to this message
Old 05-15-2014, 08:50 PM   #8 (permalink)
Share your iKon 450L FBL install photos (just ordered one) not a huge fan of the 3GX works ok but when you have flown V-bars and iKon's it's simply not in the same league.....
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 05-16-2014, 09:21 AM   #9 (permalink)
Thanks for the advice folks. I am placing my order today, and will post photos when it is done.
Old 07-05-2014, 09:00 AM   #10 (permalink)
Any photos with the Ikon installed..?
Sent fra min GT-I9505 via Tapatalk
Jotto is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 10:23 AM   #11 (permalink)
Oops, I forgot I was going to take pics. Check back later today or tomorrow.
Old 07-05-2014, 11:39 AM   #12 (permalink)
this is how i have mine installed:
the wires are facing back and i have no access to the usb port, so i use a
bluetooth module.
here is a post pf mine from a different thread with pics:
Originally Posted by bendisar View Post
here is mine:
I tried to get a good compromise between an easy serviceable heli, and a nice clean look.
most of the wires are hidden, Heli is stock except for a CC talon ESC, and an Ikon fbl (i have tried the 3GX, but it was crap)
running 1 sat receiver on the lower electronics tray.
had to shave off a little from the frame so the sat wire won't touch it and transmit vibrations to the fbl unit
esc to motor wires were left exposed so i can easily disconnect them when setting up the heli.
all in all it is a pretty easy heli to wire up neatly, way easier than the 450 pro, lots of room to run wires, and the wide frames help as well.
i am flying mine gove'd at 3250RPM and it is insanely powerful. when you tell it to go it goes fast! and shoots up in to the air like a rocket.
this is one fun little heli
Greetings from Israel
Trex 700e dfc pro HV\Ikon FBL\CC Edge 160
Trex 450L\Ikon FBL\CC talon 35
Gaui X3\Ikon\Talon 35\460MX
bendisar is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 01:55 PM   #13 (permalink)
I ended up placing the iKon on the underside of the gyro plate inside the frame, which worked out very well I think. The only downside to this position is that there is not much room between the iKon and bottom plate, so the Milton mod is not possible. A potential alternative would be to make an iKon sandwich like so:
-gyro mounting plate
-PU or Zeal pad
-iKon
-PU or Zeal pad
-bottom plate
I'm not sure if the pads would be over or under compressed. Just have to try it and find out I guess.
It was a bit tricky to route the wires so that I had enough service loop for easy maintenance, but I think I ended up with a pretty good layout. I can remove each component from the frame without cutting a single zip tie.
Name:	450L Wiring Diagram Left.jpg
ID:	520027   Click image for larger version
Name:	450L Wiring Diagram Right.jpg
ID:	520028   Click image for larger version
Name:	iKon placement inside frame.jpg
ID:	520029   Click image for larger version
Name:	rear detail 1.jpg
ID:	520030   Click image for larger version
Name:	rear detail 2.jpg
Name:	rear detail 3.jpg
ID:	520032   Click image for larger version
Name:	rear detail 4.jpg
Old 07-31-2015, 03:19 PM   #14 (permalink)
I ended up mounting mine in the standard position. I did scoot it back 1/4 of an inch though. This allowed me to fit a usb cable in under the anti rotation bracket.
perrybd is offline        Reply With Quote Quick reply to this message
